Preparing your vial for cultures
1. Preparing the vial
Cleaning the vial
It's recommend to clean your vial and vial cap before every use. The vial and cap can be cleaned with water and detergent. Rinse vial and cap to remove any soap residue.
Two useful accessories for cleaning:
- small bottle brush / test tube brush.
- ~10ml syringe with luer lock attachment to pump soapy water in and out of the vial cap connectors.
Choosing a volume for your culture
We suggest using between 8ml to 16ml volume of liquid in the 20ml vials, and 10ml to 30ml for 40ml vials.
Some things to consider when selecting a volume: a lower volume will provide more aeration per mL since the liquid-air interface is fixed. A lower volume will also be more responsive to changes in temperature, and be able to achieve a higher maximum temperature. But too low and the vortex caused by stirring may start interfering with the Pioreactor's optical system (a lower RPM can fix this though).
Position of tubes/steep ports in cap
Keep at least 1 cap tube/port out of the liquid and well away from potential bubbles / foam that may occur. This will prevent gas pressure from building up. Something also to keep in mind: more tubes/steep ports out of the liquid means more gas transfer with the ambient atmosphere.
If using pumps with your Pioreactor, see the note below.
2. Preparing media
Prepare your media as your protocol suggests. For example: in the our experiments, we typically showcase yeast grown in YPD broth. To create YPD broth, mix YPD and water at a ratio of 50 grams YPD powder to 1 liter distilled water.
3. Sterilization
Using heat
Divide the mixture into the vials to the correct volume, and add the stir bar in the vial.
The glassware vial, stir bar and vial cap that come with your Pioreactor are all fully autoclavable, and heat resistant up to 125℃. The luer lock ends can be covered with tin foil, or attached to air filters, or neither. Since the volume in the vial is so little, the autoclave only needs to be at its maximum temperature for a very short duration.
Don't have an autoclave? A kitchen pressure cooker works just as well. Still don't have that? You can use a stove top or hotplate: heat on a medium-low heat until boiling, and let boil for a few minutes. However, an autoclave or a pressure cooker is a more effective sterilizer.
Using sterile filtration
Filtered media can be directly added to a sterilized glass vial, or via the (sterilized) male luer lock steep ports.
4. Inoculation
Ideally in a sterile environment, the vial's lid can be removed and the inoculant can be added. Alternatively, for additional sterility, a port can be sent down a tube/port, without removing the cap at all.
How much inoculant should you add? That depends on the concentration of your inoculant. From our experience, we create a dense culture/stock culture by adding some amount of culture to sterile media or water, and then inoculate our vials from this stock.
For example, we add 0.5 grams of dried Baker's yeast to 15 mL of YPD broth, then store it in a fridge for further use.
We recommend measuring with a micropipette. If you are using a dropper, hold it vertically for more accurate, consistent drops.
5. Adjusting tube/stainless steel port lengths
Keep at least one of the bottoms of the tubes/steep ports in the cap above the liquid-air interface to avoid creating a pressured environment. Adjust the luer lock end until the other end of the tube/port is well above liquid level.
If you have an unused luer lock stainless steel port not being used for liquid handling or venting, you can use it as a baffle in the liquid to improve mixing.
