Avoiding when optical density is run
It's common to want a feature to turn off, or more generally change behaviour, when a sensitive optical density reading is taken. For example, if running an air bubbler, you may want to turn it off before an OD reading is taken, and then turn if back on after.
This behaviour is so common, we've added a helper class to take care of it for you. In pioreactor.background_jobs.base is the class BackgroundJobWithDodgingContrib that implements most of the "dodging" behaviour for you. you'll only need to do three things:
- Inherit from
BackgroundJobWithDodgingContrib, instead ofBackgroundJobContrib
from pioreactor.background_jobs.base import BackgroundJobWithDodgingContrib
class JustPause(BackgroundJobWithDodgingContrib):
- Fill in what to do before, and after, an OD reading takes place by implementing method
action_to_do_before_od_readingandaction_to_do_after_od_reading, respectively.
def __init__(self, ...):
super().__init__(..., enable_dodging_od=False, plugin_name="just-pause") # set to True if you want the dodging behaviour right away.
def action_to_do_before_od_reading(self):
# example
self.logger.debug("Pausing")
self.stop_pumping()
def action_to_do_after_od_reading(self):
# example
self.logger.debug("Unpausing")
self.start_pumping()
- You should also consider what the job should do if OD reading isn't turned on. That is, what should the default behaviour be without OD reading. Also, what should occur when the OD reading is turned on late.
You can handle the "dodging" case and "continuous" with the initialize_* methods:
def initialize_dodging_operation(self):
self.logger.debug("OD reading is ON and I'm enabled for dodging, so set up what I need...")
def initialize_continuous_operation(self):
self.logger.debug("OD reading is off, or being ignored, so set up what I need for that...")
# example
self.stop_pumping()
# example
- We also want some "buffer" time before and after an OD reading. For example, if using a bubbler, we want the bubbles to dissipate completely before taking an OD reading. We should stop bubbling early then. To set these times, add the following to your config.ini:
[<job_name>.config]
pre_delay_duration=<float>
post_delay_duration=<float>
enable_dodging_od=1
The diagram of timing, actions, and OD reading, looks like the following:
And you're done!
