Dosing automations
When pairing the Pioreactor with dosing pumps, there are new capabilities and experiments you can run. The Pioreactor is pre-programmed with the following dosing automations. In the below automations, values highlighted like so are configurable.
Before starting a dosing automation from the UI, review the Current volume and Efflux tube level fields in the automation dialog. Current volume should match the liquid currently in the vial, and Efflux tube level should match the volume set by the height of your waste / efflux tube.
Pausing a dosing automation cancels the remainder of the current dose. Resuming does not finish that old dose; future doses use fresh readings.
Available dosing automations
Silent
Requires: None
The silent automation is the simplest automation: doing nothing. It does not schedule pump actions.
Chemostat
Requires:
2 peristaltic pumps:
- one media pump
- one waste pump
2 liquid containers with luer attachments
- one labelled "waste"
- one labelled "media"
The chemostat automation is the second simplest dosing automation. Every duration minutes, the media and waste pumps run and exchange exchange volume (mL) of liquid inside the Pioreactor. You can also choose Skip first run to wait one full interval before the first exchange. Initially, the culture is growing and consuming nutrients and energy. Eventually, a nutrient will become scarce and will stall growing. Upon a pump refresh, this growth-limiting nutrient becomes abundant once again, and the culture can grow, up until consuming all of it again and stalling growth. Thus, the bioreactor enters into a nutrient near-equilibrium (hence the term "chemostat", for "chemical-static"). However, more long-term, because the culture is under an evolutionary pressure to grow, adaptions will occur that will improve the acquisition or utilization of the growth-limiting nutrient.
Turbidostat
Requires:
- one media pump
- one waste pump
A turbidostat ("turbidity-static") tries to keep the biomass constant over time. It reacts to fresh updates from the selected biomass signal, and performs a set media / waste pump cycle if the value exceeds the target biomass. The amount exchanged each time is the exchange volume parameter (mL). For very fast growing cultures, we recommend an exchange volume between 1.0 mL and 2.0 mL.
This automation will always move the full exchange volume, even if it's not enough for the measured biomass to drop below the target biomass. If that happens, the automation can trigger again after another fresh biomass update. After each exchange, Turbidostat waits briefly before reacting again so post-dilution readings have time to settle.
The current turbidostat fields in the UI are:
exchange volume: how much media and waste to move in each dilution cycle, in mL.target biomass: the biomass threshold that triggers a dilution cycle.biomass signal: which biomass estimate to monitor. The UI defaults this toauto.
When biomass signal is set to:
normalized_od: the automation compares against normalized OD.od_fused: the automation compares against the fused OD estimator.od: the automation compares against calibrated OD from the resolved OD channel.auto: the automation chooses the most specific available signal automatically.
When biomass signal is auto, the selection order is:
od_fused, when an activeod_fusedestimator is available.od, when an active OD calibration is available for the resolved photodiode angle.normalized_od, when neither of the above is available.
Overriding the biomass signal
Most users can leave the UI default at auto. Override it only when you want to force Turbidostat to use a specific biomass estimate.
To set a persistent default in config.ini, use the per-automation section:
[dosing_automation.turbidostat]
biomass_signal=od_fused
PID Morbidostat
Requires:
3 peristaltic pumps:
- one media pump
- one waste pump
- one alt media pump
3 liquid containers with luer attachments
- one labelled "alt media"
By introducing another pump (labelled "alt media"), another dimension of experiments opens up. We can exploit the short-time scale of adaption in microbes to evolve the culture from thriving in the original media to thriving in the alternative media, or some point in between the two. Think of it as slowly shifting the environment between the two media stocks so that the microbes are under constant evolutionary pressure. This is where the name morbidostat is from: "morbid-static".
In the Pioreactor software, the transition between environments is controlled by observing the growth rate, and artificially keeping it suppressed (set to be target growth rate) by dynamically adjusting the ratio between the original media and the alternative media when a pump cycle is run. A pump cycle is run every duration minutes, and Skip first run can delay the first cycle by one interval. Another parameter is the target OD, which should be low to keep the culture in a state of nutrient abundance (so that the primary evolutionary pressure is the alternative media adaptation).
Fed batch
Requires:
- 1 peristaltic pump
- A source and sink, with the pump in-between.
This automation moves a preset dosing volume every duration minutes using a pump. Skip first run can delay the first dose by one interval. You choose the start and end points of the tube!
Useful information for all dosing automations
How does the vial maintain a constant volume throughout operation?
When liquid is added, say 1ml, the volume rises an additional 1ml. Then 1ml of liquid is removed via efflux, but then the efflux pump runs again for an additional few seconds. The efflux pump is run for an additional few seconds to eliminate any volume deltas (for example, if the volume added is greater than the volume removed due to pumping errors). Otherwise, the deltas accumulate and the vial can overflow. This additional step helps guarantee that that volume of liquid never exceeds the end of the efflux tube. See waste_removal_multiplier parameter below.
Why does my influx pump only partially add the amount of liquid required? What are subdoses?
To further avoid overflow, we limit how much liquid is added in a single pump cycle. If the amount of liquid to be added is greater than the configuration parameter max_subdose, then the liquid is divided into smaller doses (halved until those new doses are less than max_subdose parameter), with the waste-pump run in between to avoid overflow. These small doses are called subdoses. You can change the maximum subdose value with the parameter max_subdose, see below.
Volume parameters
- Current volume: this is how much liquid is currently in the vial when you start the automation.
- Efflux tube level: the efflux tube's position determines the maximum volume your liquid volume will reach.
Configuration parameters
You can edit these parameters in your config.ini files. For dosing runs started from the UI, Current volume and Efflux tube level can also be adjusted directly in the automation dialog before starting.
Section [dosing_automation.config]
pause_between_subdoses_seconds: time to wait between doses - this is useful if you want to be sure the newly added liquid is sufficiently mixed before running the waste pump.waste_removal_multiplier: the amount of additional time to run the waste pump after the influx pump has run. This is to ensure that the volume of liquid in the vial never exceeds the end of the efflux tube. Ex: if media ran for0.75seconds, then the waste will run forwaste_removal_multiplier * 0.75 secondsmax_subdose: the maximum volume to add in a single dose. If the volume to add is greater than this value, the volume will be divided into smaller doses.
Section [dosing_automation.turbidostat]
biomass_signal: the default biomass signal used by Turbidostat when you don't pass an explicit per-run value. Valid values areauto,normalized_od,od_fused, andod.
Section [bioreactor]
efflux_tube_volume_ml: determined by the volume that just touches the outflow tube. I.e. if you were to keep running the waste pump, what would the stable volume be. Default 14.initial_volume_ml: the initial volume of liquid in the vial. In the UI this is surfaced asCurrent volume, and is used to calculate the volume of liquid in the vial at any given time. Default 14.initial_alt_media_fraction: the initial fraction of the alternative media in the vial. This is used to calculate the volume of alternative media in the vial at any given time. Default 0.initial_cumulative_media_added_ml: the initial volume of media that has been moved by the pumps. (Useful for tracking media in a source vessel). Default 0.initial_cumulative_alt_media_added_ml: Seeinitial_cumulative_media_added_mlabove. Default 0.initial_cumulative_waste_removed_ml: The initial volume of waste that has been removed. Default 0.
