Customize the hardware interface
Pioreactor's hardware layer is intentionally data-driven. Everything in core/pioreactor/hardware.py loads user-editable YAML files from ~/.pioreactor/hardware/ (or the folder pointed to by the DOT_PIOREACTOR env var). By editing these files you can rewire pins, add new peripherals, or describe an entirely new bioreactor model without touching the Python code. Pair these configs with custom bioreactor model definitions so the UI, safety limits, and wiring stay in sync.
How the loader works
hardware.py deep-merges two directories for each mod (subsystem):
~/.pioreactor/hardware/hats/<hat_version>/<mod>.yaml– physical wiring that ships with a specific HAT revision (hardware_version_info).~/.pioreactor/hardware/models/<model>/<version>/<mod>.yaml– intent for a particular bioreactor model returned byget_pioreactor_model().
Later layers override earlier ones. Missing files are allowed; missing keys throw HardwareErrors when helpers such as get_pwm_to_pin_map() run.
Common mods defined inside hardware.py are:
pwm.yaml(get_pwm_controller,get_heater_pwm_channel,get_pwm_to_pin_map)gpio.yaml(get_pcb_led_pin,get_hall_sensor_pin,get_sda_pin,get_scl_pin)temp.yaml(get_temp_address, used byis_heating_pcb_present)adc.yaml(get_adc_curriers, which subsequently powers PD channel helpers)dac.yaml(get_dac_address)
You can add additional mods with any key/value structure—get_layered_mod_config("my_mod") will still combine the YAML files.
Step-by-step: add a custom hardware profile
Create directories for your HAT and model version.
mkdir -p ~/.pioreactor/hardware/hats/<hat_version>mkdir -p ~/.pioreactor/hardware/models/<model_name>/<model_version>Use
pioreactor.version.hardware_version_info(for hats) and yourpioreactor.modelsentry for models. -
Describe the wiring (hat layer). Example
~/.pioreactor/hardware/hats/0.2/pwm.yaml:controller: hat_mcuheater_pwm_channel: "5"pwm_to_pin:"1": 17"2": 13"5": 18These keys map directly to
_load_pwm_cfg()inhardware.py. -
Describe the capabilities (model layer). Suppose you added a new auxiliary photodiode ADC:
~/.pioreactor/hardware/models/my_model/v1.0/adc.yamlpd1:driver: ADS1115address: 0x48channel: 0aux:driver: picoaddress: 0x40channel: 0salty:driver: ADS1115address: 0x49channel: 2get_adc_curriers()will automatically expose.keys()for every entry (pd1,aux,salty). Downstream helpers, likeget_available_pd_channels(), treatpd*names as photodiode channels. -
Reference new mods in code. Anywhere in your plugin/automation you can import:
from pioreactor.hardware import get_layered_mod_configstir_cfg = get_layered_mod_config("stirrer") # merges hats/<hat>/stirrer.yaml and models/<model>/stirrer.yamlif stir_cfg.get("controller") == "pico":...This keeps custom hardware logic outside Pioreactor core.
Migrating plugins from hardware constants
Use the getter functions when initializing hardware in plugins. The next Pioreactor core release removes the deprecated module constants listed below. Update affected plugins before upgrading core. These plugin releases use the getter functions:
| Plugin | Updated version |
| OLED status display | 0.2.2 |
| PiOLED display | 0.5.1 |
| Temperature expansion kit | 0.4.1 |
| Relay | 0.8.2 |
| Deprecated constant | Replacement |
GPIOCHIP | determine_gpiochip() |
PWM_CONTROLLER | get_pwm_controller() |
HEATER_PWM_TO_PIN | get_heater_pwm_channel() |
PWM_TO_PIN | get_pwm_to_pin_map() |
SDA, SCL | get_sda_pin(), get_scl_pin() |
PCB_LED_PIN, PCB_BUTTON_PIN | get_pcb_led_pin(), get_pcb_button_pin() |
HALL_SENSOR_PIN | get_hall_sensor_pin() |
TEMP, TEMP_ADDRESS | get_temp_address() |
ADCs | get_adc_curriers() |
DAC, DAC_ADDRESS | get_dac_address() |
For example, initialize an I2C bus with:
import busio
from pioreactor.hardware import get_scl_pin, get_sda_pin
i2c = busio.I2C(get_scl_pin(), get_sda_pin())
For a PWM pin, call get_pwm_to_pin_map()[channel]. The deprecated HEATER_PWM_TO_PIN name refers to a PWM channel, so the heater's GPIO pin is get_pwm_to_pin_map()[get_heater_pwm_channel()].
Tips for customization
- Use integers for all addresses and pins;
hardware.pycasts everything viaint()and will raise if parsing fails. - Keep YAML minimal—only override keys that differ from the hat defaults to take advantage of deep-merge layering.
- The helper predicates (
is_ADC_present,is_heating_pcb_present, etc.) are safe ways to gate optional hardware in your jobs.
Once you describe the hardware this way, the rest of the stack—jobs, automations, plugins—just asks hardware.py for the capabilities it needs, so new hardware becomes a configuration exercise instead of a fork of the core codebase.
