API Reference (Unit /unit_api)
Conventions
- All Pioreactors have the
/unit_apiendpoints exposed. - Async endpoints return
202 Acceptedwith atask_idandresult_url_path. - Poll
GET /unit_api/task_results/{task_id}untilstatusissucceededorfailed. - File download endpoints return binary bodies; use the response content-type to handle them.
- Path parameters are shown inline in the endpoint URL.
- Request/response examples are the canonical shapes; omit optional fields you do not need.
- Errors have the following schema:
"error": "Human-readable error message",
"cause": "Human-readable cause (defaults to error if not set)",
"remediation": "Suggested fix or next step",
"status": 400
Pioreactor Unit API
Generated from core/pioreactor/web/unit_api.py.
This file is generated. Edit the API source or generator instead of editing this file by hand.
Endpoint count: 100
Endpoint Index
Get Unit Active
Get Unit Active endpoint.
Endpoint
GET /unit_api/active
Response
Success
Status: 200 OK
Example body:
"is_active": 1
Set Unit Active
Set Unit Active endpoint.
Endpoint
PUT /unit_api/active
Request
Request Body
| Name | Type | Required | Description |
| is_active | integer | Yes | is active. |
"is_active": true
Response
Success
Status: 200 OK
No example body inferred.
Get All Active Calibrations
Get All Active Calibrations endpoint.
Endpoint
GET /unit_api/active_calibrations
Response
Success
Status: 200 OK
Example body:
Remove Active Status Calibration
Remove Active Status Calibration endpoint.
Endpoint
DELETE /unit_api/active_calibrations/{device}
Request
Path Parameters
| device | string | Yes | Target device name. |
Response
Success
Status: 200 OK
Example body:
"status": "success"
Set Active Calibration
Set Active Calibration endpoint.
Endpoint
PATCH /unit_api/active_calibrations/{device}/{calibration_name}
Request
Path Parameters
| calibration_name | string | Yes | Calibration name. |
Response
Success
Status: 200 OK
Example body:
"status": "success"
Get All Active Estimators
Get All Active Estimators endpoint.
Endpoint
GET /unit_api/active_estimators
Response
Success
Status: 200 OK
Example body:
Remove Active Status Estimator
Remove Active Status Estimator endpoint.
Endpoint
DELETE /unit_api/active_estimators/{device}
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
"status": "success"
Set Active Estimator
Set Active Estimator endpoint.
Endpoint
PATCH /unit_api/active_estimators/{device}/{estimator_name}
Request
Path Parameters
| estimator_name | string | Yes | Estimator name. |
Response
Success
Status: 200 OK
Example body:
"status": "success"
Get Automation Descriptors
Return this unit's automation UI descriptors for one automation family.
Endpoint
GET /unit_api/automations/descriptors/{automation_type}
Request
Path Parameters
| automation_type | string | Yes | Automation type, for example dosing, temperature, or led. |
Response
Success
Status: 200 OK
Example body:
"display_name": "Only record temperature",
"automation_name": "only_record_temperature",
"description": "Apply no heating, only record the temperature.",
"source": null,
"fields": []
"display_name": "Thermostat",
"automation_name": "thermostat",
"description": "Vary the amount of applied heating to keep the culture near a target temperature, using a control-loop.",
"source": null,
"fields": [
"key": "target_temperature",
"default": 30,
"label": "Target temperature",
"disabled": false,
"required": true,
"unit": "\u2103",
"type": "numeric",
"options": null
Get Bioreactor Values
Get Bioreactor Values endpoint.
Endpoint
GET /unit_api/bioreactor/experiments/{experiment}
Request
Path Parameters
| experiment | string | Yes | Experiment identifier. |
Response
Success
Status: 200 OK
Example body:
"values": {
"current_volume_ml": 14.0,
"efflux_tube_volume_ml": 14.0,
"alt_media_fraction": 0.0,
"cumulative_media_added_ml": 0.0,
"cumulative_alt_media_added_ml": 0.0,
"cumulative_waste_removed_ml": 0.0
Update Bioreactor Values
Update Bioreactor Values endpoint.
Endpoint
PATCH /unit_api/bioreactor/experiments/{experiment}
Request
Path Parameters
Request Body
| values | object | Yes | values. |
"values": {
"current_volume_ml": 12.5
Response
Success
Status: 200 OK
Example body:
"status": "success"
Get Calibration Protocols
Get Calibration Protocols endpoint.
Endpoint
GET /unit_api/calibration_protocols
Response
Success
Status: 200 OK
Example body:
"id": "alt_media_pump_duration_based",
"target_device": "alt_media_pump",
"protocol_name": "duration_based",
"priority": 99,
"title": "Duration-based pump calibration",
"description": "Build a duration-to-volume curve for the alt media pump using a simple multi-step flow.",
"requirements": [
"DC Peristaltic pump assigned to alt media pump",
"Pioreactor vial",
"Container of clean water"
"id": "camera_manual_focus",
"target_device": "camera",
"protocol_name": "manual_focus",
"priority": 99,
"title": "Manual camera focus",
"description": "Capture still images while manually adjusting the camera's focus.",
"requirements": [
"Camera connected",
"Detailed focus target near the intended vial position",
"Physical access to the camera focus control"
"id": "media_pump_duration_based",
"target_device": "media_pump",
"priority": 99,
"description": "Build a duration-to-volume curve for the media pump using a simple multi-step flow.",
"requirements": [
"DC Peristaltic pump assigned to media pump",
"Pioreactor vial",
Get All Calibrations
Get All Calibrations endpoint.
Endpoint
GET /unit_api/calibrations
Response
Success
Status: 200 OK
Example body:
"alt_media_pump": [
"calibration_type": "simple_peristaltic_pump",
"calibration_name": "alt_media-2023-05-02",
"calibrated_on_pioreactor_unit": "testing_unit",
"created_at": "2010-01-01T00:00:00Z",
"curve_data_": {
"type": "poly",
"coefficients": [
1.0270833333333333,
0.0
"x": "Duration",
"y": "Volume",
"recorded_data": {
"x": [
0.5,
0.5,
0.5
"y": [
0.5,
0.5,
0.5
"hz": 200.0,
"dc": 90.0,
"voltage": 0.0,
"is_active": false,
"pioreactor_unit": "localhost"
"calibration_name": "alt_media_pump-2026-01-28",
"calibrated_on_pioreactor_unit": "localhost",
"created_at": "2026-01-28T01:45:28.286000Z",
"curve_data_": {
"type": "poly",
"coefficients": [
6.224877783813145,
0.0
"x": "Duration",
"y": "Volume",
"recorded_data": {
"x": [
0.26666666666666666,
0.26666666666666666
"y": [
1.0,
1.0,
1.0
"hz": 250.0,
"dc": 100.0,
"voltage": 0.0,
"is_active": false,
"calibration_name": "debug",
"curve_data_": {
"type": "poly",
"coefficients": [
1.0,
0.0
"x": "Duration",
"y": "Volume",
"recorded_data": {
"x": [],
"y": []
"hz": 100.0,
"dc": 60.0,
"voltage": -1.0,
"is_active": false,
"media_pump": [
"curve_data_": {
"type": "poly",
"coefficients": [
1.0270833333333333,
0.0
"x": "Duration",
"y": "Volume",
"recorded_data": {
"x": [
0.5,
0.5,
0.5
"y": [
0.5,
0.5,
0.5
"hz": 200.0,
"dc": 90.0,
"voltage": 0.0,
"is_active": false,
"curve_data_": {
"type": "poly",
"coefficients": [
1.0,
0.0
"x": "Duration",
"y": "Volume",
"recorded_data": {
"x": [],
"y": []
"hz": 100.0,
"dc": 60.0,
"voltage": -1.0,
"is_active": false,
"calibration_name": "fast_dosing_test_calibration_10ml_s",
"curve_data_": {
"type": "poly",
"coefficients": [
10.0,
0.0
"x": "Duration",
"y": "Volume",
"recorded_data": {
"x": [],
"y": []
"hz": 100.0,
"dc": 60.0,
"voltage": -1.0,
"is_active": false,
"od135": [
"calibration_type": "od600",
"calibration_name": "linear_135",
"created_at": "2026-01-02T02:07:01.506000Z",
"curve_data_": {
"type": "poly",
"coefficients": [
5.0,
0.0
"x": "OD600",
"y": "Voltage",
"recorded_data": {
"x": [
0.0,
1.0
"y": [
0.0,
5.0
"ir_led_intensity": 90.0,
"angle": "135",
"pd_channel": "4",
"is_active": false,
"calibration_name": "od-cal-2026-01-02",
"created_at": "2026-01-02T03:14:38.840000Z",
"curve_data_": {
"type": "poly",
"coefficients": [
0.0006722234149721264,
-0.0007658042929294755,
0.11977764295022217
"x": "OD600",
"y": "Voltage",
"recorded_data": {
"x": [
1.0,
2.0,
0.0
"y": [
0.1196840620722648,
0.12093492802425171,
0.11977764295022218
"ir_led_intensity": 80.0,
"angle": "135",
"pd_channel": "4",
"is_active": false,
"calibration_name": "od-cal-2026-01-11",
"created_at": "2026-01-11T02:16:58.880000Z",
"curve_data_": {
"type": "poly",
"coefficients": [
0.05997775639991009,
0.059977756399910084
"x": "OD600",
"y": "Voltage",
"recorded_data": {
"x": [
1.0,
1.0
"y": [
0.1200894308809028,
0.11982159471873759
"angle": "135",
"pd_channel": "4",
"is_active": false,
"od45": [
"calibration_name": "linear_45",
"created_at": "2026-02-12T01:35:42.992000Z",
"curve_data_": {
"type": "poly",
"coefficients": [
4.0,
0.0
"x": "OD600",
"y": "Voltage",
"recorded_data": {
"x": [
0.0,
1.0
"y": [
0.0,
4.0
"angle": "45",
"pd_channel": "3",
"is_active": false,
"calibration_name": "tmp45",
"created_at": "2026-02-24T14:56:02.229000Z",
"curve_data_": {
"type": "poly",
"coefficients": [
4.0,
0.0
"x": "OD600",
"y": "Voltage",
"recorded_data": {
"x": [
0.0,
1.0
"y": [
0.0,
4.0
"angle": "45",
"pd_channel": "3",
"is_active": false,
"od90": [
"calibration_name": "custom-od600",
"calibrated_on_pioreactor_unit": "pio1",
"created_at": "2026-01-18T20:00:00Z",
"curve_data_": {
"type": "poly",
"coefficients": [
4.701085432962409e-06,
-0.0002849862354595922,
0.0023565718622962583
"x": "OD600",
"y": "Voltage",
"recorded_data": {
"x": [
0.0025,
0.007924,
0.01991
"y": [
0.0045,
0.018,
0.19
"ir_led_intensity": 70.0,
"angle": "90",
"pd_channel": "2",
"is_active": false,
"calibration_name": "linear",
"created_at": "2026-01-02T01:54:55.994000Z",
"curve_data_": {
"type": "poly",
"coefficients": [
2.0,
0.0
"x": "OD600",
"y": "Voltage",
"recorded_data": {
"x": [
0.0,
2.0
"y": [
0.0,
1.0
"angle": "90",
"pd_channel": "2",
"is_active": false,
"calibration_name": "linear_90",
"curve_data_": {
"type": "poly",
"coefficients": [
2.0,
0.0
"x": "OD600",
"y": "Voltage",
"recorded_data": {
"x": [
0.0,
2.0
"y": [
0.0,
4.0
"angle": "90",
"pd_channel": "2",
"is_active": false,
"stirring": [
"calibration_type": "simple_stirring",
"calibration_name": "stirring-calibration-2026-02-10_02-02",
"created_at": "2026-02-10T02:02:24.897000Z",
"curve_data_": {
"type": "spline",
"knots": [
19.8,
39.9
"coefficients": [
"<truncated>",
"<truncated>",
"<truncated>"
"x": "DC %",
"y": "RPM",
"recorded_data": {
"x": [
39.9,
34.875,
29.85
"y": [
1500.0,
1500.0,
1500.0
"pwm_hz": 200.0,
"voltage": 0.0,
"is_active": false,
"calibration_name": "stirring-calibration-2026-02-20_02-19",
"created_at": "2026-02-20T02:19:35.790000Z",
"curve_data_": {
"type": "spline",
"knots": [
9.9,
12.413,
17.438
"coefficients": [
"<truncated>",
"<truncated>",
"<truncated>"
"<truncated>",
"<truncated>",
"<truncated>"
"<truncated>",
"<truncated>",
"<truncated>"
"x": "DC %",
"y": "RPM",
"recorded_data": {
"x": [
19.95,
17.438,
14.925
"y": [
500.0,
500.0,
500.0
"pwm_hz": 200.0,
"voltage": 0.0,
"is_active": false,
"calibration_name": "stirring-calibration-2026-02-20_02-21",
"created_at": "2026-02-20T02:21:41.341000Z",
"curve_data_": {
"type": "spline",
"knots": [
9.9,
12.413,
17.438
"coefficients": [
"<truncated>",
"<truncated>",
"<truncated>"
"<truncated>",
"<truncated>",
"<truncated>"
"<truncated>",
"<truncated>",
"<truncated>"
"x": "DC %",
"y": "RPM",
"recorded_data": {
"x": [
19.95,
17.438,
14.925
"y": [
500.0,
500.0,
500.0
"pwm_hz": 200.0,
"voltage": 0.0,
"is_active": false,
"waste_pump": [
"curve_data_": {
"type": "poly",
"coefficients": [
1.0270833333333333,
0.0
"x": "Duration",
"y": "Volume",
"recorded_data": {
"x": [
0.5,
0.5,
0.5
"y": [
0.5,
0.5,
0.5
"hz": 200.0,
"dc": 90.0,
"voltage": 0.0,
"is_active": false,
"curve_data_": {
"type": "poly",
"coefficients": [
1.0,
0.0
"x": "Duration",
"y": "Volume",
"recorded_data": {
"x": [],
"y": []
"hz": 100.0,
"dc": 60.0,
"voltage": -1.0,
"is_active": false,
"curve_data_": {
"type": "poly",
"coefficients": [
10.0,
0.0
"x": "Duration",
"y": "Volume",
"recorded_data": {
"x": [],
"y": []
"hz": 100.0,
"dc": 60.0,
"voltage": -1.0,
"is_active": false,
Get Calibrations By Device
Get Calibrations By Device endpoint.
Endpoint
GET /unit_api/calibrations/{device}
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
"calibration_name": "example_calibration",
"is_active": true
Create Calibration
Create a new calibration for the specified device.
Endpoint
POST /unit_api/calibrations/{device}
Request
Path Parameters
Request Body
| calibration_data | string | Yes | calibration data. |
| set_as_active | boolean | No | set as active. |
"calibration_data": "calibration_type: simple_peristaltic_pump\ncalibration_name: example_calibration\n",
"set_as_active": true
Response
Success
Status: 201 Created
No success response body.
Delete Calibration
Delete a specific calibration for a given device.
Endpoint
DELETE /unit_api/calibrations/{device}/{calibration_name}
Request
Path Parameters
Response
Success
Status: 200 OK
Get Calibration
Get Calibration endpoint.
Endpoint
GET /unit_api/calibrations/{device}/{calibration_name}
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
"is_active": true
Get Camera Status For Experiment
Get Camera Status For Experiment endpoint.
Endpoint
GET /unit_api/camera/experiments/{experiment}/status
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
"unit": "localhost",
"detection_status": "detected",
"runtime_available": true,
"capture_command": null,
"mock": true,
"latest_still": {
"experiment": "khtfddecb",
"captured_at": "2026-11-04T15:07:00.570920Z",
"image_id": "20261104T150700.570920Z-90eec877",
"capture_reason": "scheduled"
"auto_capture_enabled": true,
"snapshot_interval_minutes": 5
Delete Camera Stills For Experiment Route
Delete Camera Stills For Experiment Route endpoint.
Endpoint
DELETE /unit_api/camera/experiments/{experiment}/stills
Request
Path Parameters
Response
Success
Status: 200 OK
List Camera Stills For Experiment
List Camera Stills For Experiment endpoint.
Endpoint
GET /unit_api/camera/experiments/{experiment}/stills
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
"stills": [
Capture Camera Still For Experiment
Capture Camera Still For Experiment endpoint.
Endpoint
POST /unit_api/camera/experiments/{experiment}/stills
Request
Path Parameters
Response
Success
Status: 202 Accepted
Example body:
"unit": "pio01",
"task_id": "abcd1234",
"result_url_path": "/unit_api/task_results/abcd1234",
"status": "accepted"
Get Zipped Camera Stills For Experiment
Get Zipped Camera Stills For Experiment endpoint.
Endpoint
GET /unit_api/camera/experiments/{experiment}/stills.zip
Request
Path Parameters
Response
Success
Status: 200 OK
Response body is binary file data.
Delete Camera Still For Experiment
Delete Camera Still For Experiment endpoint.
Endpoint
DELETE /unit_api/camera/experiments/{experiment}/stills/{image_id}.jpg
Request
Path Parameters
| image_id | string | Yes | image id. |
Response
Success
Status: 200 OK
Get Camera Still For Experiment
Get Camera Still For Experiment endpoint.
Endpoint
GET /unit_api/camera/experiments/{experiment}/stills/{image_id}.jpg
Request
Path Parameters
Response
Success
Status: 200 OK
Rename Camera Still For Experiment
Rename Camera Still For Experiment endpoint.
Endpoint
PATCH /unit_api/camera/experiments/{experiment}/stills/{image_id}.jpg
Request
Path Parameters
Request Body
| new_image_id | string | Yes | new image id. |
"new_image_id": "example_new_image_id"
Response
Success
Status: 200 OK
Get Camera Focus Preview
Get Camera Focus Preview endpoint.
Endpoint
GET /unit_api/camera/focus_sessions/{session_id}/preview.jpg
Request
Path Parameters
| session_id | string | Yes | Calibration session identifier. |
Response
Success
Status: 200 OK
Update Camera Settings
Update Camera Settings endpoint.
Endpoint
PATCH /unit_api/camera/settings
Request
Request Body
| auto_capture_enabled | boolean | Yes | auto capture enabled. |
Response
Success
Status: 200 OK
Get Capabilities
Get Capabilities endpoint.
Endpoint
GET /unit_api/capabilities
Response
Success
Status: 200 OK
Example body:
"job_name": "add_alt_media",
"help": "Add alt-media from unit",
"arguments": [],
"options": [
"name": "ml",
"long_flag": "ml",
"help": "",
"required": false,
"multiple": false,
"default": null,
"type": "float"
"name": "duration",
"long_flag": "duration",
"help": "",
"required": false,
"multiple": false,
"default": null,
"type": "float"
"name": "continuously",
"long_flag": "continuously",
"help": "add until the maximum safe volume is reached.",
"required": false,
"multiple": false,
"default": null,
"type": "boolean"
"published_settings": {},
"cli_example": "pio run add_alt_media [OPTIONS]"
"job_name": "add_media",
"help": "Add media to unit",
"arguments": [],
"options": [
"name": "ml",
"long_flag": "ml",
"help": "",
"required": false,
"multiple": false,
"default": null,
"type": "float"
"name": "duration",
"help": "",
"required": false,
"multiple": false,
"default": null,
"type": "float"
"required": false,
"multiple": false,
"default": null,
"type": "boolean"
"cli_example": "pio run add_media [OPTIONS]"
"job_name": "backup_database",
"help": "(leader only) Backup db to workers.",
"arguments": [],
"options": [
"name": "output",
"long_flag": "output",
"help": "",
"required": false,
"multiple": false,
"default": "/Users/camerondavidson-pilon/code/pioreactor/.pioreactor/storage/pioreactor.sqlite.backup",
"type": "text"
"name": "force",
"long_flag": "force",
"help": "force backing up",
"required": false,
"multiple": false,
"default": null,
"type": "boolean"
"name": "backup_to_workers",
"long_flag": "backup-to-workers",
"help": "back up db to N workers",
"required": false,
"multiple": false,
"default": null,
"type": "integer"
"cli_example": "pio run backup_database [OPTIONS]"
Leave Cluster
Leave this unit's cluster, then reboot. See pio cluster leave.
Endpoint
POST /unit_api/cluster/leave
Request
Request Body
| stop_activities | boolean | No | stop activities. |
"stop_activities": true
Response
Success
Example body:
"unit": "pio01",
Get Merged Config
Get Merged Config endpoint.
Endpoint
GET /unit_api/config/merged
Response
Success
Status: 200 OK
Example body:
"PWM": {
"1": "stirring",
"2": "waste",
"3": "media",
"4": "air_bubbler",
"5": "heating"
"leds": {
"A": "IR",
"B": "white_light",
"C": "",
"D": ""
"bioreactor": {
"efflux_tube_volume_ml": "14",
"initial_volume_ml": "14",
"initial_alt_media_fraction": "0.0",
"initial_cumulative_media_added_ml": "0",
"initial_cumulative_alt_media_added_ml": "0",
"initial_cumulative_waste_removed_ml": "0"
"stirring.config": {
"initial_target_rpm": "500",
"initial_duty_cycle": "15",
"pwm_hz": "200",
"use_rpm": "True",
"duration_between_updates_seconds": "23",
"post_delay_duration": "0.25",
"pre_delay_duration": "0.25",
"enable_dodging_od": "true",
"target_rpm_during_od_reading": "0",
"target_rpm_outside_od_reading": "500"
"dosing_automation.turbidostat": {
"biomass_signal": "auto"
"stirring.pid": {
"Kp": "0.007",
"Ki": "0.0",
"Kd": "0.0"
"od_config.photodiode_channel": {
"1": "REF",
"2": "90"
"od_reading.config": {
"samples_per_second": "0.2",
"turn_off_leds_during_reading": "1",
"pd_reference_ema": "0.4",
"ir_led_intensity": "80",
"duration_between_led_off_and_od_reading": "0.1",
"smoothing_penalizer": "6.0",
"use_dark_offsets": "1"
"camera": {
"snapshot_interval_minutes": "5",
"camera_index": "0",
"ir_led_intensity": "90",
"enabled": "1",
"keep_camera_active": "0"
"storage": {
"database": "/Users/camerondavidson-pilon/code/pioreactor/.pioreactor/storage/pioreactor.sqlite",
"temporary_cache": "/Users/camerondavidson-pilon/code/pioreactor/.pioreactor/storage/local_intermittent_pioreactor_metadata.sqlite",
"persistent_cache": "/Users/camerondavidson-pilon/code/pioreactor/.pioreactor/storage/local_persistent_pioreactor_metadata.sqlite",
"number_of_backup_replicates_to_workers": "0"
"logging": {
"log_file": "./pioreactor.log",
"ui_log_file": "./pioreactor.log",
"ui_log_level": "DEBUG",
"console_log_level": "DEBUG"
"cluster.topology": {
"leader_hostname": "localhost",
"leader_address": "localhost"
"ui.overview.settings": {
"filtered_od_lookback_minutes": "240",
"raw_od_lookback_minutes": "240",
"log_display_count": "65",
"time_display_mode": "hours"
"ui": {
"port": "4999",
"proto": "http"
"ui.overview.charts": {
"implied_growth_rate": "1",
"implied_daily_growth_rate": "0",
"fraction_of_volume_that_is_alternative_media": "1",
"normalized_optical_density": "1",
"raw_optical_density": "1",
"temperature": "1",
"optical_density": "1"
"ui.overview.cards": {
"dosings": "1",
"event_logs": "1",
"profiles": "1"
"dosing_automation.pid_morbidostat": {
"Kp": "5",
"Ki": "0",
"Kd": "0"
"temperature_automation.thermostat": {
"Kp": ".01",
"Ki": ".01",
"Kd": ".01"
"mqtt": {
"username": "pioreactor",
"password": "raspberry",
"broker_address": "localhost",
"broker_ws_port": "9001",
"broker_port": "1883",
"ws_protocol": "ws",
"use_tls": "0"
"dosing_automation.config": {
"pause_between_subdoses_seconds": "0.5",
"waste_removal_multiplier": "2.0",
"max_volume_to_warn": "17.0",
"max_subdose": "1.0",
"experimental_pump_malfunction_tolerance": "0.2",
"experimental_detect_pump_malfunction": "False"
Get Specific Config
Get Specific Config endpoint.
Endpoint
GET /unit_api/config/specific
Response
Success
Status: 200 OK
Response body is plain text.
Update Specific Config
Replace this unit's unit-specific config text.
Endpoint
PATCH /unit_api/config/specific
Request
Request Body
| code | string | Yes | code. |
"code": "[section]\nkey=value\n"
Response
Success
Status: 200 OK
Example body:
"status": "success"
Endpoint
POST /unit_api/config/specific
Request
Request Body
Response
Success
Status: 200 OK
Example body:
"status": "success"
Endpoint
PUT /unit_api/config/specific
Request
Request Body
Response
Success
Status: 200 OK
Example body:
"status": "success"
Get All Estimators
Get All Estimators endpoint.
Endpoint
GET /unit_api/estimators
Response
Success
Status: 200 OK
Example body:
"od_fused": [
"estimator_type": "od_fused_estimator",
"estimator_name": "od-fused-estimator-2026-01-23",
"calibrated_on_pioreactor_unit": "xr1",
"created_at": "2026-01-23T14:43:04.207000Z",
"angles": [
"45",
"90",
"135"
"mu_splines": {
"45": {
"type": "akima",
"knots": [
"<truncated>",
"<truncated>"
"coefficients": [
"<truncated>"
"90": {
"type": "akima",
"knots": [
"<truncated>",
"<truncated>"
"coefficients": [
"<truncated>"
"135": {
"type": "akima",
"knots": [
"<truncated>",
"<truncated>"
"coefficients": [
"<truncated>"
"sigma_splines_log": {
"45": {
"type": "akima",
"knots": [
"<truncated>",
"<truncated>"
"coefficients": [
"<truncated>"
"90": {
"type": "akima",
"knots": [
"<truncated>",
"<truncated>"
"coefficients": [
"<truncated>"
"135": {
"type": "akima",
"knots": [
"<truncated>",
"<truncated>"
"coefficients": [
"<truncated>"
"min_logc": 0.0,
"max_logc": 0.7781512503836436,
"sigma_floor": 0.05,
"recorded_data": {
"x": [
0.0,
0.47712125471966244,
0.6989700043360189
"y": [
-6.778473545527855,
-6.787264739975302,
-6.787050588455531
"low_conc_scales": {},
"y": "log(Voltage)",
"is_active": false,
"pioreactor_unit": "localhost",
"device": "od_fused"
"estimator_name": "od-fused-estimator-2026-01-27",
"created_at": "2026-01-27T15:59:11.334000Z",
"angles": [
"45",
"90",
"135"
"mu_splines": {
"45": {
"type": "akima",
"knots": [
"<truncated>",
"<truncated>",
"<truncated>"
"coefficients": [
"<truncated>",
"<truncated>",
"<truncated>"
"90": {
"type": "akima",
"knots": [
"<truncated>",
"<truncated>",
"<truncated>"
"coefficients": [
"<truncated>",
"<truncated>",
"<truncated>"
"135": {
"type": "akima",
"knots": [
"<truncated>",
"<truncated>",
"<truncated>"
"coefficients": [
"<truncated>",
"<truncated>",
"<truncated>"
"45": {
"type": "akima",
"knots": [
"<truncated>",
"<truncated>",
"<truncated>"
"coefficients": [
"<truncated>",
"<truncated>"
"90": {
"type": "akima",
"knots": [
"<truncated>",
"<truncated>",
"<truncated>"
"coefficients": [
"<truncated>",
"<truncated>"
"135": {
"type": "akima",
"knots": [
"<truncated>",
"<truncated>",
"<truncated>"
"coefficients": [
"<truncated>",
"<truncated>"
"min_logc": -2.0,
"max_logc": 0.5440680443502757,
"sigma_floor": 0.04,
"recorded_data": {
"by_angle": {
"45": {
"x": "<truncated>",
"y": "<truncated>"
"90": {
"x": "<truncated>",
"y": "<truncated>"
"135": {
"x": "<truncated>",
"y": "<truncated>"
"is_active": false,
"estimator_name": "od-fused-estimator-2026-01-28",
"calibrated_on_pioreactor_unit": "xr4",
"created_at": "2026-01-28T16:04:53.392000Z",
"angles": [
"45",
"90",
"135"
"mu_splines": {
"45": {
"type": "akima",
"knots": [
"<truncated>",
"<truncated>",
"<truncated>"
"coefficients": [
"<truncated>",
"<truncated>",
"<truncated>"
"90": {
"type": "akima",
"knots": [
"<truncated>",
"<truncated>",
"<truncated>"
"coefficients": [
"<truncated>",
"<truncated>",
"<truncated>"
"135": {
"type": "akima",
"knots": [
"<truncated>",
"<truncated>",
"<truncated>"
"coefficients": [
"<truncated>",
"<truncated>",
"<truncated>"
"45": {
"type": "akima",
"knots": [
"<truncated>",
"<truncated>",
"<truncated>"
"coefficients": [
"<truncated>",
"<truncated>",
"<truncated>"
"90": {
"type": "akima",
"knots": [
"<truncated>",
"<truncated>",
"<truncated>"
"coefficients": [
"<truncated>",
"<truncated>",
"<truncated>"
"135": {
"type": "akima",
"knots": [
"<truncated>",
"<truncated>",
"<truncated>"
"coefficients": [
"<truncated>",
"<truncated>",
"<truncated>"
"min_logc": -4.0,
"max_logc": 1.6989700043360187,
"recorded_data": {
"by_angle": {
"45": {
"x": "<truncated>",
"y": "<truncated>"
"90": {
"x": "<truncated>",
"y": "<truncated>"
"135": {
"x": "<truncated>",
"y": "<truncated>"
"is_active": false,
"temperature_fir": [
"estimator_type": "fir_temperature_estimator",
"estimator_name": "fir_temperature_estimator_linear_mlx_ambient_pcb_v1",
"calibrated_on_pioreactor_unit": "seed",
"created_at": "2026-02-18T00:00:00Z",
"w_obj": 0.986277,
"w_amb": -0.126407,
"w_pcb": 0.088753,
"c": 1.083602,
"tau_s": 120.0,
"k_vol": -0.012317,
"volume_ref_ml": 25.0,
"user_bias_c": 0.0,
"y": "temperature_c",
"is_active": false,
"device": "temperature_fir"
Get Estimators By Device
Get Estimators By Device endpoint.
Endpoint
GET /unit_api/estimators/{device}
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
Delete Estimator
Delete Estimator endpoint.
Endpoint
DELETE /unit_api/estimators/{device}/{estimator_name}
Request
Path Parameters
Response
Success
Status: 200 OK
Get Estimator
Get Estimator endpoint.
Endpoint
GET /unit_api/estimators/{device}/{estimator_name}
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
"estimator_name": "example_estimator",
"is_active": true
Check Hardware For Model
Check whether this unit's hardware supports a model.
Endpoint
PATCH /unit_api/hardware/check
Request
Request Body
| model_name | string | Yes | model name. |
| model_version | string | Yes | model version. |
"model_name": "pioreactor_40ml",
"model_version": "1.5"
Response
Success
Example body:
"unit": "pio01",
Endpoint
POST /unit_api/hardware/check
Request
Request Body
Response
Success
Example body:
"unit": "pio01",
Health Check
Health Check endpoint.
Endpoint
GET /unit_api/health
Response
Success
Status: 200 OK
Example body:
"status": "ok",
"utc_time": "2026-11-04T15:07:00.922Z"
Import Dot Pioreactor From Zip
Import a zipped DOT_PIOREACTOR archive into this unit.
Endpoint
POST /unit_api/import_zipped_dot_pioreactor
Response
Success
Example body:
"unit": "pio01",
Get Jobs
Get Jobs endpoint.
Endpoint
GET /unit_api/jobs
Response
Success
Status: 200 OK
Example body:
Get Job Descriptors
Return this unit's background-job UI descriptors.
Endpoint
GET /unit_api/jobs/descriptors
Response
Success
Status: 200 OK
Example body:
"display_name": "Stirring",
"job_name": "stirring",
"display": true,
"published_settings": [
"key": "target_rpm",
"type": "numeric",
"display": true,
"description": "Modify the target RPM of stirring. This will effect the optical density reading. Too low and the stirring may completely stop. Too high and the resulting vortex may interfere with the optics.",
"default": null,
"unit": "RPM",
"label": "Target stir RPM",
"editable": true,
"min": null,
"max": null
"source": "app",
"description": "Start the stirring on the Pioreactor. Stirring is needed for mixing and proper OD measurements.",
"subtext": null,
"is_testing": false
"display_name": "Optical density",
"job_name": "od_reading",
"display": true,
"published_settings": [],
"source": "app",
"description": "Collect optical density measurements of the culture over time.",
"subtext": null,
"is_testing": false
"display_name": "Growth rate",
"job_name": "growth_rate_calculating",
"display": true,
"source": "app",
"description": "Transform optical density measurements into culture growth rate measurements. Start this after innoculation. Begins by sampling for a few minutes to gather a baseline.",
"subtext": null,
"is_testing": false
Run Job
Run a job on this unit.
Endpoint
PATCH /unit_api/jobs/run/job_name/{job_name}
Request
Path Parameters
| job_name | string | Yes | Job name. |
Request Body
| args | array | No | args. |
| config_overrides | array | No | config overrides. |
| env | object | No | env. |
| options | object | No | options. |
"options": {
"target_rpm": "200"
"env": {
"JOB_SOURCE": "api"
"args": [
"some-flag"
"config_overrides": [
"stirring.config",
"pwm_hz",
"100"
Response
Success
Example body:
"unit": "pio01",
Run Job
Endpoint
POST /unit_api/jobs/run/job_name/{job_name}
Request
Path Parameters
Request Body
"options": {
"target_rpm": "200"
"env": {
"JOB_SOURCE": "api"
"args": [
"some-flag"
"stirring.config",
"pwm_hz",
"100"
Response
Success
Example body:
"unit": "pio01",
Get All Running Jobs
Get All Running Jobs endpoint.
Endpoint
GET /unit_api/jobs/running
Response
Success
Status: 200 OK
Example body:
Get Running Job
Get Running Job endpoint.
Endpoint
GET /unit_api/jobs/running/{job_name}
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
Get Running Jobs For Experiment
Get Running Jobs For Experiment endpoint.
Endpoint
GET /unit_api/jobs/running/experiments/{experiment}
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
Get Job Settings
Return published settings for a running job.
Endpoint
GET /unit_api/jobs/settings/job_name/{job_name}
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
"settings": {
"target_rpm": "200"
Get Job Setting
Get Job Setting endpoint.
Endpoint
GET /unit_api/jobs/settings/job_name/{job_name}/setting/{setting}
Request
Path Parameters
| setting | string | Yes | Job setting name. |
Response
Success
Status: 200 OK
Example body:
"target_rpm": "200"
Stop Jobs
Stop jobs matching at least one filter.
Endpoint
PATCH /unit_api/jobs/stop
Request
Request Body
| experiment | string | No | experiment. |
| job_id | integer | No | job id. |
| job_name | string | No | job name. |
| job_source | string | No | job source. |
"experiment": "testing_experiment",
"job_id": 1,
"job_name": "example_job_name",
"job_source": "example_job_source"
Response
Success
Example body:
"unit": "pio01",
Stop Jobs
Endpoint
POST /unit_api/jobs/stop
Request
Request Body
"job_id": 1,
Response
Success
Example body:
"unit": "pio01",
Stop All Jobs
Stop all jobs running on this unit.
Endpoint
PATCH /unit_api/jobs/stop/all
Response
Success
Example body:
"unit": "pio01",
Stop All Jobs
Endpoint
POST /unit_api/jobs/stop/all
Response
Success
Example body:
"unit": "pio01",
Get All Long Running Jobs
Get All Long Running Jobs endpoint.
Endpoint
GET /unit_api/long_running_jobs/running
Response
Success
Status: 200 OK
Example body:
Get Unit Model
Get Unit Model endpoint.
Endpoint
GET /unit_api/model
Response
Success
Status: 200 OK
Set Unit Model
Set Unit Model endpoint.
Endpoint
PUT /unit_api/model
Request
Request Body
Response
Success
Status: 200 OK
Install Plugin
Install one plugin by running pio plugin install.
Endpoint
PATCH /unit_api/plugins/install
Request
Request Body
"args": [
"some-flag"
"env": {
"JOB_SOURCE": "api"
"options": {
"target_rpm": "200"
Response
Success
Example body:
"unit": "pio01",
Install Plugin
Endpoint
POST /unit_api/plugins/install
Request
Request Body
"args": [
"some-flag"
"env": {
"JOB_SOURCE": "api"
"options": {
"target_rpm": "200"
Response
Success
Example body:
"unit": "pio01",
Install Plugin From Usb
Install one plugin artifact from a Pioreactor-managed USB mount.
Endpoint
PATCH /unit_api/plugins/install-from-usb
Request
Request Body
| filepath | string | Yes | filepath. |
"filepath": "example_filepath"
Response
Success
Example body:
"unit": "pio01",
Endpoint
POST /unit_api/plugins/install-from-usb
Request
Request Body
Response
Success
Example body:
"unit": "pio01",
Install Python Plugin File From Leader Copy
Install one Python file plugin copied by the leader to /tmp.
Endpoint
PATCH /unit_api/plugins/install-python-file-from-leader-copy
Request
Request Body
| filename | string | Yes | filename. |
"filename": "profile.yaml"
Response
Success
Example body:
"unit": "pio01",
Endpoint
POST /unit_api/plugins/install-python-file-from-leader-copy
Request
Request Body
Response
Success
Example body:
"unit": "pio01",
Get Installed Plugins
Get Installed Plugins endpoint.
Endpoint
GET /unit_api/plugins/installed
Response
Success
Status: 200 OK
Example body:
"name": "pioreactor-precision-temperature-plugin",
"version": "0.1.1",
"description": "Precision temperature automation for Pioreactor using FIR + MLX90632",
"homepage": "https://github.com/Pioreactor/pioreactor-precision-temperature-plugin",
"source": "entry_points",
"author": "Cam Davidson-Pilon"
"name": "MusetFedbatch",
"version": "Unknown",
"description": "Unknown",
"homepage": "http://localhost:4999/unit_api/plugins/installed/MusetFedbatch.py",
"source": "plugins/MusetFedbatch.py",
"author": "Unknown"
"name": "UVCycle",
"homepage": "http://localhost:4999/unit_api/plugins/installed/UVCycle.py",
"source": "plugins/UVCycle.py",
"author": "Unknown"
get a specific Python file in the .pioreactor/plugin folder
Endpoint
GET /unit_api/plugins/installed/{filename}
Request
Path Parameters
| filename | string | Yes | Filename. |
Response
Success
Status: 200 OK
Response body is the plugin Python source as plain text.
Uninstall Plugin
Uninstall one plugin by running pio plugin uninstall.
Endpoint
PATCH /unit_api/plugins/uninstall
Request
Request Body
"args": [
"some-flag"
"env": {
"JOB_SOURCE": "api"
"options": {
"target_rpm": "200"
Response
Success
Example body:
"unit": "pio01",
Uninstall Plugin
Endpoint
POST /unit_api/plugins/uninstall
Request
Request Body
"args": [
"some-flag"
"env": {
"JOB_SOURCE": "api"
"options": {
"target_rpm": "200"
Response
Success
Example body:
"unit": "pio01",
Get Settings Descriptors
Return this unit's settings UI descriptors.
Endpoint
GET /unit_api/settings/descriptors
Response
Success
Status: 200 OK
Example body:
"key": "bioreactor",
"display_name": "Bioreactor",
"display": true,
"key": "current_volume_ml",
"type": "numeric",
"display": true,
"description": "Current estimated liquid volume in the vial.",
"default": 14.0,
"unit": "mL",
"label": "Current volume",
"editable": true,
"min": 0.0,
"max": null
"key": "efflux_tube_volume_ml",
"type": "numeric",
"display": true,
"description": "Liquid volume equivalent to the height of the waste/efflux tube.",
"default": 14.0,
"unit": "mL",
"label": "Efflux tube level",
"editable": true,
"min": 0.0,
"max": null
"key": "alt_media_fraction",
"type": "numeric",
"display": true,
"description": "Fraction of the current volume estimated to be alt media.",
"default": 0.0,
"unit": null,
"label": "Alt media fraction",
"editable": true,
"min": 0.0,
"max": 1.0
"source": "app",
"description": "Per-unit bioreactor settings.",
"subtext": null
"key": "leds",
"display_name": "led intensity",
"display": false,
"key": "intensity",
"type": "string",
"display": true,
"description": null,
"default": null,
"unit": null,
"label": "LED intensity",
"editable": false,
"min": null,
"max": null
"source": "app",
"subtext": null
"key": "pwms",
"display_name": "PWMs",
"display": false,
"key": "dc",
"type": "string",
"display": true,
"default": null,
"unit": null,
"label": "PWM intensity",
"editable": false,
"min": null,
"max": null
"source": "app",
"subtext": null
Get Disk Space
Return this unit's root filesystem disk space.
Endpoint
GET /unit_api/system/disk_space
Response
Success
Status: 200 OK
Example body:
"available_bytes": 38477627392,
"total_bytes": 494384795648
Get System Ipv4
Get System Ipv4 endpoint.
Endpoint
GET /unit_api/system/ipv4
Response
Success
Status: 200 OK
Example body:
"ipv4_address": ""
Get Memory
Return this unit's memory availability.
Endpoint
GET /unit_api/system/memory
Response
Success
Status: 200 OK
Example body:
"available_bytes": 3314483200,
"total_bytes": 17179869184
List System Path
List System Path endpoint.
Endpoint
GET /unit_api/system/path/
Response
Success
Status: 200 OK
Example body:
"current": "/home/pioreactor/.pioreactor",
"dirs": [
"experiment_profiles",
"plugins",
"storage"
"files": [
"config.ini",
"unit_config.ini"
List System Path
Endpoint
GET /unit_api/system/path/{req_path}
Request
Path Parameters
| req_path | string | Yes | Path under the unit filesystem endpoint. |
Response
Success
Status: 200 OK
Example body:
"dirs": [
"plugins",
"storage"
"files": [
"config.ini",
"unit_config.ini"
Reboot System
Reboot this unit.
Endpoint
PATCH /unit_api/system/reboot
Response
Success
Example body:
"unit": "pio01",
Reboot System
Reboot this unit.
Endpoint
POST /unit_api/system/reboot
Response
Success
Example body:
"unit": "pio01",
Remove File
Remove a file under this unit's DOT_PIOREACTOR tree.
Endpoint
PATCH /unit_api/system/remove_file
Request
Request Body
Response
Success
Example body:
"unit": "pio01",
Remove File
Endpoint
POST /unit_api/system/remove_file
Request
Request Body
Response
Success
Example body:
"unit": "pio01",
Repair System
Repair this unit's Pioreactor filesystem permissions.
Endpoint
PATCH /unit_api/system/repair
Response
Success
Example body:
"unit": "pio01",
Repair System
Endpoint
POST /unit_api/system/repair
Response
Success
Example body:
"unit": "pio01",
Shutdown System
Shut down this unit.
Endpoint
PATCH /unit_api/system/shutdown
Response
Success
Example body:
"unit": "pio01",
Shutdown System
Endpoint
POST /unit_api/system/shutdown
Response
Success
Example body:
"unit": "pio01",
Update Software
Update the Pioreactor app on this unit.
Endpoint
PATCH /unit_api/system/update
Request
Request Body
"args": [
"some-flag"
"env": {
"JOB_SOURCE": "api"
"options": {
"target_rpm": "200"
Response
Success
Example body:
"unit": "pio01",
Update Software
Endpoint
POST /unit_api/system/update
Request
Request Body
"args": [
"some-flag"
"env": {
"JOB_SOURCE": "api"
"options": {
"target_rpm": "200"
Response
Success
Example body:
"unit": "pio01",
Update Software Target
Update one software target on this unit.
Endpoint
PATCH /unit_api/system/update/{target}
Request
Path Parameters
| target | string | Yes | Update target. |
Request Body
"args": [
"some-flag"
"env": {
"JOB_SOURCE": "api"
"options": {
"target_rpm": "200"
Response
Success
Example body:
"unit": "pio01",
Endpoint
POST /unit_api/system/update/{target}
Request
Path Parameters
Request Body
"args": [
"some-flag"
"env": {
"JOB_SOURCE": "api"
"options": {
"target_rpm": "200"
Response
Success
Example body:
"unit": "pio01",
Get Clock Time
Get Clock Time endpoint.
Endpoint
GET /unit_api/system/utc_clock
Response
Success
Status: 200 OK
Example body:
"status": "success",
"clock_time": "2026-11-04T15:07:01.076Z",
"synchronized": null
Set Clock Time
Set or sync this unit's UTC clock.
Endpoint
PATCH /unit_api/system/utc_clock
Request
Request Body
| utc_clock_time | string | Yes | utc clock time. |
"utc_clock_time": "2026-01-01T00:00:00Z"
Response
Success
Example body:
"unit": "pio01",
Set Clock Time
Endpoint
POST /unit_api/system/utc_clock
Request
Request Body
Response
Success
Example body:
"unit": "pio01",
Restart Web Server
Restart the Pioreactor web server target on the leader.
Endpoint
PATCH /unit_api/system/web_server/restart
Response
Success
Example body:
"unit": "pio01",
Restart Web Server
Endpoint
POST /unit_api/system/web_server/restart
Response
Success
Example body:
"unit": "pio01",
Get Web Server Status
Get Web Server Status endpoint.
Endpoint
GET /unit_api/system/web_server/status
Response
Success
Status: 200 OK
Example body:
"service": "lighttpd.service,huey.service",
"state": "ready",
"raw_status": "active"
Get Task Status
Poll the state of an async task previously returned by create_task_response(...).
Endpoint
Request
Path Parameters
| task_id | string | Yes | Task identifier. |
Response
Success
Example body:
"task_id": "task-id",
"result_url_path": "/unit_api/task_results/task-id",
"status": "pending"
Get Usb Status
Get Usb Status endpoint.
Endpoint
GET /unit_api/usb
Response
Success
Status: 200 OK
Example body:
"status": "mounted",
"partitions": [
"device": "/dev/pioreactor-dev-usb1",
"parent_device": "/dev/pioreactor-dev-usb",
"label": "DEV_USB",
"uuid": "DEV-USB",
"fstype": "ext4",
"size_bytes": null,
"mountpoints": [
"/Users/camerondavidson-pilon/code/pioreactor/.pioreactor/dev_usb_mounts/DEV_USB"
"removable": true,
"mounted": true,
"display_name": "DEV_USB",
"pioreactor_mountpoint": "/Users/camerondavidson-pilon/code/pioreactor/.pioreactor/dev_usb_mounts/usb-DEV-USB",
"mountpoint": "/Users/camerondavidson-pilon/code/pioreactor/.pioreactor/dev_usb_mounts/DEV_USB",
"writable": true,
"free_bytes": 38477627392,
"unsupported_reason": null
"active_mount": {
"label": "DEV_USB",
"uuid": "DEV-USB",
"fstype": "ext4",
"size_bytes": null,
"mountpoints": [
"removable": true,
"mounted": true,
"writable": true,
Get Usb Artifacts
Get Usb Artifacts endpoint.
Endpoint
GET /unit_api/usb/artifacts
Response
Success
Status: 200 OK
Example body:
"updates": [
"path": "/Users/camerondavidson-pilon/code/pioreactor/.pioreactor/dev_usb_mounts/DEV_USB/release_26.5.1.zip",
"version": "26.5.1"
"plugins": [
"path": "/Users/camerondavidson-pilon/code/pioreactor/.pioreactor/dev_usb_mounts/DEV_USB/my_plugin.whl",
"name": "my-plugin",
"version": null,
"kind": "wheel"
"path": "/Users/camerondavidson-pilon/code/pioreactor/.pioreactor/dev_usb_mounts/DEV_USB/pioreactor/plugins/pioreactor_usb_demo-1.2.3-py3-none-any.whl",
"name": "pioreactor-usb-demo",
"version": "1.2.3",
"kind": "wheel"
"writable": true,
Eject Usb
Eject Usb endpoint.
Endpoint
POST /unit_api/usb/eject
Request
Request Body
| device | string | No | device. |
"device": "example_device"
Response
Success
Example body:
"unit": "pio01",
Mount Usb
Mount Usb endpoint.
Endpoint
POST /unit_api/usb/mount
Request
Request Body
Response
Success
Example body:
"unit": "pio01",
Get App Version
Get App Version endpoint.
