User interface
I'm not able to access http://pioreactor.local
- In your browser's address bar, add the
http://infront of the url, like so:http://pioreactor.local. - The UI is hosted on http, not http_s_. Check if you are accessing
http://pioreactor.local, and nothttps://pioreactor.local. - Try accessing using the url
http://<the permanent name of your Pioreactor aka hostname>.local - If you know your Raspberry Pi's IP, try
http://<IP address of your Raspberry Pi>. Here's information to determine the IP address - On macOS, if your browser shows
ERR_ADDRESS_UNREACHABLE, check System Settings > Privacy & Security > Local Network and make sure your browser is allowed to access devices on the local network. If it is already allowed, try toggling the permission off and on. - Errors during installation:
- When pressing the button on the HAT, does the blue LED show up? If not, installation may have failed. See notes here.
- In your Raspberry Pi Imager settings, confirm that you clicked "Set username and password", and used the username
pioreactor. If not, try reinstalling the image.
- Are you on an older Windows machine? You may need to install a DNS service, but also see workarounds here.
- Try SSHing in and restarting the webserver:
sudo systemctl restart lighttpd.service && sudo systemctl status lighttpd.service.
No information is shown on the Inventory page / no green dot / no response when I click some buttons.
See question below.
I see "Failed to connect to MQTT. ..." in a pop-up - what can I do?
This error likely occurs because your browser can't connect to an internal system, MQTT, that is used for displaying data and actions. Possibly you also weren't able to access the UI with http://pioreactor.local, but had to use an IP address as the url.
To fix this:
- Navigate to the Configuration page in the side bar.
- Find the
[mqtt]section, and change thebroker_addressconfiguration to your Pioreactor's IP. Ex:
[mqtt]
broker_address=192.168.0.10
Your IP may be different than the one above.
- Hit
Save. - Power-cycle the Pioreactor by rebooting it from the Inventory page.
Another reason might be that your institution's firewall is blocking port 9001. Ask your IT department about this. The web UI requires port 80 and port 9001 open to use.
If you are using a remote access service, like tailscale
Likely you didn't fill out the mqtt broker_address parameter in the configuration correctly. See the Tailscale instructions again.
When I click an action in the UI, I don't see any response. Or the button just spins and does nothing.
Any of the following could solve your problem:
- Is there a green icon in the top-left of the Pioreactor card? If not, or it's grey, either the Pioreactor is powered off, or the
monitorjob is not running. If so, try power-cycling the Pioreactor.
- It's possible that the experiment has changed while the page has been left open - try refreshing the page and try again.
- If you had trouble accessing the UI (see question above), in your config.ini, change the
leader_addressfield to whatever worked above, an IP for example. - Possibly the web server is off. Try logging into your leader and typing
sudo systemctl status lighttpd.service - Do you also see a "Failed to connect to MQTT. Is configuration for leader_address correct?" error pop-up? If so, see question above.
- Try power-cycling the Pioreactor.
