Connect the optics system
Have the XR version? Move over to these instructions.
  1. You will need:
  • Eye-spy covers (3x)
  • 8mm screws (12x)
  • Eye-spies (2x)
  • 100mm Stemma-QT wire
  • 50mm Stemma-QT wire
  • LED cable
  • LED caps (4x)
STEMMA-QT wires may have white or black connectors.
Step 2: Install the eye-spys #
  1. Place an eye-spy cover over the REF eye-spy.
Each eye-spy is unique. The one used for REF has a white mark in the upper-left corner.
  1. With the tan connectors towards the top, place the eye-spy into the REF socket on the vial holder. Secure it with 4x 8mm screws.
  2. Place an eye-spy cover over the other eye-spy.
The measuring eye-spy can be placed in either the 90 or 135 degree pocket. For most applications, 90 degrees is the standard.
  1. Place the eye-spy into the desired pocket (90 or 135). Secure with 4x 8mm screws.
  2. Cover the remaining pocket with the last eye-spy cover. Secure with the remaining 8mm screws.
Step 3: Connect eye-spys to HAT #
  1. Locate the Stemma-QT connector on the HAT and connect the 100mm Stemma-QT wire, with the yellow wire furthest from the heater flat flex cable.
  2. Carefully connect the other end to the leftmost eye-spy. Use the colors of the wire to orient the connector correctly.
  3. Use the 50mm Stemma-QT wire to connect each eye-spy.
It does not matter which wires are connected to either eye-spy sockets. However, organize the wires neatly and avoid crossing over when possible. Insert each connector carefully and straight; pushing too hard can damage an internal pin.
Step 4: Connect LED cable (Channel A → IR pocket) #
  1. Connect the LED cable to the Channel A connector.
  2. Secure an LED cap over the unused pocket.
  3. Notice the flat side of the LED bulb and the flat protrusion in front of the IR pocket.
  4. With the IR cable pointing downward, gently insert the bulb into the IR pocket.
  5. Gently twist the LED cable to the left. The bulb should feel secured in the pocket. Cover it with an LED cap.
Step 5: You're done! #
Your new 20ml Pioreactor v1.5 is now assembled! 🚀
Next: begin installing the software.
