Common questions
Pioreactor operation
How can I restart my Pioreactor? Is pulling the power plug out safe?
We suggest using the UI to reboot your Pioreactor's software:
Pulling the plug is usually fine, but try to avoid doing it as much as possible.
Can I still use the Pioreactor software without the hardware?
Yes - the Pioreactor UI and software should still work. There will be warnings that there is no HAT attached, but those can be ignored.
Why does the onboard blue LED keep flashing?
There may be a problem. You can diagnose the problem by counting the number of flashes observed.
What does the onboard button do?
The button on the Pioreactor HAT sends a signal to the web UI to display a "hello" message. This is useful to know which Pioreactor in a cluster you are interacting with. The button also will republish the state of the Pioreactor.
The button can be reprogrammed, too.
How do I change the date or time on the Pioreactor?
SSH into your Pioreactor, and run:
sudo date --set "Thu Nov 2 09:46:50 EDT 2023"
Optical density and LEDs
How does optical density work on the Pioreactor?
The Pioreactor uses turbidity to measure optical density (other systems, like spectrophotometers, use attenuation). Specifically, the Pioreactor uses scattering of light. The system will shine infrared light into the culture, and measure the amount of light that is scattered off cells. The scattering has a good linear range (see below for more), and higher saturation point than attenuation for cultures of 20ml volume. If you have an instrument that measures OD600 or some other measurement of optical density, and you wish to calibrate to that, the Pioreactor has a routine to perform a calibration and record in the instruments units. See docs here.
What are the units of Pioreactor's optical density
The uncalibrated optical densities reported the UI and recorded in the database are have an arbitrary unit, and are per Pioreactor (so they can't be compared to each other). However, the normalized optical density, generated after starting the activity Growth rate in the UI, is comparable, which is why we suggest using it for inferences (especially if you haven't calibrated to some OD600 machine). Read more about our optical density measurements here.
How can I change the frequency (rate) of optical density measurements?
In the configuration, you can edit the parameter samples_per_second
to adjust the how often the Pioreactor takes an optical density snapshot. Note that this parameter is the inverse of "duration between readings". For example, if you wish to record a measurement every 60 seconds, then samples_per_second=0.01666667
(which is 1/60).
Why does the intensity for LED A turn on & off during an experiment?
You may have noticed that the LED labelled A turns on & off every 5 seconds or so. This is (normally) the channel for the infrared (IR) LED, which is used in the optical density measurements. We only take reading every 5 seconds (the default), we don't need the IR LED on all the time. The Pioreactor will only turn on LED when needed. This preserves the strength of the LED over longer periods of time. For more advanced use cases, it also allows other optical measurements to take place without the IR LED interfering with them.
Why does my optical density flatten, or even decrease? What is a saturation point?
For some experiments, especially when using a scatter angle of 135°, you may notice that the optical density starts to flatten, and even decrease, when you know the culture should still be growing. This is not a property of the culture, but occurs because the culture is getting too dense, and light is now being interrupted before it reaches the photodiodes. Prior to this point, called the saturation point, the relationship between culture density and optical density is nearly linear. But after this point, there is a flattening, even negative, relationship between culture density and optical density. For all analysis, we recommend only studying when the culture is in the linear regime. You can mitigate the problem by choosing a smaller scatter angle (like 90° or 45°), diluting the culture using an automation like the turbidostat, or using a lower concentration of nutrient(s) in the media. Read more about Pioreactor's optical system here.
What does the effect of the scatter angle have on optical density?
The scatter angle is the angle between the IR LED and a photodiode. This angle can be 45°, 90°, or 135° (although 180° is possible, we don't consider it here). What is there to consider when choosing an angle. In general, the trend is shorter angles => less sensitive at low densities, but higher saturation point. By default, we suggest 45° as a good trade off between sensitivity and saturation. You can mix angles, and the Pioreactor's internal algorithm will still combine them into a single growth rate. Read more about Pioreactor's optical system here.
Can I use my own 5mm LEDs and photodiodes for optical density?
Of course! The only two requirements are that the spectrum of the LED overlaps with the spectrum of the photodiode, and that the LED light won't be absorbed by media/culture, nor damage the media/culture. Thus, the often-used 600nm light source works in the Pioreactor. None of our internal algorithms or analytics are dependent on the wavelength of light chosen.
When you are using additional LEDs outside of the optical density LED & photodiode pair, you may worry that your additional LEDs will interfere with the optical density measurement. This won't happen, as we turn off all non-optical density LEDs before taking an optical density measurement.
Is optical density the same as turbidity?
Turbidity is a measure of optical density, like how decibels are a measurement of sound intensity. Likewise, absorbance is a measure of optical density.
Heating and Temperature control
Why does the Pioreactor only provide a temperature reading every 4 minutes?
We made a design choice early on to make preparation as error-free as possible. This involved thinking about sensors being in situ (in place), versus the sensors being on the outside of the vial. The temperature sensor in the Pioreactor is outside the vial, which means less chance of contamination, but there's a tradeoff (as you could guess): we have to rely on an estimation algorithm that requires 4 minutes to gather data on. We think this is a fair trade-off, as high frequency temperature readings are not that important in an experiment that lasts 12 hours or more.
Why does the Pioreactor's heating keep shutting off?
If you find that the Pioreactor's heating is shutting off, typically with an accompanying error and flashing blue light, then likely the temperature is becoming too high for safe handling. We restrict the onboard PCB's temperature to be no higher than 63℃. Temperature's higher than this can deform the plastic, and possibly cause burns. If the Pioreactor detects a temperature near or above this value, the software will shut off the heating, and possible the entire Raspberry Pi in extreme cases.
To avoid this occurring, we suggest not setting the target temperature too high - not more than 20℃ above ambient temperature. Also, reducing the Kd
parameter in [temperature_automation.stable]
section in the config.ini would help.
How does heating work on the Pioreactor?
The Pioreactor has an onboard PCB, called the heating PCB, that sits below the glass vial. On the PCB are resistors that convert current from PWM outputs into heat. By varying the duty cycle of the PWM, we vary the amount of heat converted.
Mixing and stirring in the Pioreactor
How is mixing / stirring performed in the Pioreactor?
Stirring is performed with a micro stir bar inside the vial, controlled by a pair of magnets spinning below the vial. The rotation speed, RPM, of the stir bar can be controlled using the Pioreactor software. This stirring is also how aeration is done.
Can I use my own stir bar?
Of course! The maximum length of a stir bar is 20mm. Keep the height low as to not interfere with the optics. (The provided stir bar is 3mm high). Try using other stir bar shapes / designs!
The magnets rubs against the plastic screws above them, causing the stirring performance to be degraded / stop. How do I fix this?
Dis-attach the top faceplate. Under the faceplate, slightly unscrew each of the four metal screws. This will add more space between the magnets and the plastic screws.
How can I increase the strength of the magnetic force applied to the stirbar?
For Pioreactor 20ml v1.0: Try to reduce the distance between the stirring magnets and the stir bar by carefully raising the stirring fan a small amount. Going even further, you can remove the 4mm screws in the bottom of the vial holder (but find another way to secure the PCB), thereby be able to bring the magnets even closer.
How can I improve mixing and aeration?
If the standard mixing and aeration with the stir bar is not enough for your application, you can do a few things, (in increasing order of complication, not necessarily effectiveness):
- If the tubes in the cap are submerged during operation, this is reduce the transfer of air. Pull them up from the top of the cap to keep them out of the liquid. Even more effective: shorten them with scissors.
- Increase the RPM of the stirring. This will increase the surface area exposed to the air. Be warned though: too high of an RPM will cause either a large enough vortex to interfere with the optical systems, or will causing the stir bar to fall out of sync.
- Add a baffle to the vial cap. A simple cylinder that rests into the liquid causes disturbance in the rotating liquid that both mixing and aeration are significantly improved. A tube can be removed from the cap, and a autoclavable rod can be inserted such that it enters the media, but won't interfere with the optics.
- Adding external aeration to your Pioreactor. In the simplest case, using an air pump.
Raspberry Pi Hardware
What Raspberry Pi hardware can I use? I see Raspberry Pi 1, 2, 3, 4, A, B, +, Zero - it's confusing!
We've designed the hardware and software to be compatible with any Raspberry Pi that has onboard Wifi and a 40 pin header. That includes (at the time of writing):
- Raspberry Pi 3 Model B
- Raspberry Pi 3 Model B+
- Raspberry Pi 3 Model A+
- Raspberry Pi 4 Model B ³
- Raspberry Pi Zero W (with header) ¹
- Raspberry Pi Zero 2 W (with header)
- Raspberry Pi 400 ²
Although you can use any above, we like the Raspberry Pi 3 Model A+, and Raspberry Pi Zero 2 W because of their low power consumption, slim build, and low price. Both have the necessary CPU power and memory for the Pioreactor workload, and are generally easy to source.
¹ Raspberry Pi Zero W is on the list above, and is very low cost compared to the others. They can absolutely be used for Pioreactors as workers - we don't recommend them to be your leader (note sure what these terms mean? Here's an introduction to leader and workers). As workers, Raspberry Pi Zero W perform just fine, but will respond slower to commands. Note that this does not include the Raspberry Pi Zero 2 W model, which is fine for all roles.
² The Raspberry Pi 400 has its 40 pin header exposed in a different orientation, so your Pioreactor won't be able to sit on top like for other RPi versions. Take a look at this forum post to see how another user used the Raspberry Pi 400 with their Pioreactor.
³ Note that you don't need a lot of RAM for the Pioreactor, so we recommend getting the lower RAM option RPi 4s (1GB or 2GB) to save some money. However, 4GB and 8GB are fine, too.
What microSD cards do you recommend?
At least 16GB. We like 16GB or 32GB SanDisk Edge or Samsung microSD cards for their longevity, but any good quality, class 10 SD card will do.
What power supply unit (PSU) do I need?
If you look at the power rating, it should be about 5 V and at least 2.25 A, or above 12 W. We really like the official Raspberry Pi PSUs, available at most places you can purchase Raspberry Pis.
Do I need any cooling for the Raspberry Pi?
Nope, you shouldn't, unless you are connecting an external monitor. However, extra heat sinks are never a bad idea!
Could a Raspberry Pi-compatible board work, like Rock Pi 4?
Maybe? We haven't tested them, but so long as i) the GPIO pins are identical, and ii) Raspberry Pi OS can be installed, it should work.
Why are the Raspberry Pi LEDs/USB/Ethernet/etc. turned off?
We turn off the "activity" LED (usually the green one) to save some power for the Pioreactor's peripherals. We do the same for USB and Ethernet. You can turn these back on by editing the /boot/config.txt
file on the RPi.
What is the username/password for the Raspberry Pi?
When setting up your Raspberry Pi with the Pioreactor software, you would have chosen a password. Try the recommended username: pioreactor
, and password: raspberry
Can I use the desktop interface (with a display) with the Pioreactor?
Not currently. Our software is based of the "headless" operating-system, which doesn't have display output.
Dosing
Why does the Media card in the UI not update when I run a dosing command?
The Media card will only update when an Dosing Automation is active (even the Silent
automation). Why is it done this way? Often, you don't want volumes to be recorded there: during cleaning, during testing, etc. Often you only want volumes associated with the experiment to be there.
All dosing events ares recorded to the database however, and with a record of when the event occurred, and source of action. This data is available in the "Export data" web page, under Dosing event log
Data storage, access and recovery
💡 For any important project, we suggest manually exporting or backing up critical data multiple different places. This doesn't just apply to using the Pioreactor, but is good advice in general.
Where are logs stored?
For the logs that you see in the Log Table in the Experiment Overview page, these can be download on the Download experiment data page in the Pioreactor web interface. Other logs are also available, including dosing event and algorithm change-logs.
More granular logs per Pioreactor are available in /var/log/pioreactor.log
on the Raspberry Pis.
How do I access raw experiment data?
- The Download experiment data page in the Pioreactor web interface provides CSV exports of common datasets from a pre-selected experiment.
- All data eventually lands in a SQLite3 database on the leader Pioreactor, by default located in
/home/pioreactor/.pioreactor/storage/pioreactor.sqlite
. This can be download using a tool likescp
. - To access the SQLite3 database from the command line, try
pio db
My microSD card is corrupted - what can I do?
Unfortunately, the microSD card becoming corrupted or damaged is an infrequent but possible risk with using Raspberry Pis.
If the microSD card was inside a non-leader Pioreactor, it's best to try to reformat the microSD card and start fresh (i.e. reinstall the Pioreactor software and reintroduce it to the cluster). This is usually okay as no critical data is stored locally in workers, only log files and hardware calibrations will be lost.
If the microSD was inside the leader Raspberry Pi, this is a bigger problem. Likely any running experiment will have to be restarted. Fortunately, if you have more than one Pioreactor in your cluster, then the leader's SQLite database has been periodically backing itself up to other Pioreactors in the cluster every few days. Using the command line, check other Pioreactors'
directory for the latest backup namedpioreactor.sqlite.backup
(should be from within the past few days hours). You can use this database to restart a new leader.
Networking
Can I use Ethernet cable connections instead of WIFI connections?
Yes, so long as the Raspberry Pi's are connected to the same network and discoverable, this should work. Even mixing Ethernet and WIFI is fine.
How can I determine the Pioreactor's IP address?
Depending on your access to the Pioreactor, there are a few ways:
- In the UI's
/pioreactors
page, look underManage
->System
for the IP. - After SSH-ing into the Pioreactor, use
hostname -I | awk '{print $1}'
to print the IP address. - If you can't access the Pioreactor's UI or SSH in: the software will write the IP address to the
/boot
directory on the SD card. After the Pioreactor's blue LED has blinked, you can unplug the Pioreactor, remove the SD card, and place the SD card in another computer. Navigate to the card, and in the directory you should see a file calledip
. Open this file, and the IP address should be there. Place the SD card back into the Pioreactor and plug it back in.
I'm using a local access point, but I'd like to install plugins, update software, etc.
To install a plugin
On a computer that is connected to the internet, download the .whl
file from the plugins webpage on PyPI. Then, connect that computer to your Pioreactor's local access point's network. To each Pioreactor you wish to install the plugin on, transfer the .whl
file to the Pioreactor (using SFTP or FTP). Then, run pio install-plugin <plugin-name> <path/to/local/.whl>
To upgrade the Pioreactor software
See steps here.
If I have multiple Pioreactor leaders on my network, what leader does http://pioreactor.local
point to?
If there are multiple leaders on the same network, then each will override the other's pioreactor.local
alias, and the alias will be unreliable. You can either access the leaders by their hostnames: http://<leader hostname>.local
, or you can change the alias in the config.ini, too, by editing domain_alias
under section [ui]
(changing this requires a restart of the machine).
