Back up and restore Pioreactor system files
Each Pioreactor keeps its configuration, calibration data, and persistent state inside ~/.pioreactor. The Inventory page now lets you export that directory as a system archive (.zip) for safekeeping and import it onto the same unit when you need to restore or clone a setup.
Control Pioreactor menu showing Export system archive and Import system archive actions highlighted
Exporting a system archive​
  1. Open the Inventory page, find the Pioreactor you want to back up, and click Control Pioreactor → Export system archive.
  2. Review the dialog and click Export when ready. The UI downloads a file named <pioreactor>_dot_pioreactor.zip.
  3. Store the archive somewhere safe. It contains every file from that unit’s ~/.pioreactor plus a pioreactor_export_metadata.json descriptor (hostname, version, export time).
Export system archive confirmation dialog with the Export button highlighted
After you confirm, the browser saves a zip named <pioreactor>_dot_pioreactor.zip.
Troubleshooting​
  • If export is blocked, check whether the unit has the sentinel file ~/.pioreactor/DISALLOW_UI_FILE_SYSTEM; removing it re-enables downloads.
  • Since the export is over http, you may need to "approve" your browser to download it (check the download tab in your browser).
  • For the leader Pioreactor, it's also exporting the sqlite database. This might take a while for very large databases.
Importing a system archive​
Use imports when you need to restore a backup, duplicate a Pioreactor after replacing hardware, or bring back calibration data after re-flashing an SD card.
  1. On the Inventory page, choose Control Pioreactor → Import system archive.
  2. Read the warning and click Select system archive file, then pick a .zip generated by the export flow.
  3. Wait for confirmation in the snackbar. The UI shows a spinner while uploading and tells you when the Pioreactor begins rebooting.
Important
Importing wipes the existing ~/.pioreactor on that unit before restoring the archive, so anything not inside the uploaded zip is permanently removed.
Import system archive confirmation dialog with the Select system archive file button highlighted
Important behaviour to note:
  • Hostnames must match. The worker compares the archive metadata to the target unit name and rejects mismatches during import.
  • The ZIP is validated to block absolute paths, symlinks, or other unsafe entries before anything is extracted.
  • An automatic backup of the existing ~/.pioreactor is written to /tmp/<hostname>_dot_pioreactor_backup_<timestamp> before any files are replaced. You can manually restore from that folder if you need to undo the import.
  • After the files are moved into place, the worker schedules a reboot so the new configuration takes effect.
  • Imports and exports share the same guard: adding ~/.pioreactor/DISALLOW_UI_FILE_SYSTEM disables both operations until the file is removed.
Advanced notes​
  • For scripted workflows you can hit /api/units/$broadcast/zipped_dot_pioreactor to download archives for every worker in one request. The aggregated ZIP namespaces each unit under a folder that matches its hostname.
  • Imports are always per-unit. If you are automating restores, loop over your hosts and POST the zip to /api/units/<pioreactor>/import_zipped_dot_pioreactor one at a time.
With these tools you can keep regular snapshots of your cluster, move calibrations between identical builds, or roll back quickly after testing changes.
