Using community-built plugins
The Pioreactor comes with a large set of functionality and behaviour to accomplish most projects. For example, continuous culturing, optical density reading, and stable temperatures are available out-of-the-box. However, the specifics and range of how people use bioreactors goes far beyond what we could ever cover. That's why Pioreactor has added a platform so that community members can make their own extensions and share them with others. We call these plugins. (Below is how to install plugins - if you are looking to create your own plugins, see here.)
Installing plugins
From your Pioreactor's interface, the "Plugins" button on the left navigation bar will display all your currently installed plugins, and available plugins from the community.
plugin page
Custom automations
After installation, custom dosing, LED, or temperature automations will be available in the automation modal under the "Settings" tab in each Pioreactor's Manage modal.
Custom activities
After installation, a custom activity's state and settings will show up on each Pioreactor's card. Below, we've installed the pioreactor-air-bubbler plugin:
Managing on/off and settings are done just like any other job, in the Manage modal:
Alternative: putting Python files in the the plugins folder
An alternative way to install a plugin is to place a Python file in the /home/pi/.pioreactor/plugins directory on the Raspberry Pi. This is good for one-off scripts or plugins you are demoing or testing.
