Security hardening
Pioreactor is usually operated on a trusted lab or classroom network. If other people can reach that network, or if you are enabling remote access, take a few minutes to reduce what can be changed from the UI and from default credentials.
Keep the cluster off the public internet​
Do not expose the Pioreactor UI directly to the public internet. If you need remote access, use a private network option like Tailscale instead of router port forwarding.
Use a network you control when possible. A dedicated lab network, router, or local access point limits who can reach the UI, SSH, and MQTT broker.
Change default passwords​
During Raspberry Pi Imager setup, use a password that is not the default raspberry. If a Pioreactor is already installed, SSH into each Pioreactor and change the pioreactor Linux user's password:
passwd
If you use the built-in local access point, change its SSID and password in config.ini under [local_access_point]. See Changing SSID name or password for your local access point.
Add a UI password​
If you want the UI to ask for a username and password, install the pioreactor-basic-auth-for-ui plugin on the leader:
pio plugins install pioreactor-basic-auth-for-ui
pio run change_ui_credentials <username> <password>
Add the generated API key to config.ini under [ui_basic_auth], then restart the leader.
This adds a password prompt, but it does not encrypt traffic. The UI still uses HTTP, so someone else on the same network may be able to read traffic. For remote access, use a private network option like Tailscale.
Disable plugin changes from the UI​
Plugins run code on your Pioreactors. If you do not want users with UI access to install plugins, install plugins from USB, or uninstall plugins from the Plugins page, create a DISALLOW_UI_INSTALLS file on the leader:
touch ~/.pioreactor/DISALLOW_UI_INSTALLS
For stronger protection, create the same file on every Pioreactor in the cluster:
pios cp ~/.pioreactor/DISALLOW_UI_INSTALLS
This also blocks direct plugin install API calls to worker units.
After this file is present, make plugin changes over SSH instead:
pio plugins install <plugin-name>
pio plugins uninstall <plugin-name>
To allow UI plugin changes again, SSH into the Pioreactor and remove the file:
rm ~/.pioreactor/DISALLOW_UI_INSTALLS
Keep software updated​
Install Pioreactor updates from Updates when they are available. Updates include bug fixes and security improvements for the UI, API, and cluster tooling.
If your Pioreactor does not have internet access, use USB software updates or another offline update method.
Limit who can SSH​
Only share the pioreactor username and password with people who should be able to control the machine. SSH access can install software, edit configuration, and run commands directly on the Pioreactor.
For shared environments, consider using a separate router or local access point for the Pioreactor cluster so the machines are not reachable from a broad guest network.
