Experiment profile schema and syntax
Experiment profiles are YAML files that choreograph jobs across your Pioreactor cluster. This page documents the syntax the UI validates against and the constructs available when you are editing a profile directly.
Declare the profile format
Every experiment profile must declare the supported profile format at the top level:
version: "1.0"
Keep "1.0" quoted. An unquoted 1.0 is parsed by YAML as a number and is rejected. Profiles that existed before Pioreactor 26.7.0 are migrated automatically during the software upgrade; new or manually copied profiles must include this field.
Add profile metadata
It's a good idea to give your profile a descriptive and unique name. This way it will be easier to find later. Also providing a detailed description will help your colleagues (and future self!) understand what the profile accomplishes.
version: "1.0"
experiment_profile_name: stirring with different temperatures
metadata:
author: Cameron DP
description: Turn on stirring for all workers, but set the temperature to be different between them.
common and pioreactors blocks
Any tasks in the common block will execute that task for all workers assigned to the current experiment. The pioreactors block is where you can write tasks for specific workers. For example, you may want the stirring to be on for all Pioreactors, but you want the temperature to be different for two workers:
common:
jobs:
stirring:
actions:
- type: start
t: 0s
pioreactors:
pio001:
jobs:
temperature_automation:
actions:
- type: start
t: 0s
options:
automation_name: thermostat
target_temperature: 35
pio002:
jobs:
actions:
- type: start
t: 0s
options:
target_temperature: 32
Times refer to the profile start time
When writing a profile, note that any t field refers to when the experiment profile started, and not when the experiment started. Use either a bare number (interpreted in hours) or a string with a unit suffix (s, m, h, or d, such as 30s, 0.5h, or 2d); negative values are rejected.
Conditionals and expressions
How the if directive works
The if directive can be included in any action to conditionally execute it or not. The expression is evaluated when the action is scheduled (that is, after t time has passed since the profile started).
The if directive supports the boolean operators and, or, and not, parentheses, the literals True and False, comparisons (==, >=, <=, >, <), and basic arithmetic on floats (+, -, *, /). Strings must be bare words without spaces.
How expressions work
Expressions are our way to fetch dynamic data, provided from jobs, during execution of profiles. For example, the following:
pio1:stirring:target_rpm >= 500
fetches the target_rpm from pio1's stirring job at execution time, compares it to 500, and returns true or false. You can use that inside an action:
stirring:
actions:
- type: update
t: 6h
if: pio1:stirring:target_rpm >= 500
options:
target_rpm: 400
You can also compare against strings. For example, to stop a job if the temperature automation currently running equals thermostat:
actions:
- type: stop
t: 6h
if: pio1:temperature_automation:automation_name == thermostat
Many published settings are nested JSON blobs. Use . to index into them:
actions:
- type: update
t: 6h
if: pio1:temperature_automation:temperature.temperature <= 30
options:
Expressions in options
Options can interpolate expressions as well. Wrap them in ${{ ... }} so the parser can distinguish expressions from literal strings:
pioreactors:
worker1:
jobs:
stirring:
actions:
- type: start
t: 0s
options:
target_rpm: 500
- type: update
t: 12h
options:
target_rpm: ${{ worker1:stirring:target_rpm + 50 }}
You can reference other jobs, too. The example below adjusts stirring based on optical density:
- type: update
t: 12h
options:
target_rpm: ${{ worker1:stirring:target_rpm + worker1:od_reading:od2.od * 10 }}
Expressions in config_overrides
A start action can also interpolate expressions in config_overrides. Each key overrides a setting in that job's <job_name>.config section for the new process:
- Place
config_overridesalongsideoptions, not inside it. Useoptionsfor job arguments andconfig_overridesfor configuration settings. - Use a flat mapping of setting names to literal values or
${{ ... }}expressions. Expressions are evaluated when the start action runs, and values are passed to the new process as strings. - Overrides apply only to the process started by that action. They do not edit
config.iniorunit_config.ini, or change already-running jobs. Include the overrides again in any later start action that needs them. - This field is supported on
startactions only. It cannot select other configuration sections or accept nested section mappings.
version: "1.0"
experiment_profile_name: configurable-stirring
inputs:
stirring_pwm_hz: 100
common:
jobs:
stirring:
actions:
- type: start
t: 0s
config_overrides:
pwm_hz: ${{ stirring_pwm_hz }}
Here, pwm_hz overrides [stirring.config] for the new stirring process. To use a fixed value instead, write pwm_hz: 100.
Expressions in the common block
Expressions can reference a specific Pioreactor by name (for example worker1:stirring:target_rpm). Inside the common block, you usually want each worker to look at its own value instead. Use the ::<job>:setting syntax, which leaves out the unit name:
::<job_name>:setting
The :: is replaced with the name of the Pioreactor the action is running on. Because common actions run once for each worker in the experiment, every worker evaluates the expression against its own job. It is not an aggregate (such as an average or maximum) across workers.
For example, to raise the stirring RPM on each worker whose own target is at or below 500:
common:
jobs:
stirring:
actions:
- type: update
t: 6h
if: ${{ ::stirring:target_rpm <= 500 }}
options:
target_rpm: 500
You can also use this syntax when building options:
common:
jobs:
stirring:
actions:
- type: update
t: 6h
options:
target_rpm: ${{ ::stirring:target_rpm + 10 * ::od_reading:od2.od }}
Built-in functions in expressions
There are a few helper functions you can call inside ${{ ... }}:
random()produces a random number between 0 and 1.unit()returns the unit the expression is evaluated for.job_name()returns the job the expression is evaluated for.experiment()returns the name of the current experiment.hours_elapsed()returns the time (in hours) since the profile began.
Action reference
start and stop
start launches a job or automation, and stop halts it.
pause and resume
pause temporarily suspends a job or automation, and resume restarts it from the paused state.
update
update mutates settings on a running job. Provide the new values inside options:
actions:
- type: update
options:
volume: 0.75
duration: 15
log
log writes a message to the experiment log. options.message is required, and options.level defaults to notice.
actions:
- type: log
options:
message: "This is a message, and it can contain expressions like ${{ unit() }}."
level: info
when
when triggers one or more actions the first time a condition becomes true. For example, start a chemostat when OD exceeds a threshold:
common:
jobs:
od_reading:
actions:
- type: start
dosing_automation:
actions:
- type: when
wait_until: ${{ ::od_reading:od2.od > 2.0 }}
t: 0s
actions:
- type: start
t: 0s
options:
automation_name: chemostat
volume: 0.6
duration: 10
t delays evaluation until the specified time. Once the condition fires, the when action is exhausted and will not run again.
repeat
repeat loops a block of actions. It requires two fields:
actions: the actions to perform each iteration. Theirtvalues are relative to the start of the loop.every: how long between iterations.
- type: repeat
t: 6h # start looping after 6 hours
every: 0.5h # run every 30 minutes
actions:
- type: update
t: 0s
- type: update
t: 0.1h
Optional fields provide stricter control:
max_time: total runtime of the loop. Withevery: 0.5handmax_time: 6h, the loop runs 12 times.while: an expression evaluated at the start of each iteration. If it returnsFalse, the loop exits.if: skip the entirerepeatblock when the expression isFalse.
A coarse turbidostat example:
add_media:
actions:
- type: repeat
t: 6h
every: 9s
while: ${{ worker1:od_reading:od2.od > 3.0 }}
actions:
- type: start
options:
volume: 1
remove_waste:
actions:
- type: repeat
t: 6h
every: 9s
actions:
- type: start
options:
volume: 1.5
To override Turbidostat's default biomass signal inside an experiment profile, set biomass_signal directly in the start options:
common:
jobs:
dosing_automation:
actions:
- type: start
options:
automation_name: turbidostat
target_biomass: 2.0
exchange_volume_ml: 1.0
biomass_signal: od_fused
The config-backed default lives in [dosing_automation.turbidostat]. A profile's config_overrides for this job targets [dosing_automation.config], so use the start option above to select the biomass signal for this run.
Defining top-level parameters with inputs
Surface key constants in an inputs section so collaborators can tweak them. Use the names in expressions anywhere in the profile:
inputs:
growth_phase_temp: 37.0
stationary_phase_temp: 30.0
od_threshold: 1.6
common:
jobs:
actions:
- type: update
t: 12h
if: ${{ ::od_reading:od2.od < od_threshold }}
options:
target_temperature: ${{ stationary_phase_temp }}
- type: update
t: 12h
if: ${{ ::od_reading:od2.od >= od_threshold }}
options:
target_temperature: ${{ growth_phase_temp }}
YAML syntax check and indentation tips
- Validate your YAML with a tool such as https://www.yamllint.com/.
- Mind indentation—YAML uses spaces to convey structure. For example, only the second example below is correct:
# correct ✅
common:
jobs:
actions:
- type: start
t: 0s
options:
target_temperature: 30
# wrong ❌
common:
jobs:
actions:
- type: start
t: 0s
options:
If you see an error such as Expected "object", got "array" at ...options, make sure you are not prefixing option keys with -:
# wrong ❌
options:
- automation_name: thermostat
- target_temperature: 30
# correct ✅
options:
Schema reference
The UI validates profiles against this schema and performs an additional run-time check.
# Main structure of the experiment profile
version: "1.0" # Required and quoted; unquoted 1.0 is a YAML number and is rejected
experiment_profile_name: <string> # Name of the experiment profile
# Metadata (optional)
metadata:
author: <string>
description: <string>
# Plugins (optional)
plugins:
- name: <string>
version: <string> # version or constraint, e.g. "1.2.3" or ">=1.2.3"
# Inputs available to expressions (optional)
inputs:
<input_name>: <value>
# Jobs common to all Pioreactors (optional)
common:
jobs:
<job_name>:
actions:
- # see Action definitions below
# Jobs per Pioreactor (optional)
pioreactors:
<pioreactor_unit_name>:
label: <string>
jobs:
<job_name>:
actions:
# Action definitions
- type: log
t: <time_string_or_float>
if: <bool_or_expression>
options:
message: <string>
level: DEBUG|debug|WARNING|warning|INFO|info|NOTICE|notice|ERROR|error (default: notice)
- type: start
options: {<option_name>: <value>} # expressions allowed via ${{ }}
args: [<string>, ...]
config_overrides: {<config_name>: <value>} # expressions allowed via ${{ }}
- type: update
- type: pause
- type: resume
- type: stop
- type: repeat
every: <time_string_or_float>
while: <bool_or_expression> # optional stop condition
max_time: <time_string_or_float> # optional cap on total time loops run for
actions:
- # basic action only (log, start, pause, resume, stop, update)
- type: when
wait_until: <bool_or_expression>
actions:
- # any action (including repeat/when)
# Profile expression syntax (used in ${{ ... }} in options/conditions)
# Literals
# - Numbers: integer or float (e.g., 1, -2.5)
# - Booleans: true, false (case-insensitive)
# - Names resolve to values provided in the expression environment (inputs, etc.); otherwise they remain strings.
# Operators
# - Arithmetic: +, -, *, / (raises on division by zero), ** (exponent)
# - Comparisons: <, <=, ==, >=, >
# - Logical: and, or, not
# - Parentheses for precedence
# Functions
# - random(): float in [0,1)
# - unit(): current unit name
# - hours_elapsed(): current action time
# - experiment(): current experiment name
# - job_name(): current job name
# MQTT lookups
# - <unit>:<job>:<setting>[.<nested_key>]*
# - ::<job>:<setting>[.<nested_key>]* (uses current unit)
# Examples: unit():od_reading:od600, ::stirring:setting.target_rpm
# Bioreactor topics contain timestamp and value fields: use ::bioreactor:current_volume_ml.value.
# Fails if worker is inactive or topic missing.
# Conversion rules
# - Numeric strings become floats; "true"/"false" become booleans; otherwise strings stay strings.
# Time strings
# Accepted formats are either a number (float/int) meaning hours, or a string that is a number immediately followed by a unit:
# s, m, h, or d (case-insensitive). Examples: 0.5 (30min), "30s", "2m", "1.5h", "2d". Whitespace or extra text is rejected, and
# negative values are disallowed
Examples
See examples of experiment profiles here.
