Important Raspberry Pi Locations for Pioreactor Images
Reference list of on-device paths that matter once a custom Pioreactor Raspberry Pi OS image is flashed and running. To prepare configuration, plugins, and supported files on an SD card before booting, see Provisioning images.
| Path | What lives here | Notes |
/etc/pioreactor.env | Shared environment file exported to services | Provides canonical DOT_PIOREACTOR, RUN_PIOREACTOR, LG_WD, and virtualenv paths so systemd units pick up the same locations. |
/home/pioreactor/.pioreactor/ | Pioreactor home ($DOT_PIOREACTOR) | Contains configs, plugins, storage, hardware definitions, logs, and other per-device state. Ensure ownership stays pioreactor:pioreactor. |
/home/pioreactor/.pioreactor/config.ini | Cluster-wide configuration | Holds network, MQTT, UI, logging, and automation settings replicated to workers. |
/home/pioreactor/.pioreactor/unit_config.ini | Unit overrides | Optional per-device overrides synced from the leader when a worker is added. |
/home/pioreactor/.pioreactor/plugins/ | Plugin root | Mirrors the .pioreactor layout for plugin-provided files; typically subdivided into python/, ui/, exportable_datasets/, etc. |
/home/pioreactor/.pioreactor/plugins/ui/ | UI plugin assets | Static contrib YAML, templates, and other UI resources merged into the Pioreactor UI. |
/home/pioreactor/.pioreactor/plugins/exportable_datasets/ | Exportable dataset plugins | Each plugin ships SQL queries or serializers that surface new datasets to the UI. |
/home/pioreactor/.pioreactor/storage/ | Persistent databases | Holds SQLite data such as pioreactor.sqlite (experiments) and local_persistent_pioreactor_metadata.sqlite. |
/home/pioreactor/.pioreactor/storage/pioreactor.sqlite | Primary experiment database | Used by the leader, replicated to workers for durability. Back up before major upgrades. |
/home/pioreactor/.pioreactor/storage/local_persistent_pioreactor_metadata.sqlite | Persistent cache | Stores long-lived metadata that survives reboots. |
/home/pioreactor/.pioreactor/hardware/ | Hardware definition packs | YAML that describes hats, models, sensors, and calibration values consumed by the Pioreactor hardware subsystem. |
/home/pioreactor/.pioreactor/experiment_profiles/ | User experiment profiles | Drop .yaml / .yml profile definitions here so they show up in the UI for scheduling. |
/home/pioreactor/.ssh/ | Device SSH keys | Created during image build so leaders can add workers securely. |
/run/pioreactor/ | Runtime scratch space ($RUN_PIOREACTOR) | tmpfs directory for caches, sockets, Huey queues, and general runtime coordination. Cleared on reboot. |
/run/pioreactor/cache/ | Volatile caches | Includes local_intermittent_pioreactor_metadata.sqlite and UI/Huey cache files that can be safely discarded. |
/run/pioreactor/exports/ | Web export staging | Lighttpd serves /exports/ from here. By default this is volatile staging under /run; set PIO_EXPORTS_DIR in pioreactor.env to use a persistent directory symlinked to this path. |
/var/log/pioreactor.log | System log for Pioreactor services | Configured via config.ini and read by both CLI and UI. Rotate with journald/logrotate as needed. |
/opt/pioreactor/venv/ | System Python virtual environment | Hosts the Pioreactor Python installation (pio, pios, services). Activate manually for debugging. |
/tmp/ | Temporary workspace | Referenced by TMPDIR in pioreactor.env for short-lived files outside tmpfs. |
