Writing a new automation
An automation is a hands-off way to adjust the environment for the microbes. We currently support three types of automations: dosing, LED, and temperature.
In this section, we'll develop a simple dosing automation.
Creating our first custom automation​
Writing an automation involves creating a Python class and overriding specific methods. It would be helpful to be somewhat familiar with Python classes before beginning. Here's an example of a (naive) turbidostat automation, i.e. it will add fresh media and remove old media when an optical density threshold is exceeded. The full code is below, and we'll go through each line of code after:
# -*- coding: utf-8 -*-
from pioreactor import types as pt
from pioreactor.automations.dosing.base import DosingAutomationJobContrib
class NaiveTurbidostat(DosingAutomationJobContrib):
automation_name = "naive_turbidostat"
published_settings = {
"target_normalized_od": {"datatype": "float", "settable": True, "unit": "AU"},
"exchange_volume_ml": {"datatype": "float", "settable": True, "unit": "mL"},
def __init__(self, target_normalized_od, exchange_volume_ml=1.0, **kwargs):
self._event_trigger_ready = False
super().__init__(**kwargs)
self.target_normalized_od = float(target_normalized_od)
self.exchange_volume_ml = float(exchange_volume_ml)
self._event_trigger_ready = True
def _set_normalized_od(self, message: pt.MQTTMessage):
super()._set_normalized_od(message)
if message.payload and not message.retain and self._event_trigger_ready:
self.trigger_run_once_from_event()
def execute(self):
if self.latest_normalized_od > self.target_normalized_od:
self.execute_io_action(
media_ml=self.exchange_volume_ml,
waste_ml=self.exchange_volume_ml,
First important thing is to subclass from DosingAutomationJobContrib:
The DosingAutomationJobContrib is a subclass of a BackgroundJob. The -Contrib part is a small detail to specify that it's a third-party automation (i.e. you are developing it, not us.)
We need a "key" to i) distinguish this from other automations, and ii) be able to be communicate between systems (think: the web UI in JavaScript to Python, and back). The automation_name attribute does this for us. Normally, it's the snakecase of the class name.
The published_settings tells the Pioreactor software what class attributes are published to MQTT, and if they are editable via MQTT (we will try editing over MQTT later). This is important if you wish to dynamically change attributes of an automation during an experiment, for example: from the web interface. Our class has the following:
The associated metadata says that the class attributes target_normalized_od and exchange_volume_ml are floats, are editable via MQTT (so they can be changed using the web interface), and have units.
Next, we define how to initialize our automation class. Here we can add settings we want to accept from the user: what is our initial target optical density. Note the boilerplate **kwargs, and super() are important.
Automations now choose their own trigger model. This example should react to new normalized OD readings, so it overrides the passive normalized-OD listener. The parent class stores the latest reading first. Then, for a fresh non-retained MQTT message, trigger_run_once_from_event() schedules one non-overlapping call to execute().
Finally, the execute method contains one decision/action. In our simple case, we want to dilute the vial if the latest normalized OD exceeds the target:
def execute(self):
Since we are working with a fixed volume, media_ml must equal waste_ml, else an error will be thrown. What is the latest_normalized_od attribute? Our class, when active, is listening to new normalized OD values being published by the growth-rate calculator. Hence when execute runs, we'll have access to the most up-to-date value. Likewise, there are also latest_growth_rate, latest_od, and latest_od_fused attributes that update when new values are calculated or published. These attributes are defined and maintained in the parent class.
For periodic automations, call self.run_every(...) in __init__ instead of overriding a passive listener. For example, a chemostat-style automation might accept duration and skip_first_run, then call self.run_every(duration, skip_first_run=skip_first_run, run_after_seconds=2.0).
Prefer self.execute_io_action(...) inside execute. If you need to call add_media_to_bioreactor(...) directly, remember to forward mqtt_client=self.pub_client and logger=self.logger:
def execute(self):
if self.latest_growth_rate < self.target_mu:
self.add_media_to_bioreactor(
ml=self.dosing_volume,
source_of_event=f"{self.job_name}:{self.automation_name}",
unit=self.unit,
experiment=self.experiment,
mqtt_client=self.pub_client,
logger=self.logger,
Running the automation​
How do we run this automation now? Let's copy the code into a file called naive_turbidostat.py and place it into the folder ~/.pioreactor/plugins.
You can create this file on your Pioreactor's Raspberry Pi: after accessing the Raspberry Pi's command line, typing nano ~/.pioreactor/plugins/naive_turbidostat.py, and pasting in the code below.
def execute(self):
Run the script with pio run dosing_automation --automation-name naive_turbidostat --target-normalized-od 0.5 --exchange-volume-ml 1.0. This will start the job. After a moment, you may notice that warnings are thrown - that's because there are no normalized optical density measurements being produced! You can use ctrl-c to stop the job.
Editing attributes over MQTT (optional)​
We'll demonstrate the ability to dynamically change the target_normalized_od attribute using MQTT. For each member of published_settings, the DosingAutomationJobContrib class listens to the MQTT topic:
pioreactor/<unit name>/<experiment>/dosing_automation/<attribute>/set
We'll use mosquitto_pub to publish a message to this topic. So, with the Python script running, open a new command line, and enter the following:
mosquitto_pub -t "pioreactor/test_unit/test_experiment/dosing_automation/target_normalized_od/set" -m 5.0 -u pioreactor -P raspberry
You should see some logs in the Python console report that the target_normalized_od was changed. Also, the value of 5.0 is published and retained to the topic pioreactor/test_unit/test_experiment/dosing_automation/target_normalized_od
Why is this useful?
  1. This is how the web interface updates settings in running activities.
  2. Other Pioreactor activities can update each other's settings.
  3. External programs or apps can monitor and update settings this way, too.
Adding the automation to the UI​
To add your automation to the UI so it appears in the automation drop-down, follow the the steps here.
Extensions of our custom automation​
Below are some extensions. Keep the event-triggering _set_normalized_od method from the complete example above; these snippets focus on the changed settings and decision logic.
Changing the volume exchanged​
Exchanging 1ml each time may not be enough, so the example includes exchange_volume_ml in published_settings. Since it is settable, the UI or MQTT can dynamically adjust the volume while the automation is running.
Using latest_growth_rate​
If our growth rate is high, we may want to modify the volume exchanged to keep up. A naive solution: we can bump up the exchanged volume if the growth rate is high. Much better would be a dynamic solution, or a feedback loop.
def execute(self):
if self.latest_growth_rate > 0.2:
self.execute_io_action(media_ml=2 * self.exchange_volume_ml, waste_ml=2 * self.exchange_volume_ml)
else:
self.execute_io_action(media_ml=self.exchange_volume_ml, waste_ml=self.exchange_volume_ml)
