Adding the Precision Temperature Upgrade Kit
The Precision Temperature Upgrade Kit adds a faster, more accurate external temperature sensor to a Pioreactor 20ml and 40ml.
Step 1: Install the FIR temperature sensor #
- Use a flat-head screwdriver or thin shim to gently lift and remove the plastic cover from the SPEC position.
- Connect one end of the provided STEMMA QT cable to the FIR temperature sensor PCB.
- Connect the other end of the cable to the nearest Eye-spy PCB.
- Place the sensor PCB into the open position. Match the orientation shown in the photos: the LED "pad" faces the right-hand side, and the 6 holes face the left-hand side.
- Optionally, secure the PCB with the provided 8mm M2.5 screws.
Step 2: Install the plugin
Power on the Pioreactor, open Plugins in the Pioreactor UI, and install pioreactor-precision-temperature-plugin on the Pioreactor with the new sensor.
Slow heating after changing sensors
In a cluster with different temperature sensors, check each Pioreactor's hardware and configuration together:
- Install the precision-temperature plugin only on units with the sensor attached.
- Check software compatibility and configuration against the plugin's current instructions.
- Keep sensor-specific thermostat settings in the individual Pioreactor configuration; shared settings affect other units too.
- When reverting to the original sensor, remove the plugin from that unit and restore the configuration appropriate to that sensor, including temperature sampling and thermostat settings. Removing hardware alone does not undo configuration changes.
Disconnect power before changing sensor connections. Before starting another experiment, verify temperature readings and heating response with the intended sensor and configuration.
