Another example writing a new automation
Let's design a simple LED automation for Light/Dark cycles. The basic idea is that the LED automation applies the current light or dark phase, then schedules the next phase boundary. This is different from a periodic dosing automation: there is no global duration loop for every automation anymore. Each automation chooses its own trigger model.
The Code​
  1. Imports at the top of the file!
# -*- coding: utf-8 -*-
from __future__ import annotations
from threading import Timer
from pioreactor.automations import events
from pioreactor.automations.led.base import LEDAutomationJobContrib
from pioreactor.types import LedChannel
from pioreactor.utils.timing import current_utc_datetime
  1. Define a new class as a subclass of LEDAutomationJobContrib. We use LEDAutomationJobContrib since this is a 3rd party automation. We give the new class a descriptive name. The automation_name attribute is necessary - and is often just the snake case version of the class name.
class LightDarkCycle(LEDAutomationJobContrib):
automation_name = "light_dark_cycle"
  1. Define our published_settings for this class. This is a dictionary of attributes that we can modify or inspect from MQTT, and hence from the UI or from the leader Pioreactor. Only include settings that users may want to inspect or modify mid-experiment.
published_settings = {
"light_intensity": {"datatype": "float", "settable": True, "unit": "%"},
"light_duration_minutes": {"datatype": "float", "settable": True, "unit": "min"},
"dark_duration_minutes": {"datatype": "float", "settable": True, "unit": "min"},
  1. Create the __init__, with the attributes we'll need.
def __init__(
self,
light_intensity: float | str,
light_duration_minutes: float | str,
dark_duration_minutes: float | str,
**kwargs,
super().__init__(**kwargs)
self._cycle_started_at = current_utc_datetime()
self._phase_timer: Timer | None = None
self.light_active = False
self.channels: tuple[LedChannel, ...] = ("D", "C")
self.set_light_intensity(light_intensity)
self.light_duration_minutes = float(light_duration_minutes)
self.dark_duration_minutes = float(dark_duration_minutes)
self._automation_strategy_start_callback = self._start_phase_schedule
  • _cycle_started_at anchors the light/dark cycle.
  • _phase_timer stores the pending timer for the next phase boundary.
  • light_active keeps track of whether the LEDs are currently on or off.
  • channels refers to which LED channels on the Pioreactor HAT we are using.
  • light_duration_minutes: the number of minutes to keep the light on.
  • dark_duration_minutes: the number of minutes to keep the light off.
  • light_intensity: the level of intensity, as a percent, of the LEDs when turned on.
_automation_strategy_start_callback tells the base automation runtime what should start once the job is fully initialized. For periodic automations, this is usually handled by self.run_every(...). For this phase-based automation, we install our own callback instead.
  1. Define execute. It calculates where we are in the cycle and delegates to trigger_leds.
def execute(self):
elapsed_minutes = (current_utc_datetime() - self._cycle_started_at).total_seconds() / 60
return self.trigger_leds(elapsed_minutes)
The other class function, trigger_leds, role is to:
  1. determine if we should turn on LEDs, turn off LEDs, or do nothing.
  2. if we are changing LED status, perform that task.
  3. return an Event when something changed, or None when there is no change.
To decide the phase, we think about total minutes passed modulo how long our cycle is. If our cycle lasts 24 hours (which is 1440 minutes), then minute 1500 is really minute 60 in the next cycle.
def trigger_leds(self, elapsed_minutes: float):
if self.light_duration_minutes <= 0:
light_should_be_on = False
elif self.dark_duration_minutes <= 0:
light_should_be_on = True
else:
cycle_duration_minutes = self.light_duration_minutes + self.dark_duration_minutes
light_should_be_on = (elapsed_minutes % cycle_duration_minutes) < self.light_duration_minutes
if light_should_be_on == self.light_active:
return None
self.light_active = light_should_be_on
intensity = self.light_intensity if light_should_be_on else 0
for channel in self.channels:
self.set_led_intensity(channel, intensity)
action = "on" if light_should_be_on else "off"
return events.ChangedLedIntensity(f"{elapsed_minutes:.1f}min: turned {action} LEDs.")
We also need to define set_light_intensity. This function is automatically called whenever we change light_intensity (see note below). We need additional logic to immediately change the light_intensity when asked, otherwise the LEDs would not update until the next phase callback.
def set_light_intensity(self, intensity: float | str):
self.light_intensity = float(intensity)
if self.light_active:
self.set_led_intensity(channel, self.light_intensity)
Updates over MQTT either update the attribute directly, i.e. self.<attr> = new_value, or, if defined, the method set_<attr>(new_value) is called instead. This is what is happening with set_light_intensity. Using set_<attr> methods is useful when you have additional logic that needs to be accomplished when an attribute changes.
Finally, we schedule the next phase boundary. run_once(wait_for_ready=False) is preferred over calling execute() directly because it handles shared automation bookkeeping like state checks, non-overlap, event logging, and latest_event.
def _start_phase_schedule(self):
self._run_and_schedule_next_phase()
def _run_and_schedule_next_phase(self):
self.run_once(wait_for_ready=False)
self._schedule_next_phase_boundary()
def _seconds_until_next_phase_boundary(self):
if self.light_duration_minutes <= 0 or self.dark_duration_minutes <= 0:
return None
position_minutes = elapsed_minutes % cycle_duration_minutes
if position_minutes < self.light_duration_minutes:
next_boundary_minutes = self.light_duration_minutes
else:
next_boundary_minutes = cycle_duration_minutes
return max((next_boundary_minutes - position_minutes) * 60, 0.05)
def _schedule_next_phase_boundary(self):
self._cancel_phase_timer()
seconds_until_boundary = self._seconds_until_next_phase_boundary()
if seconds_until_boundary is None or self.state != self.READY:
return
self._phase_timer = Timer(seconds_until_boundary, self._run_and_schedule_next_phase)
self._phase_timer.daemon = True
self._phase_timer.start()
def _cancel_phase_timer(self):
if self._phase_timer is not None:
self._phase_timer.cancel()
self._phase_timer = None
When settings that affect the schedule change, recompute the current phase and reschedule the next boundary:
def set_dark_duration_minutes(self, minutes: float):
self.dark_duration_minutes = float(minutes)
def set_light_duration_minutes(self, minutes: float):
self.light_duration_minutes = float(minutes)
And cancel any pending timer when the automation sleeps or disconnects:
def on_sleeping(self):
super().on_sleeping()
def on_sleeping_to_ready(self):
super().on_sleeping_to_ready()
def on_disconnected(self):
super().on_disconnected()
That's the end of the class! In total, our file looks like:
Follows a light / dark cycle. Starts with the light phase.
def __init__(
self,
**kwargs,
def execute(self):
else:
return None
return None
else:
return
Setting up the Pioreactor​
Setting up your Pioreactor is easy: attach LEDs to LED channels D and C, and stick them in pockets X2 and X3.
Running the automation​
Let's save this file to our Pioreactor plugin folder, by accessing the Pioreactor's command line, typing nano ~/.pioreactor/plugins/light_dark_cycle.py, and pasting in the code above.
You can test the automation from the Pioreactor's command line by executing:
pio run led_automation --automation-name light_dark_cycle --light-intensity 45 --light-duration-minutes 960 --dark-duration-minutes 480
Adding the automation to the UI​
To add your automation to the UI so it appears in the automation drop-down, follow the the steps here.
