API Reference (Leader /api)
Conventions
- Only the leader Pioreactor has the
/apiendpoints exposed. - Async endpoints return
202 Acceptedwith atask_idandresult_url_path. - Poll
GET /unit_api/task_results/{task_id}untilstatusissucceededorfailed. $broadcastmay be used in path parameters where documented to target all units/workers.- File download endpoints return binary bodies; use the response content-type to handle them.
- Path parameters are shown inline in the endpoint URL.
- Request/response examples are the canonical shapes; omit optional fields you do not need.
- Errors have the following schema:
"error": "Human-readable error message",
"cause": "Human-readable cause (defaults to error if not set)",
"remediation": "Suggested fix or next step",
"status": 400
Use /api/workers/... for worker-only targets (experiment-scoped jobs/logs) and /api/units/... when the leader is also a valid target; both accept $broadcast where supported.
Pioreactor Leader API
Generated from core/pioreactor/web/api.py.
This file is generated. Edit the API source or generator instead of editing this file by hand.
Endpoint count: 163
Endpoint Index
Get Automation Descriptors
Return the leader's automation UI descriptors for one automation family.
Endpoint
GET /api/automations/descriptors/{automation_type}
Request
Path Parameters
| Name | Type | Required | Description |
| automation_type | string | Yes | Automation type, for example dosing, temperature, or led. |
Response
Success
Status: 200 OK
Example body:
"display_name": "Only record temperature",
"automation_name": "only_record_temperature",
"description": "Apply no heating, only record the temperature.",
"source": null,
"fields": []
"display_name": "Thermostat",
"automation_name": "thermostat",
"description": "Vary the amount of applied heating to keep the culture near a target temperature, using a control-loop.",
"source": null,
"fields": [
"key": "target_temperature",
"default": 30,
"label": "Target temperature",
"disabled": false,
"required": true,
"unit": "\u2103",
"type": "numeric",
"options": null
Get Chart Descriptors
Return the leader's chart UI descriptors.
Endpoint
GET /api/charts/descriptors
Response
Success
Status: 200 OK
Example body:
"chart_key": "implied_growth_rate",
"data_source": "growth_rates",
"title": "Implied growth rate",
"source": "app",
"y_axis_label": "Growth rate, h\u207b\u00b9",
"fixed_decimals": 2,
"down_sample": true,
"mqtt_topic": "growth_rate_calculating/growth_rate",
"lookback": 100000,
"data_source_column": null,
"payload_key": "growth_rate",
"y_transformation": "(y) => y",
"y_axis_domain": [
-0.02,
0.1
"interpolation": "stepAfter"
"chart_key": "implied_daily_growth_rate",
"title": "Implied daily growth rate",
"source": "app",
"y_axis_label": "Growth rate, d\u207b\u00b9",
"lookback": 100000,
"y_transformation": "(y) => 24 * y",
"y_axis_domain": [
-0.1,
1.0
"chart_key": "fraction_of_volume_that_is_alternative_media",
"data_source": "alt_media_fractions",
"title": "Fraction of volume that is alternative media",
"source": "app",
"y_axis_label": "Fraction",
"fixed_decimals": 3,
"down_sample": false,
"mqtt_topic": "bioreactor/alt_media_fraction",
"lookback": 100000,
"data_source_column": "alt_media_fraction",
"payload_key": null,
"y_axis_domain": [
0.0,
0.05
Get Shared Config
Get Shared Config endpoint.
Endpoint
GET /api/config/shared
Response
Success
Status: 200 OK
Response body is plain text.
Update Shared Config
Update Shared Config endpoint.
Endpoint
PATCH /api/config/shared
Request
Request Body
| code | string | Yes | code. |
"code": "[section]\nkey=value\n"
Response
Success
Status: 200 OK
Example body:
"status": "success"
Endpoint
PUT /api/config/shared
Request
Request Body
Response
Success
Status: 200 OK
Example body:
"status": "success"
Get Shared Config History
Get Shared Config History endpoint.
Endpoint
GET /api/config/shared/history
Response
Success
Status: 200 OK
Example body:
"filename": "config.ini",
"timestamp": "2026-09-03T18:56:20.786Z",
"data": "[PWM]\n# map the externals to the PWM\n# hardware PWM are available on channels 1 & 3.\n1=stirring\n2=waste\n3=media\n4=air_bubbler\n5=heating\n\n\n[leds]\nA=IR\nB=white_light\nC=\nD=\n\n\n[bioreactor]\n# efflux_tube_volume_ml is determined by the volume that just touches the outflow tube. I.e. if you\n# where to keep running the waste pump, what would the stable volume be.\n# see docs\nefflux_tube_volume_ml=14\ninitial_volume_ml=14\ninitial_alt_media_fraction=0.0\ninitial_cumulative_media_added_ml=0\ninitial_cumulative...<truncated>"
"timestamp": "2026-08-04T21:28:03.520Z",
"data": "[PWM]\n# map the externals to the PWM\n# hardware PWM are available on channels 1 & 3.\n1=stirring\n2=waste\n3=media\n4=alt_media\n5=heating\n\n\n[leds]\nA=IR\nB=white_light\nC=\nD=\n\n\n[bioreactor]\n# efflux_tube_volume_ml is determined by the volume that just touches the outflow tube. I.e. if you\n# where to keep running the waste pump, what would the stable volume be.\n# see docs\nefflux_tube_volume_ml=14\ninitial_volume_ml=14\ninitial_alt_media_fraction=0.0\ninitial_cumulative_media_added_ml=0\ninitial_cumulative_a...<truncated>"
"timestamp": "2026-08-04T21:27:21.754Z",
Get Config For Pioreactor Unit
Get merged configs, optionally limiting $broadcast with repeated unit query parameters.
Endpoint
GET /api/config/units/{pioreactor_unit}
Request
Path Parameters
| pioreactor_unit | string | Yes | Unit name or $broadcast where supported. |
Response
Success
Status: 200 OK
Example body:
"configs": {
"localhost": {
"PWM": {
"1": "stirring",
"2": "waste",
"3": "media",
"4": "air_bubbler",
"5": "heating"
"leds": {
"A": "IR",
"B": "white_light",
"C": "",
"D": ""
"bioreactor": {
"efflux_tube_volume_ml": "14",
"initial_volume_ml": "14",
"initial_alt_media_fraction": "0.0",
"initial_cumulative_media_added_ml": "0",
"initial_cumulative_alt_media_added_ml": "0",
"initial_cumulative_waste_removed_ml": "0"
"stirring.config": {
"initial_target_rpm": "500",
"initial_duty_cycle": "15",
"pwm_hz": "200",
"use_rpm": "True",
"duration_between_updates_seconds": "23",
"post_delay_duration": "0.25",
"pre_delay_duration": "0.25",
"enable_dodging_od": "true",
"target_rpm_during_od_reading": "0",
"target_rpm_outside_od_reading": "500"
"dosing_automation.turbidostat": {
"biomass_signal": "auto"
"stirring.pid": {
"Kp": "0.007",
"Ki": "0.0",
"Kd": "0.0"
"od_config.photodiode_channel": {
"1": "REF",
"2": "90"
"od_reading.config": {
"samples_per_second": "0.2",
"turn_off_leds_during_reading": "1",
"pd_reference_ema": "0.4",
"ir_led_intensity": "80",
"duration_between_led_off_and_od_reading": "0.1",
"smoothing_penalizer": "6.0",
"use_dark_offsets": "1"
"camera": {
"snapshot_interval_minutes": "5",
"camera_index": "0",
"ir_led_intensity": "90",
"enabled": "1",
"keep_camera_active": "0"
"storage": {
"database": "/Users/camerondavidson-pilon/code/pioreactor/.pioreactor/storage/pioreactor.sqlite",
"temporary_cache": "/Users/camerondavidson-pilon/code/pioreactor/.pioreactor/storage/local_intermittent_pioreactor_metadata.sqlite",
"persistent_cache": "/Users/camerondavidson-pilon/code/pioreactor/.pioreactor/storage/local_persistent_pioreactor_metadata.sqlite",
"number_of_backup_replicates_to_workers": "0"
"logging": {
"log_file": "./pioreactor.log",
"ui_log_file": "./pioreactor.log",
"ui_log_level": "DEBUG",
"console_log_level": "DEBUG"
"cluster.topology": {
"leader_hostname": "localhost",
"leader_address": "localhost"
"ui.overview.settings": {
"filtered_od_lookback_minutes": "240",
"raw_od_lookback_minutes": "240",
"log_display_count": "65",
"time_display_mode": "hours"
"ui": {
"port": "4999",
"proto": "http"
"ui.overview.charts": {
"implied_growth_rate": "1",
"implied_daily_growth_rate": "0",
"fraction_of_volume_that_is_alternative_media": "1",
"normalized_optical_density": "1",
"raw_optical_density": "1",
"temperature": "1",
"optical_density": "1"
"ui.overview.cards": {
"dosings": "1",
"event_logs": "1",
"profiles": "1"
"dosing_automation.pid_morbidostat": {
"Kp": "5",
"Ki": "0",
"Kd": "0"
"temperature_automation.thermostat": {
"Kp": ".01",
"Ki": ".01",
"Kd": ".01"
"mqtt": {
"username": "pioreactor",
"password": "raspberry",
"broker_address": "localhost",
"broker_ws_port": "9001",
"broker_port": "1883",
"ws_protocol": "ws",
"use_tls": "0"
"dosing_automation.config": {
"pause_between_subdoses_seconds": "0.5",
"waste_removal_multiplier": "2.0",
"max_volume_to_warn": "17.0",
"max_subdose": "1.0",
"experimental_pump_malfunction_tolerance": "0.2",
"experimental_detect_pump_malfunction": "False"
"errors": {}
Get Specific Config For Pioreactor Unit
Get Specific Config For Pioreactor Unit endpoint.
Endpoint
GET /api/config/units/{pioreactor_unit}/specific
Request
Path Parameters
Response
Success
Status: 200 OK
Update Specific Config For Pioreactor Unit
Update Specific Config For Pioreactor Unit endpoint.
Endpoint
PATCH /api/config/units/{pioreactor_unit}/specific
Request
Path Parameters
Request Body
Response
Success
Status: 200 OK
Example body:
"status": "success"
Endpoint
PUT /api/config/units/{pioreactor_unit}/specific
Request
Path Parameters
Request Body
Response
Success
Status: 200 OK
Example body:
"status": "success"
Get Specific Config History For Pioreactor Unit
Get Specific Config History For Pioreactor Unit endpoint.
Endpoint
GET /api/config/units/{pioreactor_unit}/specific/history
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
"filename": "unit_config.ini::localhost",
"timestamp": "2026-09-03T19:00:17.521Z",
"data": "[PWM]\n# map the externals to the PWM\n# hardware PWM are available on channels 1 & 3.\n1=stirring\n2=waste\n3=media\n4=air_bubbler\n5=heating"
"timestamp": "2026-04-08T00:58:21.686Z",
"data": "[PWM]\n# map the externals to the PWM\n# hardware PWM are available on channels 1 & 3.\n1=stirring\n2=waste\n3=media\n4=bubblert\n5=heating"
"timestamp": "2026-04-08T00:18:45.007Z",
"data": "[PWM]\n# map the externals to the PWM\n# hardware PWM are available on channels 1 & 3.\n1=stirring\n2=waste\n3=media\n4=bubbler\n5=heating"
Get Zipped Configs
Get Zipped Configs endpoint.
Endpoint
GET /api/config/zipped
Response
Success
Status: 200 OK
Response body is binary file data.
Get Exportable Datasets
Get Exportable Datasets endpoint.
Endpoint
GET /api/datasets/exportable
Response
Success
Status: 200 OK
Example body:
"dataset_name": "pioreactor_unit_activity_data",
"description": "This dataset includes most of your experiment data, including the time series of OD metrics, temperature, stirring rates, LED updates, and dosings.",
"display_name": "Pioreactor unit activity data (recommended)",
"has_experiment": true,
"has_unit": true,
"default_order_by": "timestamp",
"table": "pioreactor_unit_activity_data",
"query": null,
"source": "app",
"timestamp_columns": [
"timestamp"
"always_partition_by_unit": true,
"column_descriptions": {},
"column_units": {}
"dataset_name": "logs",
"description": "This dataset includes the append-only collection of logs from all Pioreactors. A subset of these logs are displayed in the Log Table in the Experiment Overview.",
"display_name": "Pioreactor logs",
"has_unit": true,
"table": "logs",
"query": null,
"source": "app",
"timestamp"
"always_partition_by_unit": false,
"column_units": {}
"dataset_name": "od_readings",
"description": "This dataset includes a time series of readings provided by the sensors (transformed via a calibration curve, if available), the inputs for growth calculations and normalized optical density.",
"display_name": "Optical density",
"has_unit": true,
"table": "od_readings",
"query": null,
"source": "app",
"timestamp"
"column_units": {}
Preview Exportable Dataset
Preview Exportable Dataset endpoint.
Endpoint
GET /api/datasets/exportable/{target_dataset}/preview
Request
Path Parameters
| target_dataset | string | Yes | Exportable dataset name. |
Response
Success
Status: 200 OK
Example body:
"timestamp": "2026-01-01T00:00:00Z",
"pioreactor_unit": "pio01",
"experiment": "testing_experiment"
Export Exportable Datasets
Export selected datasets for one experiment.
Endpoint
POST /api/datasets/exportable/export
Request
Request Body
| datasets | array | Yes | datasets. |
| experiment | string | Yes | experiment. |
| partition_by_unit | boolean | Yes | partition by unit. |
| end_time | object | No | end time. |
| partition_by_experiment | boolean | No | partition by experiment. |
| start_time | object | No | start time. |
"datasets": [
"od_readings"
"experiment": "testing_experiment",
"partition_by_unit": true,
"end_time": "2026-01-01T12:00:00Z",
"partition_by_experiment": true,
"start_time": "2026-01-01T00:00:00Z"
Response
Success
Status: 202 Accepted
Example body:
"unit": "pio01",
"task_id": "abcd1234",
"result_url_path": "/unit_api/task_results/abcd1234",
"status": "accepted"
Export Exportable Datasets To Usb
Export selected datasets for one experiment to the leader's mounted USB.
Endpoint
POST /api/datasets/exportable/export-to-usb
Request
Request Body
"datasets": [
"od_readings"
Response
Success
Example body:
"unit": "pio01",
Get Experiment Profiles
Get Experiment Profiles endpoint.
Endpoint
GET /api/experiment_profiles
Response
Success
Status: 200 OK
Example body:
"experimentProfile": {
"version": "1.0",
"experiment_profile_name": "updating_jobs",
"metadata": {
"author": "Cam Davidson-Pilon",
"description": "A profile to immediately start stirring, heating to 30C, and, after 2h, update temperature to 35C."
"plugins": [],
"common": {
"jobs": {
"stirring": {
"actions": "<truncated>",
"description": "<truncated>"
"temperature_automation": {
"pioreactors": {},
"inputs": {}
"file": "update_temp.yaml",
"fullpath": "/Users/camerondavidson-pilon/code/pioreactor/.pioreactor/experiment_profiles/update_temp.yaml"
"version": "1.0",
"experiment_profile_name": "test_simple1",
"metadata": {
"author": "Jane Doe",
"description": null
"plugins": [],
"common": {
"jobs": {
"od_reading": {
"pioreactors": {},
"inputs": {}
"file": "test_simple.yaml",
"fullpath": "/Users/camerondavidson-pilon/code/pioreactor/.pioreactor/experiment_profiles/test_simple.yaml"
"version": "1.0",
"experiment_profile_name": "temp_test",
"metadata": {
"author": null,
"description": "testing https://forum.pioreactor.com/t/writing-an-experimental-profile-based-on-a-temperature-automation-dependent-on-a-desired-od-reading/774"
"plugins": [],
"common": {
"jobs": {}
"pioreactors": {
"localhost": {
"jobs": {
"temperature_automation": "<truncated>"
"label": null
"inputs": {}
"file": "temp_test.yaml",
"fullpath": "/Users/camerondavidson-pilon/code/pioreactor/.pioreactor/experiment_profiles/temp_test.yaml"
Create Experiment Profile
Create an experiment profile YAML file.
Endpoint
POST /api/experiment_profiles
Request
Request Body
| body | string | Yes | body. |
| filename | string | Yes | filename. |
"body": "Profile YAML or text content.",
"filename": "profile.yaml"
Response
Success
Status: 200 OK
Example body:
"status": "success"
Delete Experiment Profile
Delete Experiment Profile endpoint.
Endpoint
DELETE /api/experiment_profiles/{filename}
Request
Path Parameters
| filename | string | Yes | Filename. |
Response
Success
Status: 200 OK
Example body:
"status": "success"
Get Experiment Profile endpoint.
Endpoint
GET /api/experiment_profiles/{filename}
Request
Path Parameters
Response
Success
Status: 200 OK
Update Experiment Profile
Update Experiment Profile endpoint.
Endpoint
PATCH /api/experiment_profiles/{filename}
Request
Path Parameters
Request Body
Response
Success
Status: 200 OK
Example body:
"status": "success"
Get Experiments
Get Experiments endpoint.
Endpoint
GET /api/experiments
Response
Success
Status: 200 OK
Example body:
"experiment": "khtfddecb",
"created_at": "2026-10-10T02:18:15.701Z",
"started_at": "2026-10-10T02:18:15.701Z",
"description": "",
"delta_hours": 612.0,
"worker_count": 0,
"tags": []
"experiment": "adwd",
"created_at": "2026-09-22T18:36:50.839Z",
"started_at": "2026-11-02T01:39:14.000Z",
"description": "This is a description text!\nqwd\n",
"delta_hours": 61.0,
"worker_count": 0,
"tags": []
"experiment": "BH Glycerol - Batch modffe - Take 3fef",
"created_at": "2026-09-05T00:39:41.297Z",
"started_at": "2026-09-05T00:39:41.297Z",
"description": "13:35 tet added\n",
"delta_hours": 1454.0,
"worker_count": 0,
"tags": []
Create Experiment
Create a new experiment.
Endpoint
POST /api/experiments
Request
Request Body
| description | string | No | description. |
| tags | array | No | tags. |
"description": "Experiment notes.",
"tags": [
"screening"
Response
Success
Status: 201 Created
Example body:
"created_at": "2026-01-01T00:00:00Z",
"started_at": "2026-01-01T00:00:00Z",
"delta_hours": 0,
"worker_count": 1,
"tags": [
"screening"
Delete Experiment
Delete Experiment endpoint.
Endpoint
DELETE /api/experiments/{experiment}
Request
Path Parameters
| experiment | string | Yes | Experiment identifier. |
Response
Success
Example body:
"unit": "pio01",
Get Experiment
Get Experiment endpoint.
Endpoint
GET /api/experiments/{experiment}
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
"description": "",
"worker_count": 0,
"tags": []
Update Experiment
Update Experiment endpoint.
Endpoint
PATCH /api/experiments/{experiment}
Request
Path Parameters
Request Body
| started_at | object | No | started at. |
"tags": [
"screening"
Response
Success
Status: 200 OK
Example body:
"delta_hours": 0,
"worker_count": 1,
"tags": [
"screening"
Get Camera Statuses For Experiment
Get Camera Statuses For Experiment endpoint.
Endpoint
GET /api/experiments/{experiment}/cameras
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
"cameras": {
"localhost": {
"ok": true,
"unit": "localhost",
"value": {
"detection_status": "detected",
"runtime_available": true,
"capture_command": null,
"mock": true,
"latest_still": {
"captured_at": "2026-11-04T15:07:00.570920Z",
"image_id": "20261104T150700.570920Z-90eec877",
"capture_reason": "scheduled"
"auto_capture_enabled": true,
"snapshot_interval_minutes": 5
Get Experiment Chart Preferences
Get Experiment Chart Preferences endpoint.
Endpoint
GET /api/experiments/{experiment}/chart_preferences
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
"overview_chart_keys": null,
"pioreactor_chart_keys": null
Update Experiment Chart Preferences
Update Experiment Chart Preferences endpoint.
Endpoint
PATCH /api/experiments/{experiment}/chart_preferences
Request
Path Parameters
Request Body
| overview_chart_keys | array | No | overview chart keys. |
| pioreactor_chart_keys | array | No | pioreactor chart keys. |
"overview_chart_keys": [],
"pioreactor_chart_keys": []
Response
Success
Status: 200 OK
No example body inferred.
Get Recent Experiment Profile Runs
Get Recent Experiment Profile Runs endpoint.
Endpoint
GET /api/experiments/{experiment}/experiment_profiles/recent
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
Get Running Profiles
Get Running Profiles endpoint.
Endpoint
GET /api/experiments/{experiment}/experiment_profiles/running
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
Get List Of Historical Workers For Experiment
Get List Of Historical Workers For Experiment endpoint.
Endpoint
GET /api/experiments/{experiment}/historical_worker_assignments
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
"pioreactor_unit": "localhost",
"is_currently_assigned_to_experiment": 0
Get Exp Logs
Shows event logs from all units, uses pagination.
Endpoint
GET /api/experiments/{experiment}/logs
Request
Path Parameters
Query Parameters
| min_level | string | No | min level. |
Response
Success
Status: 200 OK
Example body:
"level": "INFO",
"message": "Log message.",
"task": "stirring",
"source": "app",
Get Media Rates
Shows amount of added media per unit. Note that it only consider values from a dosing automation (i.e. not manual dosing, which includes continously dose)
Endpoint
GET /api/experiments/{experiment}/media_rates
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
"all": {
"altMediaRate": 0.0,
"mediaRate": 0.0
Get Recent Logs
Shows recent event logs from all units
Endpoint
GET /api/experiments/{experiment}/recent_logs
Request
Path Parameters
Query Parameters
Response
Success
Status: 200 OK
Example body:
"level": "INFO",
"task": "stirring",
"source": "app",
Get Fallback Time Series
Get Fallback Time Series endpoint.
Endpoint
GET /api/experiments/{experiment}/time_series/{data_source}/{column}
Request
Path Parameters
| data_source | string | Yes | Time-series data source name. |
| column | string | Yes | Dataset column name. |
Response
Success
Status: 200 OK
Body shape: series is a list of series labels. data is a parallel list of point arrays, so data[i] contains the points for series[i]. Each point has x as an ISO-8601 UTC timestamp string and y as a number.
Example body:
"series": [
"pio01",
"pio02"
"data": [
"x": "2026-01-01T00:00:00.000Z",
"y": 0.01234
"x": "2026-01-01T00:01:00.000Z",
"y": 0.0125
"y": 0.00987
"y": 0.01001
Get Growth Rates
Gets growth rates for all units
Endpoint
GET /api/experiments/{experiment}/time_series/growth_rates
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
"series": [
"pio01",
"pio02"
"data": [
"y": 0.01234
"y": 0.0125
"y": 0.00987
"y": 0.01001
Get Od Readings
Gets raw od for all units
Endpoint
GET /api/experiments/{experiment}/time_series/od_readings
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
"series": [
"pio01",
"pio02"
"data": [
"y": 0.01234
"y": 0.0125
"y": 0.00987
"y": 0.01001
Get Od Readings Filtered
Gets normalized od for all units
Endpoint
GET /api/experiments/{experiment}/time_series/od_readings_filtered
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
"series": [
"pio01",
"pio02"
"data": [
"y": 0.01234
"y": 0.0125
"y": 0.00987
"y": 0.01001
Get Od Readings Fused
Get Od Readings Fused endpoint.
Endpoint
GET /api/experiments/{experiment}/time_series/od_readings_fused
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
"series": [
"pio01",
"pio02"
"data": [
"y": 0.01234
"y": 0.0125
"y": 0.00987
"y": 0.01001
Get Od Raw Readings
Endpoint
GET /api/experiments/{experiment}/time_series/raw_od_readings
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
"series": [
"pio01",
"pio02"
"data": [
"y": 0.01234
"y": 0.0125
"y": 0.00987
"y": 0.01001
Get Temperature Readings
Gets temperature readings for all units
Endpoint
GET /api/experiments/{experiment}/time_series/temperature_readings
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
"series": [
"pio01",
"pio02"
"data": [
"y": 0.01234
"y": 0.0125
"y": 0.00987
"y": 0.01001
Get Unit Labels
Get Unit Labels endpoint.
Endpoint
GET /api/experiments/{experiment}/unit_labels
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
Upsert Unit Labels
Update or insert a new unit label for the current experiment.
Endpoint
PATCH /api/experiments/{experiment}/unit_labels
Request
Path Parameters
Request Body
| label | string | Yes | label. |
| unit | string | Yes | unit. |
"label": "Control",
"unit": "example_unit"
Response
Success
Status: 201 Created
Example body:
"status": "success"
Upsert Unit Labels
Endpoint
PUT /api/experiments/{experiment}/unit_labels
Request
Path Parameters
Request Body
"label": "Control",
Response
Success
Status: 201 Created
Example body:
"status": "success"
Remove Workers From Experiment
Remove Workers From Experiment endpoint.
Endpoint
DELETE /api/experiments/{experiment}/workers
Request
Path Parameters
Response
Success
Example body:
"unit": "pio01",
Get List Of Workers For Experiment
Get List Of Workers For Experiment endpoint.
Endpoint
GET /api/experiments/{experiment}/workers
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
Add Worker To Experiment
Assign a worker, treating a retry of the current assignment as a no-op.
Endpoint
PUT /api/experiments/{experiment}/workers
Request
Path Parameters
Request Body
| pioreactor_unit | string | Yes | pioreactor unit. |
"pioreactor_unit": "pio02"
Response
Success
Status: 200 OK
Example body:
"status": "success"
Remove Worker From Experiment
Remove Worker From Experiment endpoint.
Endpoint
DELETE /api/experiments/{experiment}/workers/{pioreactor_unit}
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
"status": "success"
Get Active Experiments
Get list of experiments with at least one active worker assigned
Endpoint
GET /api/experiments/active
Response
Success
Status: 200 OK
Example body:
"experiment": "Glc-02 (Jun 9 25)",
"created_at": "2025-06-09T21:01:59.620Z",
"started_at": "2025-06-09T21:01:59.620Z",
"description": "",
"delta_hours": 12306.0,
"worker_count": 1,
"tags": []
Get Experiments Worker Assignments
Get Experiments Worker Assignments endpoint.
Endpoint
GET /api/experiments/assignment_count
Response
Success
Status: 200 OK
Example body:
"worker_count": 1
Get Latest Experiment
Get Latest Experiment endpoint.
Endpoint
GET /api/experiments/latest
Response
Success
Status: 200 OK
Example body:
"description": "",
"worker_count": 0,
"tags": []
Get Job Descriptors
Return the leader's background-job UI descriptors.
Endpoint
GET /api/jobs/descriptors
Response
Success
Status: 200 OK
Example body:
"display_name": "Stirring",
"job_name": "stirring",
"display": true,
"published_settings": [
"key": "target_rpm",
"type": "numeric",
"display": true,
"description": "Modify the target RPM of stirring. This will effect the optical density reading. Too low and the stirring may completely stop. Too high and the resulting vortex may interfere with the optics.",
"default": null,
"unit": "RPM",
"label": "Target stir RPM",
"editable": true,
"min": null,
"max": null
"source": "app",
"description": "Start the stirring on the Pioreactor. Stirring is needed for mixing and proper OD measurements.",
"subtext": null,
"is_testing": false
"job_name": "od_reading",
"display": true,
"published_settings": [],
"source": "app",
"description": "Collect optical density measurements of the culture over time.",
"subtext": null,
"is_testing": false
"display_name": "Growth rate",
"job_name": "growth_rate_calculating",
"display": true,
"source": "app",
"description": "Transform optical density measurements into culture growth rate measurements. Start this after innoculation. Begins by sampling for a few minutes to gather a baseline.",
"subtext": null,
"is_testing": false
Get Local Access Point
Get Local Access Point endpoint.
Endpoint
GET /api/local_access_point
Response
Success
Status: 200 OK
Example body:
"active": false
Get Logs
Endpoint
GET /api/logs
Request
Query Parameters
Response
Success
Status: 200 OK
Example body:
"level": "INFO",
"task": "stirring",
"source": "app",
Get Models
Return the list of supported Pioreactor models (name, version, display_name).
Endpoint
GET /api/models
Response
Success
Status: 200 OK
Example body:
"models": [
"model_name": "pioreactor_40ml",
"model_version": "1.5",
"display_name": "Pioreactor 40ml, v1.5",
"reactor_capacity_ml": 40.0,
"reactor_diameter_mm": 27.0,
"reactor_max_fill_volume_ml": 33.0,
"max_temp_to_reduce_heating": 78.0,
"max_temp_to_disable_heating": 80.0,
"max_temp_to_shutdown": 85.0,
"is_legacy": false,
"is_contrib": false
"model_version": "1.0",
"display_name": "Pioreactor 40ml, v1.0",
"is_legacy": true,
"is_contrib": false
"model_name": "pioreactor_20ml",
"model_version": "1.1",
"display_name": "Pioreactor 20ml, v1.1",
"reactor_capacity_ml": 20.0,
"reactor_max_fill_volume_ml": 18.0,
"is_legacy": true,
"is_contrib": false
Get Settings Descriptors
Return the leader's settings UI descriptors.
Endpoint
GET /api/settings/descriptors
Response
Success
Status: 200 OK
Example body:
"key": "bioreactor",
"display_name": "Bioreactor",
"display": true,
"key": "current_volume_ml",
"type": "numeric",
"display": true,
"description": "Current estimated liquid volume in the vial.",
"default": 14.0,
"unit": "mL",
"label": "Current volume",
"editable": true,
"min": 0.0,
"max": null
"key": "efflux_tube_volume_ml",
"type": "numeric",
"display": true,
"description": "Liquid volume equivalent to the height of the waste/efflux tube.",
"default": 14.0,
"unit": "mL",
"label": "Efflux tube level",
"editable": true,
"min": 0.0,
"max": null
"key": "alt_media_fraction",
"type": "numeric",
"display": true,
"description": "Fraction of the current volume estimated to be alt media.",
"default": 0.0,
"unit": null,
"label": "Alt media fraction",
"editable": true,
"min": 0.0,
"max": 1.0
"source": "app",
"description": "Per-unit bioreactor settings.",
"subtext": null
"key": "leds",
"display_name": "led intensity",
"display": false,
"key": "intensity",
"type": "string",
"display": true,
"description": null,
"default": null,
"unit": null,
"label": "LED intensity",
"editable": false,
"min": null,
"max": null
"source": "app",
"subtext": null
"key": "pwms",
"display_name": "PWMs",
"display": false,
"key": "dc",
"type": "string",
"display": true,
"default": null,
"unit": null,
"label": "PWM intensity",
"editable": false,
"min": null,
"max": null
"source": "app",
"subtext": null
Update App From Release Archive
Update the Pioreactor app across the cluster from a staged release archive.
Endpoint
POST /api/system/update_from_archive
Request
Request Body
| release_archive_location | string | Yes | release archive location. |
| units | string | Yes | units. |
"release_archive_location": "/tmp/release.zip",
"units": "pio01"
Response
Success
Example body:
"unit": "pio01",
Update App
Update the Pioreactor app across the cluster to the next version.
Endpoint
POST /api/system/update_next_version
Request
Request Body
| units | string | No | units. |
"units": "pio01"
Response
Success
Example body:
"unit": "pio01",
Upload System File
Stage a release archive or other system file on the leader.
Endpoint
POST /api/system/upload
Response
Success
Status: 201 Created
Example body:
"message": "File successfully uploaded",
"save_path": "/tmp/file.zip"
Set System Utc Clock
Set the leader UTC clock, then sync workers from the leader.
Endpoint
POST /api/system/utc_clock
Request
Request Body
| utc_clock_time | string | Yes | utc clock time. |
"utc_clock_time": "2026-01-01T00:00:00Z"
Response
Success
Example body:
"unit": "pio01",
Get List Of Units
Get List Of Units endpoint.
Endpoint
GET /api/units
Response
Success
Status: 200 OK
Example body:
Get Capabilities
Get Capabilities endpoint.
Endpoint
GET /api/units/{pioreactor_unit}/capabilities
Request
Path Parameters
Response
Success
Example body:
"task_id": "1c415fc6-0ea3-40db-b9cd-f2484d0512ec",
"result_url_path": "/unit_api/task_results/1c415fc6-0ea3-40db-b9cd-f2484d0512ec",
Publish New Log
Publish a log message into an experiment log stream.
Endpoint
POST /api/units/{pioreactor_unit}/experiments/{experiment}/logs
Request
Path Parameters
Request Body
| level | string | Yes | level. |
| message | string | Yes | message. |
| source | string | Yes | source. |
| timestamp | string | Yes | timestamp. |
| source_ | string | No | source . |
| task | string | No | task. |
"level": "INFO",
"source": "api",
"source_": "api",
"task": "stirring"
Response
Success
Example body:
Import Dot Pioreactor Archive
Import a zipped DOT_PIOREACTOR archive into one unit.
Endpoint
POST /api/units/{pioreactor_unit}/import_zipped_dot_pioreactor
Request
Path Parameters
Response
Success
Status: 201 Created
Run Job On Unit In Experiment
Runs specified job on unit.
Endpoint
PATCH /api/units/{pioreactor_unit}/jobs/run/job_name/{job_name}/experiments/{experiment}
Request
Path Parameters
| job_name | string | Yes | Job name. |
Request Body
| args | array | No | args. |
| config_overrides | array | No | config overrides. |
| env | object | No | env. |
| options | object | No | options. |
"options": {
"target_rpm": "200"
"env": {
"JOB_SOURCE": "api"
"args": [
"some-flag"
"config_overrides": [
"stirring.config",
"pwm_hz",
"100"
Response
Success
Example body:
"unit": "pio01",
Endpoint
POST /api/units/{pioreactor_unit}/jobs/run/job_name/{job_name}/experiments/{experiment}
Request
Path Parameters
Request Body
"options": {
"target_rpm": "200"
"env": {
"JOB_SOURCE": "api"
"args": [
"some-flag"
"stirring.config",
"pwm_hz",
"100"
Response
Success
Example body:
"unit": "pio01",
Get Jobs Running
Get Jobs Running endpoint.
Endpoint
GET /api/units/{pioreactor_unit}/jobs/running
Request
Path Parameters
Response
Success
Example body:
"task_id": "b8260b0c-84a6-448a-a804-71cf74ef2da4",
"result_url_path": "/unit_api/task_results/b8260b0c-84a6-448a-a804-71cf74ef2da4",
Stop All Jobs On Unit For Experiment
Stop all jobs for one unit, or $broadcast, in one experiment.
Endpoint
PATCH /api/units/{pioreactor_unit}/jobs/stop/experiments/{experiment}
Request
Path Parameters
Response
Success
Example body:
"status": "success"
Endpoint
POST /api/units/{pioreactor_unit}/jobs/stop/experiments/{experiment}
Request
Path Parameters
Response
Success
Example body:
"status": "success"
Stop Specific Job On Unit
Stop one job on one unit in one experiment.
Endpoint
PATCH /api/units/{pioreactor_unit}/jobs/stop/job_name/{job_name}/experiments/{experiment}
Request
Path Parameters
Response
Success
Example body:
"unit": "pio01",
Endpoint
POST /api/units/{pioreactor_unit}/jobs/stop/job_name/{job_name}/experiments/{experiment}
Request
Path Parameters
Response
Success
Example body:
"unit": "pio01",
Update Job On Unit
Update specified job on unit. Use $broadcast for everyone.
Endpoint
PATCH /api/units/{pioreactor_unit}/jobs/update/job_name/{job_name}/experiments/{experiment}
Request
Path Parameters
Request Body
| settings | object | Yes | settings. |
"settings": {
"target_rpm": "200"
Response
Success
Example body:
Get Logs For Unit
Endpoint
GET /api/units/{pioreactor_unit}/logs
Request
Path Parameters
Query Parameters
Response
Success
Status: 200 OK
Example body:
"level": "INFO",
"task": "stirring",
"source": "app",
Install Plugin Across Cluster
Install one plugin on one unit, or $broadcast.
Endpoint
PATCH /api/units/{pioreactor_unit}/plugins/install
Request
Path Parameters
Request Body
"args": [
"some-flag"
"env": {
"JOB_SOURCE": "api"
"options": {
"target_rpm": "200"
Response
Success
Example body:
"unit": "pio01",
Endpoint
POST /api/units/{pioreactor_unit}/plugins/install
Request
Path Parameters
Request Body
"args": [
"some-flag"
"env": {
"JOB_SOURCE": "api"
"options": {
"target_rpm": "200"
Response
Success
Example body:
"unit": "pio01",
Install Plugin From Leader Usb On Machine
Install one plugin artifact from the leader's Pioreactor-managed USB mount onto selected unit(s).
Endpoint
PATCH /api/units/{pioreactor_unit}/plugins/install-from-leader-usb
Request
Path Parameters
Request Body
| filepath | string | Yes | filepath. |
"filepath": "example_filepath"
Response
Success
Example body:
"unit": "pio01",
Endpoint
POST /api/units/{pioreactor_unit}/plugins/install-from-leader-usb
Request
Path Parameters
Request Body
Response
Success
Example body:
"unit": "pio01",
Get Plugins On Machine
Get Plugins On Machine endpoint.
Endpoint
GET /api/units/{pioreactor_unit}/plugins/installed
Request
Path Parameters
Response
Success
Example body:
"task_id": "72de709a-c4d1-4054-b7ad-d1b135f271cc",
"result_url_path": "/unit_api/task_results/72de709a-c4d1-4054-b7ad-d1b135f271cc",
Uninstall Plugin Across Cluster
Uninstall one plugin from one unit, or $broadcast.
Endpoint
PATCH /api/units/{pioreactor_unit}/plugins/uninstall
Request
Path Parameters
Request Body
"args": [
"some-flag"
"env": {
"JOB_SOURCE": "api"
"options": {
"target_rpm": "200"
Response
Success
Example body:
"unit": "pio01",
Endpoint
POST /api/units/{pioreactor_unit}/plugins/uninstall
Request
Path Parameters
Request Body
"args": [
"some-flag"
"env": {
"JOB_SOURCE": "api"
"options": {
"target_rpm": "200"
Response
Success
Example body:
"unit": "pio01",
Reboot Unit
Reboot one unit, or $broadcast.
Endpoint
POST /api/units/{pioreactor_unit}/system/reboot
Request
Path Parameters
Response
Success
Status: 201 Created
No success response body.
Repair Unit
Repair filesystem permissions on one unit, or $broadcast.
Endpoint
POST /api/units/{pioreactor_unit}/system/repair
Request
Path Parameters
Response
Success
Status: 201 Created
Shutdown Unit
Shut down one unit, or $broadcast.
Endpoint
POST /api/units/{pioreactor_unit}/system/shutdown
Request
Path Parameters
Response
Success
Status: 201 Created
Get Unit Utc Clock
Get Unit Utc Clock endpoint.
Endpoint
GET /api/units/{pioreactor_unit}/system/utc_clock
Request
Path Parameters
Response
Success
Example body:
"task_id": "491ba374-5fec-4c37-a85d-f57c5f1a4bf5",
"result_url_path": "/unit_api/task_results/491ba374-5fec-4c37-a85d-f57c5f1a4bf5",
Get System Logs For Unit
Shows system logs from specific unit uses pagination.
Endpoint
GET /api/units/{pioreactor_unit}/system_logs
Request
Path Parameters
Query Parameters
Response
Success
Status: 200 OK
Example body:
"level": "INFO",
"task": "stirring",
"source": "app",
Get Usb Status On Machine
Get Usb Status On Machine endpoint.
Endpoint
GET /api/units/{pioreactor_unit}/usb
Request
Path Parameters
Response
Success
Example body:
"task_id": "d9ceb049-fd1b-42e5-b0b1-832c27d1f734",
"result_url_path": "/unit_api/task_results/d9ceb049-fd1b-42e5-b0b1-832c27d1f734",
Get Usb Artifacts On Machine
Get Usb Artifacts On Machine endpoint.
Endpoint
GET /api/units/{pioreactor_unit}/usb/artifacts
Request
Path Parameters
Response
Success
Example body:
"task_id": "f0d05c88-6ac5-4c68-b8eb-715bc706d2df",
"result_url_path": "/unit_api/task_results/f0d05c88-6ac5-4c68-b8eb-715bc706d2df",
Eject Usb On Machine
Eject Usb On Machine endpoint.
Endpoint
POST /api/units/{pioreactor_unit}/usb/eject
Request
Path Parameters
Request Body
| device | string | No | device. |
"device": "example_device"
Response
Success
Example body:
"unit": "pio01",
Mount Usb On Machine
Mount Usb On Machine endpoint.
Endpoint
POST /api/units/{pioreactor_unit}/usb/mount
Request
Path Parameters
Request Body
Response
Success
Example body:
"unit": "pio01",
Get App Versions
Get App Versions endpoint.
Endpoint
GET /api/units/{pioreactor_unit}/versions/app
Request
Path Parameters
Response
Success
Example body:
"task_id": "73e59c01-7bfa-4ab9-8919-40689c2b3bbb",
"result_url_path": "/unit_api/task_results/73e59c01-7bfa-4ab9-8919-40689c2b3bbb",
Get Zipped Dot Pioreactor
Download a ZIP of ~/.pioreactor from one or all workers.
Endpoint
GET /api/units/{pioreactor_unit}/zipped_dot_pioreactor
Request
Path Parameters
Response
Success
Status: 200 OK
Get List Of Workers
Get List Of Workers endpoint.
Endpoint
GET /api/workers
Response
Success
Status: 200 OK
Example body:
"added_at": "2025-10-03T14:12:44.444Z",
"is_active": 1,
"ipv4_address": null
Add Worker
Register a worker without changing an existing worker on retry.
Endpoint
PUT /api/workers
Request
Request Body
| model_name | string | No | model name. |
| model_version | string | No | model version. |
"pioreactor_unit": "pio02",
Response
Success
Status: 200 OK
Example body:
"status": "success"
Delete Worker
Delete Worker endpoint.
Endpoint
DELETE /api/workers/{pioreactor_unit}
Request
Path Parameters
Response
Success
Example body:
"status": "success"
Get Worker
Get Worker endpoint.
Endpoint
GET /api/workers/{pioreactor_unit}
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
"is_active": 1,
Get All Active Calibrations
Get All Active Calibrations endpoint.
Endpoint
GET /api/workers/{pioreactor_unit}/active_calibrations
Request
Path Parameters
Response
Success
Example body:
"task_id": "4e6052c6-a4be-4f3b-92c6-e4067e9ae00e",
"result_url_path": "/unit_api/task_results/4e6052c6-a4be-4f3b-92c6-e4067e9ae00e",
Remove Active Status Calibration
Remove Active Status Calibration endpoint.
Endpoint
DELETE /api/workers/{pioreactor_unit}/active_calibrations/{device}
Request
Path Parameters
| device | string | Yes | Target device name. |
Response
Success
Example body:
"unit": "pio01",
Set Active Calibration
Set Active Calibration endpoint.
Endpoint
PATCH /api/workers/{pioreactor_unit}/active_calibrations/{device}/{calibration_name}
Request
Path Parameters
| calibration_name | string | Yes | Calibration name. |
Response
Success
Example body:
"unit": "pio01",
Get All Active Estimators
Get All Active Estimators endpoint.
Endpoint
GET /api/workers/{pioreactor_unit}/active_estimators
Request
Path Parameters
Response
Success
Example body:
"task_id": "644c125e-a82a-4a89-b24f-83d217cdd8c1",
"result_url_path": "/unit_api/task_results/644c125e-a82a-4a89-b24f-83d217cdd8c1",
Remove Active Status Estimator
Remove Active Status Estimator endpoint.
Endpoint
DELETE /api/workers/{pioreactor_unit}/active_estimators/{device}
Request
Path Parameters
Response
Success
Example body:
"unit": "pio01",
Set Active Estimator
Set Active Estimator endpoint.
Endpoint
PATCH /api/workers/{pioreactor_unit}/active_estimators/{device}/{estimator_name}
Request
Path Parameters
| estimator_name | string | Yes | Estimator name. |
Response
Success
Example body:
"unit": "pio01",
Get Automation Descriptors For Worker
Proxy a request for automation UI descriptors to one worker.
Endpoint
GET /api/workers/{pioreactor_unit}/automations/descriptors/{automation_type}
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
"source": null,
"fields": []
"source": null,
"fields": [
"default": 30,
"disabled": false,
"required": true,
"unit": "\u2103",
"type": "numeric",
"options": null
Update Bioreactor On Unit
Update Bioreactor On Unit endpoint.
Endpoint
PATCH /api/workers/{pioreactor_unit}/bioreactor/update/experiments/{experiment}
Request
Path Parameters
Request Body
| values | object | Yes | values. |
"values": {
"current_volume_ml": 12.5
Response
Success
Example body:
"unit": "pio01",
Blink Worker
Ask one worker's monitor job to blink its response LED.
Endpoint
POST /api/workers/{pioreactor_unit}/blink
Request
Path Parameters
Response
Success
Example body:
Get Calibration Protocols
Get Calibration Protocols endpoint.
Endpoint
GET /api/workers/{pioreactor_unit}/calibration_protocols
Request
Path Parameters
Response
Success
Example body:
"task_id": "cc267be6-9508-451b-baa7-8f99651884cb",
"result_url_path": "/unit_api/task_results/cc267be6-9508-451b-baa7-8f99651884cb",
Get All Calibrations
Get All Calibrations endpoint.
Endpoint
GET /api/workers/{pioreactor_unit}/calibrations
Request
Path Parameters
Response
Success
Example body:
"task_id": "fc9c4662-458d-4b37-82c6-df6b35a8e2f2",
"result_url_path": "/unit_api/task_results/fc9c4662-458d-4b37-82c6-df6b35a8e2f2",
Get Calibrations
Get Calibrations endpoint.
Endpoint
GET /api/workers/{pioreactor_unit}/calibrations/{device}
Request
Path Parameters
Response
Success
Example body:
"task_id": "ff316e3c-12de-43a5-bcd2-46fec8f6c13e",
"result_url_path": "/unit_api/task_results/ff316e3c-12de-43a5-bcd2-46fec8f6c13e",
Create Calibration
Create a calibration on one worker, or $broadcast.
Endpoint
POST /api/workers/{pioreactor_unit}/calibrations/{device}
Request
Path Parameters
Request Body
| calibration_data | string | Yes | calibration data. |
| set_as_active | boolean | No | set as active. |
"calibration_data": "calibration_type: simple_peristaltic_pump\ncalibration_name: example_calibration\n",
"set_as_active": true
Response
Success
Example body:
"unit": "pio01",
Delete Calibration
Delete Calibration endpoint.
Endpoint
DELETE /api/workers/{pioreactor_unit}/calibrations/{device}/{calibration_name}
Request
Path Parameters
Response
Success
Example body:
"unit": "pio01",
Get Calibration
Get Calibration endpoint.
Endpoint
GET /api/workers/{pioreactor_unit}/calibrations/{device}/{calibration_name}
Request
Path Parameters
Response
Success
Example body:
"task_id": "43265c97-0504-4bb3-938a-e506ec6651d8",
"result_url_path": "/unit_api/task_results/43265c97-0504-4bb3-938a-e506ec6651d8",
Start Calibration Session
Start a browser-driven calibration session on one worker.
Endpoint
POST /api/workers/{pioreactor_unit}/calibrations/sessions
Request
Path Parameters
Request Body
| protocol_name | string | Yes | protocol name. |
| target_device | string | Yes | target device. |
"protocol_name": "example_protocol_name",
"target_device": "example_target_device"
Response
Success
Status: 201 Created
Get Calibration Session
Get Calibration Session endpoint.
Endpoint
GET /api/workers/{pioreactor_unit}/calibrations/sessions/{session_id}
Request
Path Parameters
| session_id | string | Yes | Calibration session identifier. |
Response
Success
Status: 200 OK
Abort Calibration Session
Abort a calibration session on one worker.
Endpoint
POST /api/workers/{pioreactor_unit}/calibrations/sessions/{session_id}/abort
Request
Path Parameters
Response
Success
Status: 201 Created
Advance Calibration Session
Submit inputs for the current step of a calibration session.
Endpoint
POST /api/workers/{pioreactor_unit}/calibrations/sessions/{session_id}/inputs
Request
Path Parameters
Request Body
| inputs | object | No | inputs. |
"inputs": {}
Response
Success
Status: 201 Created
Get Camera Status For Worker
Get Camera Status For Worker endpoint.
Endpoint
GET /api/workers/{pioreactor_unit}/camera/experiments/{experiment}/status
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
"mock": true,
"latest_still": {
List Camera Stills For Worker Experiment
List Camera Stills For Worker Experiment endpoint.
Endpoint
GET /api/workers/{pioreactor_unit}/camera/experiments/{experiment}/stills
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
"stills": [
Capture Camera Still For Worker Experiment
Capture Camera Still For Worker Experiment endpoint.
Endpoint
POST /api/workers/{pioreactor_unit}/camera/experiments/{experiment}/stills
Request
Path Parameters
Response
Success
Example body:
"unit": "pio01",
Get Zipped Camera Stills For Worker Experiment
Get Zipped Camera Stills For Worker Experiment endpoint.
Endpoint
GET /api/workers/{pioreactor_unit}/camera/experiments/{experiment}/stills.zip
Request
Path Parameters
Response
Success
Status: 200 OK
Delete Camera Still For Worker Experiment
Delete Camera Still For Worker Experiment endpoint.
Endpoint
DELETE /api/workers/{pioreactor_unit}/camera/experiments/{experiment}/stills/{image_id}.jpg
Request
Path Parameters
| image_id | string | Yes | image id. |
Response
Success
Status: 200 OK
Get Camera Still For Worker Experiment
Get Camera Still For Worker Experiment endpoint.
Endpoint
GET /api/workers/{pioreactor_unit}/camera/experiments/{experiment}/stills/{image_id}.jpg
Request
Path Parameters
Response
Success
Status: 200 OK
Rename Camera Still For Worker Experiment
Rename Camera Still For Worker Experiment endpoint.
Endpoint
PATCH /api/workers/{pioreactor_unit}/camera/experiments/{experiment}/stills/{image_id}.jpg
Request
Path Parameters
Request Body
| new_image_id | string | Yes | new image id. |
"new_image_id": "example_new_image_id"
Response
Success
Status: 200 OK
Get Camera Focus Preview For Worker
Get Camera Focus Preview For Worker endpoint.
Endpoint
GET /api/workers/{pioreactor_unit}/camera/focus_sessions/{session_id}/preview.jpg
Request
Path Parameters
Response
Success
Status: 200 OK
Update Camera Settings For Worker
Update Camera Settings For Worker endpoint.
Endpoint
PATCH /api/workers/{pioreactor_unit}/camera/settings
Request
Path Parameters
Request Body
| auto_capture_enabled | boolean | Yes | auto capture enabled. |
Response
Success
Example body:
"unit": "pio01",
Get Capabilities
Endpoint
GET /api/workers/{pioreactor_unit}/capabilities
Request
Path Parameters
Response
Success
Example body:
"task_id": "6144b4ec-9dd9-4582-b699-6511b7f91674",
"result_url_path": "/unit_api/task_results/6144b4ec-9dd9-4582-b699-6511b7f91674",
Get All Estimators
Get All Estimators endpoint.
Endpoint
GET /api/workers/{pioreactor_unit}/estimators
Request
Path Parameters
Response
Success
Example body:
"task_id": "5d167889-c361-4fba-976e-3072ed13a938",
"result_url_path": "/unit_api/task_results/5d167889-c361-4fba-976e-3072ed13a938",
Get Estimators By Device
Get Estimators By Device endpoint.
Endpoint
GET /api/workers/{pioreactor_unit}/estimators/{device}
Request
Path Parameters
Response
Success
Example body:
"task_id": "8564f31e-02aa-4bee-9bd7-876761493c51",
"result_url_path": "/unit_api/task_results/8564f31e-02aa-4bee-9bd7-876761493c51",
Delete Estimator
Delete Estimator endpoint.
Endpoint
DELETE /api/workers/{pioreactor_unit}/estimators/{device}/{estimator_name}
Request
Path Parameters
Response
Success
Example body:
"unit": "pio01",
Get Estimator
Get Estimator endpoint.
Endpoint
GET /api/workers/{pioreactor_unit}/estimators/{device}/{estimator_name}
Request
Path Parameters
Response
Success
Example body:
"task_id": "929d06a6-1829-45a8-b1e2-35b2d4f40e8e",
"result_url_path": "/unit_api/task_results/929d06a6-1829-45a8-b1e2-35b2d4f40e8e",
Get Experiment Assignment For Worker
Get Experiment Assignment For Worker endpoint.
Endpoint
GET /api/workers/{pioreactor_unit}/experiment
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
"is_active": 1,
Get Logs For Unit And Experiment
Shows event logs from specific unit and experiment, uses pagination.
Endpoint
GET /api/workers/{pioreactor_unit}/experiments/{experiment}/logs
Request
Path Parameters
Query Parameters
Response
Success
Status: 200 OK
Example body:
"level": "INFO",
"task": "stirring",
"source": "app",
Publish New Log
Endpoint
POST /api/workers/{pioreactor_unit}/experiments/{experiment}/logs
Request
Path Parameters
Request Body
"level": "INFO",
"source": "api",
"source_": "api",
"task": "stirring"
Response
Success
Example body:
Get Recent Logs For Unit And Experiment
Shows event logs for a specific unit within an experiment. This is for the single-page Pioreactor ui
Endpoint
GET /api/workers/{pioreactor_unit}/experiments/{experiment}/recent_logs
Request
Path Parameters
Query Parameters
Response
Success
Status: 200 OK
Example body:
"level": "INFO",
"task": "stirring",
"source": "app",
Get Fallback Time Series Per Unit
Get Fallback Time Series Per Unit endpoint.
Endpoint
GET /api/workers/{pioreactor_unit}/experiments/{experiment}/time_series/{data_source}/{column}
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
"series": [
"pio01",
"pio02"
"data": [
"y": 0.01234
"y": 0.0125
"y": 0.00987
"y": 0.01001
Get Growth Rates Per Unit
Get Growth Rates Per Unit endpoint.
Endpoint
GET /api/workers/{pioreactor_unit}/experiments/{experiment}/time_series/growth_rates
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
"series": [
"pio01",
"pio02"
"data": [
"y": 0.01234
"y": 0.0125
"y": 0.00987
"y": 0.01001
Get Od Readings Per Unit
Get Od Readings Per Unit endpoint.
Endpoint
GET /api/workers/{pioreactor_unit}/experiments/{experiment}/time_series/od_readings
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
"series": [
"pio01",
"pio02"
"data": [
"y": 0.01234
"y": 0.0125
"y": 0.00987
"y": 0.01001
Get Od Readings Filtered Per Unit
Get Od Readings Filtered Per Unit endpoint.
Endpoint
GET /api/workers/{pioreactor_unit}/experiments/{experiment}/time_series/od_readings_filtered
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
"series": [
"pio01",
"pio02"
"data": [
"y": 0.01234
"y": 0.0125
"y": 0.00987
"y": 0.01001
Get Od Readings Fused Per Unit
Get Od Readings Fused Per Unit endpoint.
Endpoint
GET /api/workers/{pioreactor_unit}/experiments/{experiment}/time_series/od_readings_fused
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
"series": [
"pio01",
"pio02"
"data": [
"y": 0.01234
"y": 0.0125
"y": 0.00987
"y": 0.01001
Get Od Raw Readings Per Unit
Get Od Raw Readings Per Unit endpoint.
Endpoint
GET /api/workers/{pioreactor_unit}/experiments/{experiment}/time_series/raw_od_readings
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
"series": [
"pio01",
"pio02"
"data": [
"y": 0.01234
"y": 0.0125
"y": 0.00987
"y": 0.01001
Get Temperature Readings Per Unit
Get Temperature Readings Per Unit endpoint.
Endpoint
GET /api/workers/{pioreactor_unit}/experiments/{experiment}/time_series/temperature_readings
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
"series": [
"pio01",
"pio02"
"data": [
"y": 0.01234
"y": 0.0125
"y": 0.00987
"y": 0.01001
Change Worker Status
Change Worker Status endpoint.
Endpoint
PUT /api/workers/{pioreactor_unit}/is_active
Request
Path Parameters
Request Body
| is_active | integer | Yes | is active. |
"is_active": true
Response
Success
Status: 200 OK
Example body:
"status": "success"
Get Job Descriptors For Worker
Proxy a request for background-job UI descriptors to one worker.
Endpoint
GET /api/workers/{pioreactor_unit}/jobs/descriptors
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
"display": true,
"type": "numeric",
"display": true,
"default": null,
"unit": "RPM",
"editable": true,
"min": null,
"max": null
"source": "app",
"subtext": null,
"is_testing": false
"display": true,
"source": "app",
"subtext": null,
"is_testing": false
"display": true,
"source": "app",
"subtext": null,
"is_testing": false
Endpoint
PATCH /api/workers/{pioreactor_unit}/jobs/run/job_name/{job_name}/experiments/{experiment}
Request
Path Parameters
Request Body
"options": {
"target_rpm": "200"
"env": {
"JOB_SOURCE": "api"
"args": [
"some-flag"
"stirring.config",
"pwm_hz",
"100"
Response
Success
Example body:
"unit": "pio01",
Endpoint
POST /api/workers/{pioreactor_unit}/jobs/run/job_name/{job_name}/experiments/{experiment}
Request
Path Parameters
Request Body
"options": {
"target_rpm": "200"
"env": {
"JOB_SOURCE": "api"
"args": [
"some-flag"
"stirring.config",
"pwm_hz",
"100"
Response
Success
Example body:
"unit": "pio01",
Get Jobs Running
Endpoint
GET /api/workers/{pioreactor_unit}/jobs/running
Request
Path Parameters
Response
Success
Example body:
"task_id": "27b0e81d-4e16-45f3-96f7-b03676078bed",
"result_url_path": "/unit_api/task_results/27b0e81d-4e16-45f3-96f7-b03676078bed",
Get Job Settings For Worker
Get Job Settings For Worker endpoint.
Endpoint
GET /api/workers/{pioreactor_unit}/jobs/settings/job_name/{job_name}/experiments/{experiment}
Request
Path Parameters
Response
Success
Example body:
"unit": "pio01",
Get Job Setting For Worker
Get Job Setting For Worker endpoint.
Endpoint
GET /api/workers/{pioreactor_unit}/jobs/settings/job_name/{job_name}/setting/{setting}/experiments/{experiment}
Request
Path Parameters
| setting | string | Yes | Job setting name. |
Response
Success
Example body:
"unit": "pio01",
Endpoint
PATCH /api/workers/{pioreactor_unit}/jobs/stop/experiments/{experiment}
Request
Path Parameters
Response
Success
Example body:
"status": "success"
Endpoint
POST /api/workers/{pioreactor_unit}/jobs/stop/experiments/{experiment}
Request
Path Parameters
Response
Success
Example body:
"status": "success"
Endpoint
PATCH /api/workers/{pioreactor_unit}/jobs/stop/job_name/{job_name}/experiments/{experiment}
Request
Path Parameters
Response
Success
Example body:
"unit": "pio01",
Endpoint
POST /api/workers/{pioreactor_unit}/jobs/stop/job_name/{job_name}/experiments/{experiment}
Request
Path Parameters
Response
Success
Example body:
"unit": "pio01",
Update Job On Unit
Endpoint
PATCH /api/workers/{pioreactor_unit}/jobs/update/job_name/{job_name}/experiments/{experiment}
Request
Path Parameters
Request Body
"settings": {
"target_rpm": "200"
Response
Success
Example body:
Get Worker Model And Metadata
Get Worker Model And Metadata endpoint.
Endpoint
GET /api/workers/{pioreactor_unit}/model
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
"is_legacy": false,
"is_contrib": false
Change Worker Model
Change Worker Model endpoint.
Endpoint
PUT /api/workers/{pioreactor_unit}/model
Request
Path Parameters
Request Body
| model_name | string | Yes | model name. |
| model_version | string | Yes | model version. |
Response
Success
Status: 200 OK
Example body:
"status": "success"
Update Reported Worker Active
Update Reported Worker Active endpoint.
Endpoint
PUT /api/workers/{pioreactor_unit}/reported_active
Request
Path Parameters
Request Body
"is_active": true
Response
Success
Status: 200 OK
Example body:
"status": "success"
Update Reported Worker Model
Update Reported Worker Model endpoint.
Endpoint
PUT /api/workers/{pioreactor_unit}/reported_model
Request
Path Parameters
Request Body
Response
Success
Status: 200 OK
Example body:
"status": "success"
Get Settings Descriptors For Worker
Proxy a request for settings UI descriptors to one worker.
Endpoint
GET /api/workers/{pioreactor_unit}/settings/descriptors
Request
Path Parameters
Response
Success
Status: 200 OK
Example body:
"display": true,
"type": "numeric",
"display": true,
"default": 14.0,
"unit": "mL",
"editable": true,
"min": 0.0,
"max": null
"type": "numeric",
"display": true,
"default": 14.0,
"unit": "mL",
"editable": true,
"min": 0.0,
"max": null
"type": "numeric",
"display": true,
"default": 0.0,
"unit": null,
"editable": true,
"min": 0.0,
"max": 1.0
"source": "app",
"subtext": null
"key": "leds",
"display": false,
"key": "intensity",
"type": "string",
"display": true,
"default": null,
"unit": null,
"editable": false,
"min": null,
"max": null
"source": "app",
"subtext": null
"key": "pwms",
"display": false,
"key": "dc",
"type": "string",
"display": true,
"default": null,
"unit": null,
"editable": false,
"min": null,
"max": null
"source": "app",
"subtext": null
Get Task Result For Worker
Get Task Result For Worker endpoint.
Endpoint
GET /api/workers/{pioreactor_unit}/task_results/{task_id}
Request
Path Parameters
| task_id | string | Yes | Task identifier. |
Response
Success
Example body:
"task_id": "task-id",
"result_url_path": "/unit_api/task_results/task-id",
"status": "pending"
Get Zipped Calibrations
Get Zipped Calibrations endpoint.
Endpoint
GET /api/workers/{pioreactor_unit}/zipped_calibrations
Request
Path Parameters
Response
Success
Status: 200 OK
Remove All Workers From All Experiments
Remove All Workers From All Experiments endpoint.
Endpoint
DELETE /api/workers/assignments
Response
Success
Example body:
"unit": "pio01",
Get Workers And Experiment Assignments
Get Workers And Experiment Assignments endpoint.
Endpoint
GET /api/workers/assignments
Response
Success
Status: 200 OK
Example body:
"is_active": 1
Discover Available Workers
Discover available pioreactor workers on the network not already registered.
Endpoint
GET /api/workers/discover
Response
Success
Status: 200 OK
Setup Worker Pioreactor
Provision and register a newly discovered worker. Returns 202 with a task to poll.
Endpoint
POST /api/workers/setup
Request
Request Body
| model | string | Yes | model. |
| name | string | Yes | name. |
| version | string | Yes | version. |
| ipv4_address | string | No | ipv4 address. |
"model": "example_model",
"name": "testing_experiment",
"version": "example_version",
"ipv4_address": "example_ipv4_address"
Response
Success
Example body:
"unit": "pio01",
