Overview
The web UI is hosted on the leader Pioreactor. Here are the details:
Web server
The web server we use is lighttp, and hosted from /var/www/pioreactorui
. This folder is actually a git repo, and pulls from pioreactorui GH repo. Systemd controls starting and restarting lighttp.
The lighttp conf file is located in /etc/lighttpd/conf-enabled/50-pioreactorui.conf
. Error logs (though not helpful) are in /var/log/lighttpd/error.log
Backend
The backend app is a Flask app, with entry point in /var/www/pioreactorui/main.fcgi
. The app uses Huey as background workers to perform pio
tasks, save to disk, etc. Huey is controlled by systemd huey.service
. The API is available here
Frontend
The frontend is a React app, built with Material UI components. The source code is at pioreactorui_frontend. A lot of the "data" for the frontend comes from YAML files on the RPi's filesystem. For example, all the charts, activities, and automations are defined in their own YAML file in a contrib
folder on the filesystem. This way, it's easy to add new data to the frontend without having to write new JS.
DNS name resolution to pioreactor.local
To allow for pioreactor.local
to be an alias for <leader hostname>.local
, we use mdns provided by avahi
. There is a systemd service, avahi_alias.service
, that will point pioreactor.local
to <leader hostname>.local
Updating and restarting the web UI
To update on the UI on Pioreactor leader, use pio update ui
. This also restarts the server.
To restart:
sudo systemctl restart lighttp && sudo systemctl restart huey
Logs
- Start up logs from systemd are in
sudo systemctl status lighttpd.service
. - Logs for the backend and background workers are located in
/var/log/pioreactorui.log
