Dosing and LED updates
Dosing​
You can run the pumps from the Pioreactor UI. These are not automations, but simple actions used to set up an experiment, perform cleaning, or intervene mid-run. For automated workflows, see dosing automations.
Specific control of pumps​
Under the Dosing tab, you can run specific pumps (media, waste, and alt-media) for a set duration, volume (if calibrated), or continuously. The latter will run until the Stop button is pressed. Read more about using pumps.
Careful not to overflow your vial! The Pioreactor doesn't know how much liquid is currently in the vial. Stay well below the max volume of the vial for safety.
UI showing how to add media.
Adjustments from manual changes​
Sometimes you may want to add or remove liquid from the vial by hand, for example when taking a sample. After the manual change, go to Pioreactors and edit the Current volume setting on that Pioreactor's card. This updates the estimated liquid volume without running the pumps.
For example, if you remove 0.2 mL from a vial that currently shows 14 mL, change Current volume to 13.8 mL.
UI showing how to update the current volume on a Pioreactor card.
LEDs​
Under the LED tab, you can update specific intensities of the LEDs. For automated light schedules, see LED automations.
UI showing how to change LEDs.
