Connect the optics system
Step 1: Optic cables assembly #
- You will need both PD cables (dark bulbs) and IR cable (clear bulb).
- Insert the connector of either PD cable into PD channel 1 (labelled on the faceplate).
- Place the connector of the other PD cable into PD channel 2.
- Insert the connector of the IR cable into channel A (labelled on the faceplate).
Step 2: Inserting the bulbs into the vial holder #
Insert the bulb of the PD cable in channel 2 into the pocket labeled 90°.
Slowly bend the bulb's leads 90 degrees, as seen. Secure with a LED pocket cap.
cautionAvoid over-stressing the leads, or applying too much force too quickly. After bending once, it's ill-advised to bend them again.
Insert the bulb of the IR cable in channel A into the pocket labeled IR.
Bend the leads 90 degrees and secure with a LED pocket cap.
Insert the bulb of the PD cable in channel 1 into the pocket labeled REF. Orient the bulb's leads such that when bent 90 degrees, it does not interfere with the IR LED bulb next to it.
Inspect each LED and PD to confirm that neither of the leads are touching.
Step 3: Add the rest of the LED caps #
- Push all remaining LED pocket caps onto each pocket.
Step 4: Add the window covering (optional) #
This window covering is optional. You can add it to further reduce the light in the bioreactor, or you may leave it off to inspect the culture.
- You will need 4x 6mm screws, and the window cover.
- Attach the window cover to the side of the vial holder using the screws.
- Insert the glass vial into the Pioreactor. The vial should feel snug, but not very tight. If it feels too tight, try loosening the four 6mm screws slightly.
