More about local storage on the Pioreactor
How do I write and read from the local storage?​
Here's an example:
from pioreactor.utils import local_intermittent_storage, local_peristant_storage
with local_intermittent_storage("my_namespace") as cache:
cache['key'] = "value"
print(cache['key'])
cache.get("retrieval_key")
with local_peristant_storage("my_other_namespace") as cache:
print(cache['key'])
assert cache.get("retrieval_key") is None
You can use pio cache view <name> to view the contents of <name>, and pio cache purge <name> <key> to clear contents.
What's the difference between local_intermittent_storage and local_peristent_storage?​
local_intermittent_storage is data that won't, or shouldn't, exist after a reboot. For example: the state of GPIO pins. At a hardware level, this is reset after each reboot, and so should data associated with it.
Whereas local_peristant_storage is data that should exist between reboots. This is data like some calibration data, or OD blank data.
