Custom & additional pumps for dosing automations
The following provides solutions to:
  • using a different pumping system for the Pioreactor instead of our peristaltic pumps
  • adding additional pumps to the Pioreactor (i.e., more than media and alt-media). These additional pumps may be provided via another system, for example an Arduino.
Using external pumps with a custom automation​
The first thing to do is to add a hook to your custom pump into Pioreactor's software. To do this, we attach new functions to a dosing automation that are invoked when execute_io_action is called. These functions will call your logic that runs the external pump. Specifically, if we wish to overwrite the media pump, we create a function called add_media_to_bioreactor, with signature
(self, ml: float, unit: str, experiment: str, source_of_event: str, mqtt_client, logger, *, cancel_event: threading.Event) -> float
Every custom pump callable must accept the keyword-only cancel_event: threading.Event. Forward cancel_event=cancel_event and the supplied mqtt_client to built-in pump actions. When controlling hardware directly, observe the event and stop the pump when it is set. Cancellation permanently ends that operation, including across pause/resume. Return the estimated volume actually moved, rather than the requested volume if interrupted.
The examples below show the hooks; replace their placeholder bodies with hardware control that follows this contract. Import threading in your plugin.
To see this in an example:
from pioreactor.automations.dosing.base import DosingAutomationJob
class CustomPumper(DosingAutomationJob):
automation_name = "custom_pumper"
def __init__(self, **kwargs):
super().__init__(**kwargs)
def add_media_to_bioreactor(self, ml: float, unit: str, experiment: str, source_of_event: str, mqtt_client, logger, *, cancel_event: threading.Event) -> float:
# overrides the built in add_media_to_bioreactor
# add your custom logic here. Example could be interfacing with i2c, serial, PWM, etc.
pwm = PWM(...)
logger.info(f"pumping {ml}")
return ml
def execute(self):
self.execute_io_action(media_ml=1.0, waste_ml=1.0)
Whenever execute_io_action is called upon to add media, the custom function add_media_to_bioreactor is invoked. Similar logic applies to alt_media. Overriding waste uses a different name, as the next example shows:
return ml
def add_alt_media_to_bioreactor(self, ml: float, unit: str, experiment: str, source_of_event: str, mqtt_client, logger, *, cancel_event: threading.Event) -> float:
# overrides the built in remove_waste_from_bioreactor
return ml
def remove_waste_from_bioreactor(self, ml: float, unit: str, experiment: str, source_of_event: str, mqtt_client, logger, *, cancel_event: threading.Event) -> float:
return ml
def execute(self):
self.execute_io_action(media_ml=1.0, alt_media_ml=1.0, waste_ml=2.0)
Adding additional pumps beyond media and alt-media​
In general, we can use this same pattern to add even more pumps to the Pioreactor software, beyond media and alt-media. Let's say we have a third pump, salty-media, that we wish to also use along with media and alt-media. We define the function add_salty_media_to_bioreactor with the same signature above:
class ThreePumps(DosingAutomationJob):
automation_name = "three_pumps"
def add_salty_media_to_bioreactor(self, ml: float, unit: str, experiment: str, source_of_event: str, mqtt_client, logger, *, cancel_event: threading.Event) -> float:
# call an external pump, via i2c, serial, GPIO, etc.,
# or pumping_functions.add_salt_media
return ml
With this function defined, we can invoke execute_io_action with an additional kwarg, salty_media_ml:
def execute(self):
results = self.execute_io_action(waste_ml=3.0, media_ml=1.0, alt_media_ml=1.0, salty_media_ml=1.0)
Notice the salty_media_ml=1.0 kwarg: this represents how much salty-media volume to add (your pump is responsible to dosing the correct volume). (Note in the above example, media and alt-media are not overwritten, so would use the "traditional" peristaltic pump system provided.)
In general, execute_io_action will try to call a function called add_<name>_to_bioreactor if provided with a kwarg <name>_ml.
