Disassembly
Step 1: Unplug and disassemble the optics system #
- Remove any vial placed in the Pioreactor.
- Remove the LED caps from REF, IR and 90° sockets.
- Remove the LED and PDs from their sockets.
If the LEDs/PDs are stuck in the socket, do not pull! Gently twist the bulb until it loosens from the socket to safely remove it.
- Unplug the PDs only from the HAT. Leave the LED attached - this will be reused in the v1.5.
Step 2: Replace the top vial holder #
- The new top v1.5 vial holder has a groove within the body where the #024 O-ring sits. Carefully insert the O-ring using your fingers. Make sure to not twist the O-ring.
- Run your finger inside the vial holder, pushing the O-ring into place to ensure a snug fit.
- Screw off the existing top vial holder by twisting it counter-clockwise. This old top isn't needed anymore.
- Screw on the new v1.5 vial holder until the IR LED lines up with the heater cable.
