I2C addresses
Pioreactor hardware uses the Raspberry Pi's I2C bus on GPIO2 (SDA) and GPIO3 (SCL). Device addresses are defined in the hardware YAML profiles under ~/.pioreactor/hardware/, not hard-coded into plugins or jobs.
The hardware loader layers files in this order:
  1. ~/.pioreactor/hardware/hats/<hat_version>/<mod>.yaml
  2. ~/.pioreactor/hardware/models/<model_name>/<model_version>/<mod>.yaml
Model files override HAT files. This matters most for optical density ADCs: a HAT can provide default ADC wiring, while a model can replace the pd1 and pd2 entries with model-specific optics.
Bundled defaults​
These are the I2C addresses in the bundled hardware profiles.
Hardware profileDeviceAddressDefined in
HAT 1.0ADS1115 ADC (aux, version, pd1, pd2)0x48hats/1.0/adc.yaml
HAT 1.0DAC0x49hats/1.0/dac.yaml
HAT 1.0Heating PCB temperature sensor0x4Fhats/1.0/temp.yaml
HAT 1.1RP2040 / Pico ADC and DAC0x2Chats/1.1/adc.yaml, hats/1.1/dac.yaml
HAT 1.1Heating PCB temperature sensor0x4Fhats/1.1/temp.yaml
HAT 1.2RP2040 / Pico ADC and DAC0x2Chats/1.2/adc.yaml, hats/1.2/dac.yaml
HAT 1.2Heating PCB temperature sensor0x4Fhats/1.2/temp.yaml
Pioreactor 20 mL model 1.5Optical density ADC pd10x48models/pioreactor_20ml/1.5/adc.yaml
Pioreactor 20 mL model 1.5Optical density ADC pd20x49models/pioreactor_20ml/1.5/adc.yaml
Pioreactor 40 mL model 1.5Optical density ADC pd10x48models/pioreactor_40ml/1.5/adc.yaml
Pioreactor 40 mL model 1.5Optical density ADC pd20x49models/pioreactor_40ml/1.5/adc.yaml
Common STEMMA QT hardware​
These addresses are for the third-party devices listed on Verified Stemma QT hardware we like. They do not conflict with the bundled Pioreactor addresses above, but two devices with the same address cannot share the bus unless one device supports changing its address or you add an I2C multiplexer.
DeviceDefault addressAlternate addressesNotes
Adafruit MLX90632 FIR Remote Thermal Temperature Sensor0x3A0x3BThe address can be changed with the ADDR / A0 jumper.
Adafruit AS7341 10-Channel Light / Color Sensor0x39NoneFixed address.
Monochrome 1.3" 128x64 OLED Graphic Display0x3C0x3DSelectable with the address jumper.
Adafruit SCD-30 NDIR CO2 Temperature and Humidity Sensor0x61NoneFixed address.
Reading addresses from Python​
Use pioreactor.hardware instead of duplicating addresses in your code:
from pioreactor import hardware
temp_address = hardware.get_temp_address()
dac_address = hardware.get_dac_address()
adc_curriers = hardware.get_adc_curriers()
for channel, currier in adc_curriers.items():
print(channel, hex(currier.i2c_address), currier.adc_channel)
This keeps plugins compatible with custom HAT and model profiles.
Checking the live bus​
To check whether a configured device is present, use the helper that Pioreactor uses internally:
from pioreactor.hardware import get_temp_address, is_i2c_device_present
if is_i2c_device_present(get_temp_address()):
print("Heating PCB temperature sensor detected")
For broader hardware customization, see Customize the hardware interface.
