Local development of Pioreactor
Local development​
  1. Confirm that Python3 is installed, and is greater or equal to version 3.13. python3 --version will print the version.
  2. To install the Pioreactor codebase locally, it should be enough to clone the repo pioreactor/pioreactor.
    git clone https://github.com/Pioreactor/pioreactor.git && cd pioreactor
  3. Install the core software and necessary packages (useful to do this in a virtualenv!):
    pip3 install -e core/
    pip3 install -r requirements/requirements_dev.txt -r requirements/requirements.txt
  4. In the pioreactor folder, create a folder called .pioreactor/ and other important subdirectories.
    mkdir .pioreactor
    mkdir .pioreactor/storage .pioreactor/plugins .pioreactor/exportable_datasets
  5. The configuration file that is used is config.dev.ini, and is provided in the repository. Move this to .pioreactor/.
MQTT​
You will need to install MQTT and have a broker running locally. On OSX, homebrew can be used to install the MQTT broker mosquitto. On Windows, it can be installed from this download page.
The mosquitto broker should be running whenever you invoke the Pioreactor software locally, else you'll likely get some connection refused error.
The CLI tools mosquitto_pub and mosquitto_sub should work as well.
Running jobs locally​
With pio
TESTING=1 pio run <job name>
You can also modify to hostname and experiment with
TESTING=1 \
HOSTNAME=<whatever> \
EXPERIMENT=<up to you> \
pio run <job name>
With python
TESTING=1 python <your script>.py
TESTING=1 \
If invoking from a different directory from pioreactor/, you'll need to have a config.dev.ini file locally. I usually copy my pioreactor/config.dev.ini to wherever I am working. Or you can use an environment argument GLOBAL_CONFIG=./config.dev.ini pio ...
Testing​
pytest core/tests
Plugins development​
Create a folder in the pioreactor folder called plugins_dev. In this folder, you can place python files that will run whenever pio is invoked (similar to the plugins folder at .pioreactor/plugins on the Raspberry Pi, see docs here)
Raspberry Pi Images​
Raspberry Pi images are built in the Pioreactor/CustoPiZer repo. Nightly builds are available at nightly.pioreactor.com.
