Introduction
The Pioreactor has a few different ways to store data (depending on the requirements). They are:
SQLite3​
The most important datastore is the SQLite3 database on the leader, located at /home/pioreactor/.pioreactor/storage/. This database stores historical data, jobs changes, logs, experiments, etc. The background job mqtt_to_db_streaming picks up data from MQTT (like OD readings), and puts them into the database.
The CLI command pio db will open up the SQLite terminal to query the database directly.
Backups of the database​
The leader attempts to back up the SQLite database once a week. It stores the backup locally and, by default, attempts to copy it to as many as two reachable workers. The number of worker replicas is configurable with number_of_backup_replicates_to_workers under [storage].
Worker replication is best-effort. A backup can be skipped when the database is busy or storage is low, and an unavailable worker will not receive a copy. If the leader's microSD card fails, check the timestamps of any worker copies before using one for recovery.
Local key-value datastore​
SQLite3 is also used for simpler database (caches) on each Pioreactor (worker and leader). The persistent databases are stored in /home/pioreactor/.pioreactor/storage and the temporary databases are in /run/pioreactor/cache. You can access them from Python using pioreactor.utils.local_persistent_storage and pioreactor.utils.local_intermittent_storage, respectively.
What are temporary and persistent? Something like GPIO locks or LED state are physically reset between cycles of the Raspberry Pi. So when the Pi power-cycles, the state is wiped, and by have the database in /tmp, the databases are wiped as well.
You can use pio cache view <name> to view the contents of <name>, and pio cache purge <name> <key> to clear contents.
MQTT​
The inter- and intra-Pioreactor communications are handled by MQTT, a pub/sub service. The MQTT broker is on the leader Pioreactor (pio mqtt will stream the latest messages to your terminal). MQTT is used to transfer data between workers and leader, and even between process on the workers (ex: OD readings are created on worker, send to leader, and then sent back to worker's growth_rate_calculating job. This does create minor latency, and certainly more risk of data loss, but simplifies the design of the system overall).
A principle we have stood by is to not let MQTT turn into our database. That is,
  1. we shouldn't store important information in MQTT only (also use mqtt_to_db_streaming job to store important data in the SQLite3 database, or handle it locally using local_intermittent_storage or local_persistent_storage),
  2. we shouldn't store information in MQTT that is "machine-specific", like calibrations (better to use local_intermittent_storage or local_persistent_storage)
  3. we shouldn't use MQTT as a source of truth (trust the database, local_intermittent_storage or local_persistent_storage more).
Serialization of MQTT messages​
We make a configuration change so MQTT data is not persisted through leader power-cycles.
Authentication​
The Mosquitto broker has a username/password of pioreactor / raspberry.
