Camera snapshots
Pioreactor can use a Raspberry Pi camera or a V4L2/USB camera to photograph cultures during an experiment. The camera feature is experimental. Capturing images still requires a connected, supported camera.
Camera snapshots are stored on the Pioreactor that captured them. In the Pioreactor UI, you can:
  • see the latest image from each Pioreactor in the current experiment;
  • take a snapshot immediately or capture one automatically on a schedule;
  • review, enlarge, download, or delete earlier snapshots; and
  • download all snapshots from one Pioreactor as a ZIP file.
Enable camera snapshots​
Open Configuration, select the shared config.ini, and add or update the following section:
[camera]
enabled=1
snapshot_interval_minutes=5
use_ir_led=1
ir_led_intensity=25
snapshot_interval_minutes is the number of whole minutes between automatic snapshots. Set it to 0 to disable scheduled captures while keeping manual captures available.
With use_ir_led=1 (the default), captures use the Pioreactor's IR LED at ir_led_intensity. Set use_ir_led=0 to capture using your own lighting without changing the IR LED. In that mode, ir_led_intensity is not used for camera captures.
Next, configure the type of camera connected to each Pioreactor.
For a Raspberry Pi camera:
capture_backend=rpicam
camera_index=0
For a V4L2/USB camera:
capture_backend=v4l2
device_path=/dev/video0
The shared settings apply to every Pioreactor. If your cluster uses different camera types or device paths, put those camera-specific overrides in each Pioreactor's unit_config.ini. After saving the configuration, reload the Pioreactor UI.
Reducing condensation with a Raspberry Pi camera
Set keep_camera_active=1 to keep a Raspberry Pi camera sensor warm between captures. This can reduce coverslip fogging when the culture or headspace is warm. This setting does not apply to USB cameras and takes effect after the affected Pioreactor's Huey service restarts (a reboot also applies it).
Capture and review snapshots​
Open Cameras in the sidebar. Each assigned Pioreactor with a detected camera has a camera card.
  • Use Capture snapshots automatically to enable or disable scheduled captures for an individual Pioreactor. The interval still comes from snapshot_interval_minutes.
  • Open the snapshot history to Capture snapshot, browse earlier images, delete individual images, or choose Download all snapshots.
  • Toggle Colour view to apply the Magma colour map and highlight differences in image brightness.
  • Use the pencil icon (Rename photo) beside an image to change its name, then click Rename.
  • You can also take an immediate snapshot from that Pioreactor's command line with pio run camera_snapshot.
Naming snapshots​
The UI assigns a name automatically when it captures an image. Rename the photo afterward, or supply a name when capturing from that Pioreactor's command line:
pio run camera_snapshot --name culture-before-dosing
Use letters (A–Z, a–z), digits, dots, dashes, or underscores, without spaces or the .jpg extension. Names must be unique across stored photos on that Pioreactor, including photos from other experiments. An existing photo is not overwritten. Renaming changes the image's filename and identifier, while preserving its capture time and whether it was captured manually or automatically.
Storage and retention​
Automatic captures only run while the Pioreactor is active and assigned to an experiment. Each Pioreactor retains up to 500 scheduled snapshots per experiment, spread across the experiment timeline. Manually captured snapshots are retained until you delete them or delete the experiment.
warning
Deleting an experiment also deletes its stored camera snapshots from the Pioreactors that were assigned to it. Download any images you want to keep before deleting the experiment.
Raspberry Pi capture profiles​
Raspberry Pi captures use the native rpicam-still profile at $DOT_PIOREACTOR/camera/viewing.conf (normally /home/pioreactor/.pioreactor/camera/viewing.conf). It controls image settings such as resolution, tuning, exposure, and JPEG quality. The default profile uses JPEG quality 75 to keep file sizes small while retaining the image dimensions.
Editing viewing.conf affects snapshots and focus previews on that Pioreactor. If keep_camera_active=1, restart the affected Pioreactor's Huey service or reboot it to apply profile edits to the persistent camera process.
For a single manual capture, pass a different native configuration file:
pio run camera_snapshot --name culture-fixed-exposure \
--config /home/pioreactor/.pioreactor/camera/stable_cv.conf
The 26.9.0 upgrade installs stable_cv.conf, which fixes exposure and white balance for repeatable image analysis. It is configured for the OV5647 NoIR camera; check the sensor mode and tuning file before using it with another camera model. A custom file can be used instead. Relative paths inside the profile resolve from the profile's directory; environment variables inside native config files are not expanded.
--config is supported only with capture_backend=rpicam and requires the camera warmer to be stopped. If it is enabled, set keep_camera_active=0 and restart Huey or reboot the affected Pioreactor before using a custom profile. This override applies only to that capture; automatic snapshots continue to use viewing.conf.
Focus a Raspberry Pi camera​
For a manually focused camera, stop running optical-density, stirring, dosing-automation, and LED-automation activities on the Pioreactor. Then open Protocols, select that Pioreactor and Device = camera, and run Manual camera focus. The protocol shows successive preview images and guides you while you turn the camera's focus control.
Protocols page with the camera device selected and Run protocol highlighted for Manual camera focus
If a camera is not detected​
Check that the camera is connected to the selected Pioreactor and that capture_backend, camera_index, or device_path matches the camera. For USB cameras, a stable path under /dev/v4l/by-id/ is preferable to /dev/video0 when one is available.
With [camera].enabled=1, the Pioreactor's self-test includes Camera captures an image. Run the self-test from a Pioreactor's Self-test tab to check camera capture alongside the other hardware checks. To run just the camera check on that Pioreactor's command line, use:
pio run self_test -k test_camera_capture
Stop optical density reading, stirring, and automations before running a self-test. If the camera check fails, see Self-test reference and the Pioreactor's system logs.
