API
All endpoints
In most cases, where you see <pioreactor_unit>, you can use the key $broadcast to send the command to all units.
Endpoint Methods Rule
api.get_configs GET /api/configs
api.get_config GET /api/configs/<filename>
api.update_config PATCH /api/configs/<filename>
api.get_historical_config_for GET /api/configs/<filename>/history
api.get_automation_contrib GET /api/contrib/automations/<automation_type>
api.get_charts_contrib GET /api/contrib/charts
api.create_experiment_profile POST /api/contrib/experiment_profiles
api.update_experiment_profile PATCH /api/contrib/experiment_profiles
api.get_experiment_profiles GET /api/contrib/experiment_profiles
api.get_experiment_profile GET /api/contrib/experiment_profiles/<filename>
api.delete_experiment_profile DELETE /api/contrib/experiment_profiles/<filename>
api.get_exportable_datasets GET /api/contrib/exportable_datasets
api.preview_exportable_datasets GET /api/contrib/exportable_datasets/<target_dataset>/preview
api.export_datasets POST /api/contrib/exportable_datasets/export_datasets
api.get_job_contrib GET /api/contrib/jobs
api.get_running_profiles GET /api/experiment_profiles/running/experiments/<experiment>
api.get_experiments GET /api/experiments
api.create_experiment POST /api/experiments
api.delete_experiment DELETE /api/experiments/<experiment>
api.update_experiment PATCH /api/experiments/<experiment>
api.get_experiment GET /api/experiments/<experiment>
api.get_list_of_historical_workers_for_experiment GET /api/experiments/<experiment>/historical_worker_assignments
api.get_exp_logs GET /api/experiments/<experiment>/logs
api.get_media_rates GET /api/experiments/<experiment>/media_rates
api.get_recent_logs GET /api/experiments/<experiment>/recent_logs
api.get_fallback_time_series GET /api/experiments/<experiment>/time_series/<data_source>/<column>
api.get_growth_rates GET /api/experiments/<experiment>/time_series/growth_rates
api.get_od_readings GET /api/experiments/<experiment>/time_series/od_readings
api.get_od_readings_filtered GET /api/experiments/<experiment>/time_series/od_readings_filtered
api.get_od_raw_readings GET /api/experiments/<experiment>/time_series/raw_od_readings
api.get_temperature_readings GET /api/experiments/<experiment>/time_series/temperature_readings
api.get_unit_labels GET /api/experiments/<experiment>/unit_labels
api.upsert_unit_labels PATCH, PUT /api/experiments/<experiment>/unit_labels
api.get_list_of_workers_for_experiment GET /api/experiments/<experiment>/workers
api.add_worker_to_experiment PUT /api/experiments/<experiment>/workers
api.remove_workers_from_experiment DELETE /api/experiments/<experiment>/workers
api.remove_worker_from_experiment DELETE /api/experiments/<experiment>/workers/<pioreactor_unit>
api.get_active_experiments GET /api/experiments/active
api.get_experiments_worker_assignments GET /api/experiments/assignment_count
api.get_latest_experiment GET /api/experiments/latest
api.get_historical_media_used GET /api/historical_media
api.get_historical_organisms_used GET /api/historical_organisms
api.is_local_access_point_active GET /api/is_local_access_point_active
api.get_logs GET /api/logs
api.get_models GET /api/models
api.update_app_from_release_archive POST /api/system/update_from_archive
api.update_app POST /api/system/update_next_version
api.upload POST /api/system/upload
api.set_clocktime POST /api/system/utc_clock
api.get_list_of_units GET /api/units
api.get_capabilities GET /api/units/<pioreactor_unit>/capabilities
api.get_configuration_for_pioreactor_unit GET /api/units/<pioreactor_unit>/configuration
api.publish_new_log POST /api/units/<pioreactor_unit>/experiments/<experiment>/logs
api.run_job_on_unit_in_experiment PATCH, POST /api/units/<pioreactor_unit>/jobs/run/job_name/<job>/experiments/<experiment>
api.get_jobs_running GET /api/units/<pioreactor_unit>/jobs/running
api.stop_specific_job_on_unit PATCH, POST /api/units/<pioreactor_unit>/jobs/stop/job_name/<job_name>/experiments/<experiment>
api.update_job_on_unit PATCH /api/units/<pioreactor_unit>/jobs/update/job_name/<job>/experiments/<experiment>
api.get_logs_for_unit GET /api/units/<pioreactor_unit>/logs
api.install_plugin_across_cluster PATCH, POST /api/units/<pioreactor_unit>/plugins/install
api.get_plugins_on_machine GET /api/units/<pioreactor_unit>/plugins/installed
api.uninstall_plugin_across_cluster PATCH, POST /api/units/<pioreactor_unit>/plugins/uninstall
api.reboot_unit POST /api/units/<pioreactor_unit>/system/reboot
api.shutdown_unit POST /api/units/<pioreactor_unit>/system/shutdown
api.get_clocktime GET /api/units/<pioreactor_unit>/system/utc_clock
api.get_system_logs_for_unit GET /api/units/<pioreactor_unit>/system_logs
api.get_app_versions GET /api/units/<pioreactor_unit>/versions/app
api.get_ui_versions_across_cluster GET /api/units/<pioreactor_unit>/versions/ui
api.get_list_of_workers GET /api/workers
api.add_worker PUT /api/workers
api.delete_worker DELETE /api/workers/<pioreactor_unit>
api.get_worker GET /api/workers/<pioreactor_unit>
api.get_all_active_calibrations GET /api/workers/<pioreactor_unit>/active_calibrations
api.remove_active_status_calibration DELETE /api/workers/<pioreactor_unit>/active_calibrations/<device>
api.set_active_calibration PATCH /api/workers/<pioreactor_unit>/active_calibrations/<device>/<cal_name>
api.blink_worker POST /api/workers/<pioreactor_unit>/blink
api.get_all_calibrations GET /api/workers/<pioreactor_unit>/calibrations
api.get_calibrations GET /api/workers/<pioreactor_unit>/calibrations/<device>
api.create_calibration POST /api/workers/<pioreactor_unit>/calibrations/<device>
api.get_calibration GET /api/workers/<pioreactor_unit>/calibrations/<device>/<cal_name>
api.delete_calibration DELETE /api/workers/<pioreactor_unit>/calibrations/<device>/<cal_name>
api.get_capabilities GET /api/workers/<pioreactor_unit>/capabilities
api.get_configuration_for_pioreactor_unit GET /api/workers/<pioreactor_unit>/configuration
api.get_experiment_assignment_for_worker GET /api/workers/<pioreactor_unit>/experiment
api.get_logs_for_unit_and_experiment GET /api/workers/<pioreactor_unit>/experiments/<experiment>/logs
api.publish_new_log POST /api/workers/<pioreactor_unit>/experiments/<experiment>/logs
api.get_recent_logs_for_unit_and_experiment GET /api/workers/<pioreactor_unit>/experiments/<experiment>/recent_logs
api.get_fallback_time_series_per_unit GET /api/workers/<pioreactor_unit>/experiments/<experiment>/time_series/<data_source>/<column>
api.get_growth_rates_per_unit GET /api/workers/<pioreactor_unit>/experiments/<experiment>/time_series/growth_rates
api.get_od_readings_per_unit GET /api/workers/<pioreactor_unit>/experiments/<experiment>/time_series/od_readings
api.get_od_readings_filtered_per_unit GET /api/workers/<pioreactor_unit>/experiments/<experiment>/time_series/od_readings_filtered
api.get_od_raw_readings_per_unit GET /api/workers/<pioreactor_unit>/experiments/<experiment>/time_series/raw_od_readings
api.get_temperature_readings_per_unit GET /api/workers/<pioreactor_unit>/experiments/<experiment>/time_series/temperature_readings
api.change_worker_status PUT /api/workers/<pioreactor_unit>/is_active
api.run_job_on_unit_in_experiment PATCH, POST /api/workers/<pioreactor_unit>/jobs/run/job_name/<job>/experiments/<experiment>
api.get_jobs_running GET /api/workers/<pioreactor_unit>/jobs/running
api.get_job_settings_for_worker GET /api/workers/<pioreactor_unit>/jobs/settings/job_name/<job_name>/experiments/<experiment>
api.get_job_setting_for_worker GET /api/workers/<pioreactor_unit>/jobs/settings/job_name/<job_name>/setting/<setting>/experiments/<experiment>
api.stop_all_jobs_on_worker_for_experiment PATCH, POST /api/workers/<pioreactor_unit>/jobs/stop/experiments/<experiment>
api.stop_specific_job_on_unit PATCH, POST /api/workers/<pioreactor_unit>/jobs/stop/job_name/<job_name>/experiments/<experiment>
api.update_job_on_unit PATCH /api/workers/<pioreactor_unit>/jobs/update/job_name/<job>/experiments/<experiment>
api.change_worker_model PUT /api/workers/<pioreactor_unit>/model
api.get_worker_model_and_metadata GET /api/workers/<pioreactor_unit>/model
api.get_all_calibrations_as_yamls GET /api/workers/<pioreactor_unit>/zipped_calibrations
api.get_workers_and_experiment_assignments GET /api/workers/assignments
api.remove_all_workers_from_all_experiments DELETE /api/workers/assignments
api.discover_available_workers GET /api/workers/discover
api.setup_worker_pioreactor POST /api/workers/setup
mcp.handle_mcp POST /mcp/
static GET /static/<path:filename>
unit_api.get_all_active_calibrations GET /unit_api/active_calibrations
unit_api.remove_active_status_calibration DELETE /unit_api/active_calibrations/<device>
unit_api.set_active_calibration PATCH /unit_api/active_calibrations/<device>/<cal_name>
unit_api.get_all_calibrations GET /unit_api/calibrations
unit_api.create_calibration POST /unit_api/calibrations/<device>
unit_api.get_calibrations_by_device GET /unit_api/calibrations/<device>
unit_api.get_calibration GET /unit_api/calibrations/<device>/<cal_name>
unit_api.delete_calibration DELETE /unit_api/calibrations/<device>/<calibration_name>
unit_api.discover_jobs_and_settings_available GET /unit_api/capabilities
unit_api.run_job PATCH, POST /unit_api/jobs/run/job_name/<job>
unit_api.get_all_running_jobs GET /unit_api/jobs/running
unit_api.get_running_job GET /unit_api/jobs/running/<job>
unit_api.get_running_jobs_for_experiment GET /unit_api/jobs/running/experiments/<experiment>
unit_api.get_settings_for_a_specific_job GET /unit_api/jobs/settings/job_name/<job_name>
unit_api.update_job PATCH /unit_api/jobs/settings/job_name/<job_name>
unit_api.get_specific_setting_for_a_job GET /unit_api/jobs/settings/job_name/<job_name>/setting/<setting>
unit_api.stop_jobs PATCH, POST /unit_api/jobs/stop
unit_api.stop_all_jobs PATCH, POST /unit_api/jobs/stop/all
unit_api.get_all_long_running_jobs GET /unit_api/long_running_jobs/running
unit_api.install_plugin PATCH, POST /unit_api/plugins/install
unit_api.get_installed_plugins GET /unit_api/plugins/installed
unit_api.get_plugin GET /unit_api/plugins/installed/<filename>
unit_api.uninstall_plugin PATCH, POST /unit_api/plugins/uninstall
unit_api.dir_listing GET /unit_api/system/path/
unit_api.dir_listing GET /unit_api/system/path/<path:req_path>
unit_api.reboot PATCH, POST /unit_api/system/reboot
unit_api.remove_file PATCH, POST /unit_api/system/remove_file
unit_api.shutdown PATCH, POST /unit_api/system/shutdown
unit_api.update_app_and_ui PATCH, POST /unit_api/system/update
unit_api.update_target PATCH, POST /unit_api/system/update/<target>
unit_api.get_clock_time GET /unit_api/system/utc_clock
unit_api.set_clock_time PATCH, POST /unit_api/system/utc_clock
unit_api.task_status GET /unit_api/task_results/<task_id>
unit_api.get_app_version GET /unit_api/versions/app
unit_api.get_ui_version GET /unit_api/versions/ui
unit_api.get_all_calibrations_as_zipped_yaml GET /unit_api/zipped_calibrations
From python3 -m flask --debug --app main routes -s rule
