Building the vial holder
Step 1: Inserting the O-rings #
The vial holder of the v1.1 now comes in two halves; a top vial holder and a bottom vial holder. Both have grooves to insert O-rings for a more secure hold on your vials and increased protection against leaks. The thinner O-ring (#024) fits into the top piece. The thicker O-ring (#121) lines the bottom piece.
The #024 O-ring has been switched to a version with an X-shaped cross section in recently shipped upgrade kits.
- The O-rings are pre-lubricated with a silicone-based lubricant. If needed, remove any excess lubricant from the O-rings.
- The top vial holder has a groove within the body where the thinner #024 O-ring sits. Carefully insert the O-ring using your fingers, making sure to not twist the O-ring.
- Run your finger inside the now-occupied groove, pushing the O-ring into place to ensure a snug fit.
- The bottom vial holder has a groove for the thicker #121 O-ring. The O-ring will sit between the base of the holder and the heater PCB. Carefully insert the O-ring using your fingers. Make sure to not twist the O-ring.
- Push the O-ring into place to ensure a snug fit.
Step 2: Attach the window cover #
- Place the window cover over the window. It should fit snugly.
- Attach it using four M2.5 4mm screws (2 provided in the upgrade kit, and 2 previously used in the old v1.0).
Step 3: Place and secure the heater PCB #
- Remove the thermal pad from the heater PCB.
- Place it aside so that the sticky side is upward. Take care to not dirty the thermal pad.
- Insert the flex cable below the O-ring and into the groove. Pull it through.
- Apply pressure on the back of the heater PCB so that it lies flat on the O-ring. Maintain this pressure for the next steps.
- While maintaining pressure, flip the piece over and insert the two M2.5-CS 5mm screws into the holes.
- While maintaining pressure, take turns screwing each in until both are flush, and the heater PCB is securely attached to the bottom vial holder.
- Stick the thermal pad back onto the heater PCB, sticky side down.
Step 4: Complete the vial holder #
- Screw the top and bottom vial holder sections together so that the IR label is positioned above the flat-flex-cable.
- Set this aside and proceed to the next page.
