Adding the High Temp Upgrade kit
If you purchased the High Temp Upgrade kit, you'll be replacing a few of your plastic components with the improved high-temp plastics. Once this is done, you'll also need to install some software:
Software changes
You will need to "unlock" your Pioreactor's higher temperature settings. To do this, you can either
  • install the pioreactor-high-temp-plugin (internet required) using the command pio install-plugin pioreactor-high-temp-plugin on their Pioreactors with the new pieces, or
  • create a new Python file, high_temp_plugin.py in ~/.pioreactor/plugins with the content here.
Remember: only install these changes on Pioreactors with the high temp upgrade kit.
