Introduction to background jobs
The core unit of "work" in the Pioreactor software is a background job (called activities in the web interface). Background jobs include od_reading, monitor, automation controllers, all the automations themselves, etc. Often, a community plugin is a background job (or multiple jobs) that gives your bioreactor new abilities. There are a few important features of background jobs to be highlighted if you intend on working with them.
Inheritance and file structure
All background jobs inherit from the base class pioreactor.background_jobs.base.BackgroundJob. This class controls most of the behind-the-scenes behaviour of the class.
Typically, we structure background job code such that the Python file has a single background job class and a command-line interface. See examples here.
Logging
All subclasses of BackgroundJob have the logger attribute that can be used to log messages. These messages are printed to the console, sent to MQTT, sometimes displayed in the UI, and all are stored permanently in the Pioreactor database. Here's how:
# use for debugging
job.logger.debug("A debug message - displayed in the console")
# use for providing relevant updates
job.logger.info("An info message - this is display in the Recent Logs table in the UI")
# use for successes or important updates
job.logger.notice("A notice message - this is displayed in the UI in a green popup")
# use for when something doesn't look correct, but will continue.
job.logger.warning("A debug message - this is displayed in the UI in a yellow popup")
# use for when something is wrong and you take over control from the user
job.logger.error("A debug message - this is displayed in the UI in a red popup")
State of a job
A background job can be in one of five different states:
  • init: the job is initializing. The job starts in this state.
  • ready: the job is prepared to do "work", or currently doing "work"
  • sleeping: the job's work is paused (ex: when the stirring job is in state sleeping, it turns off its power.) This state is called "paused" in the web interface.
  • disconnected: the job has disconnected from services (MQTT, databases, etc.) and cleaned itself up successfully.
  • lost: the job did not disconnect gracefully. Something may be wrong.
Here's how the states can transition to each other:
┌──────────────────────┬───────► lost ◄────────┐
│ init ├──────────► ready ├──────┼─────► disconnected │
│ sleeping ├───────────────────┘
The author can optionally define hooks when a job moves between states, and when it enters a new state. For example, the method .on_ready_to_sleeping() is called when the job moves from ready to sleeping. Similarly, the method .on_sleeping() is called when the jobs enters state sleeping. By default, these methods are empty.
The recommended way to move a job between states is with job.set_state(job.READY). This will invoke any hooks that exist between the states. State can also be changed remotely over MQTT - we'll get to that point later.
Publish & subscribe, also known as pub/sub
On job creation, the job will connect to MQTT to allow for publishing and subscribing. The attribute sub_client is for subscribing from MQTT, and pub_client is for publishing to MQTT. Internally, sub_client and pub_client are Paho client objects.
Since publishing is so common, we also expose a .publish method:
job = SomeBackgroundJob(unit, experiment)
job.publish(f"pioreactor/{job.unit}/{job.experiment}/...", payload)
Another common pattern is to subscribe to a MQTT topic, and execute a threaded callback whenever a message comes in from that topic. This is done with the .subscribe_and_callback method. By convention, this is most often used in a .start_passive_listeners method:
from pioreactor.background_jobs.base import BackgroundJob
class SomeBackgroundJob(BackgroundJob):
def __init__(self, ...):
self.start_passive_listeners()
def response_to_dosing_event(self, msg):
# change self in response, etc.
def start_passive_listeners(self):
self.subscribe_and_callback(
self.response_to_dosing_event,
f"pioreactor/{self.unit}/{self.experiment}/dosing_events",
Publishing attributes to MQTT
A common task is when we have a job running, say stirring job, and we want to dynamically update an attribute, like the target RPM, without restarting the job.
We also want to know the value of a job's attribute when it changes. For example, in the stirring job, we'd like to know what the actual RPM is. This can't be edited externally (it's a measured value...), but we want the value available for other jobs to use, for the web interface to display, or to sink it into a database.
These two tasks, updating attributes and reading attributes in real-time, are so common that we've wrapped the logic into the parent BackgroundJob class, and allow job authors to tell us what attributes they wish to update and/or read.
In the class definition, the attribute published_settings defines which class attributes they would like to track. For example, the job responsible for stirring looks like:
class Stirrer(BackgroundJob):
published_settings = {
"target_rpm": {"datatype": "json", "settable": True, "unit": "RPM"},
"measured_rpm": {"datatype": "json", "settable": False, "unit": "RPM"},
"duty_cycle": {"datatype": "float", "settable": True, "unit": "%"},
Thus the attributes target_rpm, measured_rpm, duty_cycle are all published to MQTT when they change, but only duty_cycle and target_rpm are able to be updated over MQTT (as defined by settable).
  • The "datatype" field is normally one of: "string", "float", "integer", "json", "boolean" (full list in pioreactor/types.py).
  • The "settable" field sets whether this attribute can be changed externally.
  • The "unit" field is the unit of measurement, if any. This key is optional, and can be omitted.
  • Also, there is an optional "persist" key (not shown above), which contains a boolean describing if the value should be kept in MQTT after the job exits, default False.
When a class' attribute that's present in published_settings changes, a MQTT message is published under the topic pioreactor/{self.unit}/{self.experiment}/{self.job_name}/{attr} with payload equal to the new value of the attribute. This is how the web interface is provided real-time data.
For updating an attribute, the BackgroundJob parent class listens to the MQTT topic:
pioreactor/{self.unit}/{self.experiment}/{self.job_name}/+/set
(the + is a MQTT wildcard), and when a message comes in, the class will check if the attribute (defined by +) is settable. If so, a lookup is done to see if a class method called set_<attr> is defined, and if present, calls that, with the only argument the message's payload. Otherwise, a simple assignment is done: self.<attr> = payload. The utility of a set_<attr> method is when changing the attribute requires more logic (ex: changing a PID controller's set point, see example here).
state is special attribute that is automatically appended to published_settings (with settable: True and persist: True) so the state of the job can always be updated and read from MQTT. Over MQTT, the field is called referenced as pioreactor/{unit}/{experiment}/{job_name}/$state - note the $.
When the job disconnects and cleans up, the published settings in MQTT are removed by sending an empty payload to the respective topics (unless persist: True, see above.)
Uniqueness
Only a single instance of a background job, indexed by the job's name, can be running on a Raspberry Pi. For example, only a single Monitor background job can run, likewise only a single ODReading can run. (It's not clear what running multiple ODReadings means, or how they will interact with the hardware - poorly we expect).
The uniqueness is across processes, too. So if a script is running ODReading, then pio run od_reading will fail.
This uniqueness constraint is enforced in the current version of the software. It's possible we will see a reason to remove the uniqueness constraint in a future version - let us know if you want to see this, too!
Entry & exit
Background jobs make lots of connections to MQTT, GPIOs, hardware, and other external systems. It's important to treat background jobs as objects that need to be cleaned up these connections properly.
If your jobs needs to clean up something, you can put it into the on_disconnected function:
from pioreactor.actions.led_intensity import led_intensity
class HappyJob(BackgroundJob):
# connect to a hardware
self.hardware_connection = Hardware()
self.hardware_connection.connect()
# set LED on, too
led_intensity({"A": 10})
def on_disconnected(self):
self.hardware_connection.disconnect()
led_intensity({"A": 0})
on_disconnected is called and connections are closed when the job exits (see below).
There are two ways to use a background job that will ensure jobs are cleaned up correctly on exit:
job.clean_up()
# all cleaned up - state is set to disconnected
alternatively, with a context manager:
with SomeBackgroundJob(unit, experiment) as job:
The job is also cleaned up when the Python process exits.
The following will cause problems:
#❌ don't do this
def function_that_doesnt_clean_up():
# job not cleaned up
return True
value = function_that_doesnt_clean_up()
In the above, the job SomeBackgroundJob isn't disconnected, and state hasn't changed - nor can you access the job anymore (no accessible references). Do this instead:
# ✅ this is okay
def function_that_does_clean_up():
return True
value = function_that_does_clean_up()
Blocking
Often we want the job to wait and blocks, so as to wait for user commands or MQTT messages. We can accomplish this with
job.block_until_disconnected()
This blocks the execution until the job is disconnected (either a MQTT state change, or a signal from the OS).
