Writing Pioreactor scripts with Python
This article isn't intended as a crash course in Python, or Pioreactor software, but some helpful ways to write small scripts for your Pioreactor. If interested in learning more, check out the developer docs for detailed information.
For this tutorial, you'll need to be able to SSH into your Raspberry Pi.
1. SSHing into your Raspberry Pi
SSHing means to connect to a computer remotely, and interact with its command line. In our case, we wish to interact with the Raspberry Pi remotely. SSH software depends on your operating system:
- Windows users: use the Command Prompt, or install PuTTY, or install the Secure Shell App for Google Chrome.
- macOS users: open up the terminal app:
command+space, search for "terminal".
We need to connect to the Raspberry Pi:
- hostname: your Pioreactor's name (see web interface) also-known-as your Raspberry Pi's hostname.
- user:
pioreactor - password: the one you used when you installed the Pioreactor, by default it's
raspberry.
One your online, you can have some fun and type pio blink to have your Pioreactor blink!
2. Writing our first script.
We'll start with something simple: writing a script to turn on the Pioreactor's stirring. To create a file called script_test.py and edit it on the Raspberry Pi command line, type nano script_test.py. You'll be shown an editor. Let's enter the following Python code:
import time
from pioreactor.background_jobs.stirring import start_stirring
stirrer = start_stirring(target_rpm=400)
time.sleep(10)
Hit crtl-x, and then Y to save our file.
3. Running our Python script
To run our script, type python3 script_test.py in the command line. If everything works correctly, your Pioreactor's stirring will start, and then finish after 10 seconds.
To make stirring run forever, let's edit the file again: nano script_test.py, and replace time.sleep(10) with:
import time
stirrer.block_until_disconnected()
Save the file with crtl-x, and then Y, and run the script again. Now, the job will run until you log off, or exit the program with ctrl-c. This is because block_until_disconnected will block to program at that line.
4. Extending our script: more jobs, changing RPM, and adding lights.
Let's add some more to our script. Let's say we also want to:
- turn on an LED in channel B,
- turn on optical density reading (with the reference photodiode in channel 1 and the 90° photodiode in channel 2, the default wiring).
- After 10 seconds, slow down the stirring RPM
import time
from pioreactor.background_jobs.od_reading import start_od_reading
from pioreactor.actions.led_intensity import led_intensity
led_intensity({'B': 50})
od_reader = start_od_reading({"1": "REF", "2": "90"})
time.sleep(10)
stirrer.set_target_rpm(300)
You should see data coming into to your experiment overview in the web interface!
5. Adding an automation
Next, we'd like to start heating and keep our vial at a constant temperature. Recall that all temperature tasks are actually temperature automations. In this case, we require the thermostat temperature automation, invoked from a temperature controller:
import time
from pioreactor.background_jobs.temperature_automation import start_temperature_automation
thermostat = start_temperature_automation("thermostat", target_temperature=32)
time.sleep(10)
Starting a long-running script
To run a script in the background so it continues after you close the terminal:
python3 your_script.py >/dev/null 2>&1 & disown
You can also use custom scripts in plugins to control the script's start and stop from the Pioreactor UI.
Useful utility objects
get_unit_nameandget_assigned_experiment_name, frompioreactor.whoami, return the current Pioreactor name and its assigned experiment. Use these when constructing jobs directly so data is associated with the correct unit and experiment.- RepeatedTimer runs a function every N seconds without blocking the rest of your script.
