LED automations
LED automations are ways to automatically control the 4 available LEDs in the Pioreactor. These LEDs can be used as a light source for photosynthetic microbes, influence the environment of the microbes, as additional sensors, or improve existing sensors.
For continuous light (always-on LEDs), set the intensity using the manual LED controls. Stop any LED automation that would change that intensity. OD measurements can briefly turn other LEDs off, so this does not guarantee uninterrupted illumination.
Available LED automations​
Silent​
Requires: None
The silent automation is the simplest automation: doing nothing. It does not schedule LED actions.
Light/Dark cycle​
Requires: up to 2 LEDs, in channels C and D.
This automation will turn the LEDs in channels C & D on and off on a predetermined schedule, specified by light_duration_minutes and dark_duration_minutes. The intensity of the LED is given by light_intensity. The LEDs start ON. The automation schedules each light/dark boundary directly, so there is no duration field.
LED intensity starts at the configured light intensity, alternates between light and dark phases, and repeats according to the configured phase durations.
The LEDs should go in pockets X2 and X3 on the Pioreactor.
If using the Light/Dark cycle on an older installation that does not yet show these fields, you can add the settings to be displayed in the UI by editing the following file on your leader:
nano ~/.pioreactor/ui/automations/led/light_dark_cycle.yaml
And using the following field definitions:
- key: light_intensity
type: numeric
unit: "%"
label: Light ON intensity
description: The intensity when light is ON.
- key: light_duration_minutes
type: numeric
unit: min
label: "Light ON for"
description: How long should the light be ON for?
- key: dark_duration_minutes
type: numeric
unit: min
label: "Light OFF for"
description: How long should the light be OFF for?
Save and exit, and refresh the UI.
